The price l for FileZilla Pro today jumped a good bit from what I paid last year. Not a huge deal on its own, but it made me actually stop and think about whether I even need the whole Pro thing anymore, since honestly I mostly just use it for the S3 bucket at work and my regular SFTP stuff for client sites.
I’ve got time to figure out a replacement. I bounce between a Windows desktop at home and a Macbook when I’m out, so whatever I land on needs to cover both. Doesn’t need to be free, just needs to actually be worth what I’m paying instead of feeling like an upsell.
first thing I’d say is figure out how much of what you’re paying for is actually the cloud storage piece. if you strip that out, SFTP and FTP support is free basically everywhere, WinSCP on windows, regular FileZilla or Cyberduck on either platform, no reason to pay for that part at all. the only reason Pro pricing makes any sense is the S3 and Google Drive and Dropbox integration bundled in.
so for a real replacement I’d look at CloudMounter over Cyberduck. Cyberduck is fine and it’s free, but it’s still “open the app, connect, browse, transfer” like FileZilla always was. CloudMounter skips that step entirely, your S3 bucket, your SFTP server, whatever cloud accounts you use, they all just show up as a drive in Finder or File Explorer once you set them up. so on your macbook it’s a drive, on your windows box it’s a drive, and you just work with files normally instead of babysitting a transfer window. it covers FTP, SFTP, FTPS and WebDAV too, not just the cloud storage accounts, so it’s a real one for one replacement for what Pro was doing for you, not a downgrade.
price wise it’s usually cheaper than what Pro renews at, you can install it on both machines and run your usual workflow through it for a few days. worst case it doesn’t click for you and you’re back to shopping around, but I’d be surprised if it doesn’t cover what you need.
If you only connect to a few FTP/SFTP servers, WinSCP on Windows or Cyberduck on macOS is the cheaper choice. If you regularly work across SFTP and cloud storage, CloudMounter makes more sense because it puts remote files in your normal file manager instead of another transfer queue.
The caveat with mounted drives is that they can hide what is happening during a slow or interrupted transfer. A file may appear available while it is still uploading, which matters if another person or process uses it immediately. A traditional client gives you clearer queues, retries, logs, and confirmation that the job finished.
Before switching, check the less obvious requirements: SSH key and passphrase support, host-key verification, transfer resume, permission editing, and whether you need folder synchronization. I would test those with a noncritical account first. CloudMounter is convenient for everyday file access, but for bulk uploads or scripted work, a conventional SFTP client may still be the safer and cheaper replacement.
Cancel auto-renew first, then export your site list and make sure you actually know the passwords or have copies of the SSH keys. Saved connections are the annoying part of switching, and an export file should be handled like a password file rather than left sitting in Downloads.
If your work is limited to FTP, FTPS, and SFTP, the free standard FileZilla client may be the easiest answer. You keep the familiar interface and transfer queue without paying for the Pro cloud integrations. WinSCP is the stronger Windows alternative if you want synchronization, scripting, detailed logs, and better control over SSH settings. Cyberduck is reasonable on macOS or Windows, especially if you occasionally need cloud connections, although its interface is fairly different from FileZilla.
I would separate “remote drive” apps from true transfer clients. CloudMounter can be much nicer when you edit documents directly from Finder or File Explorer, but I would not make it my only tool for website deployments, large batches, or anything where I need an obvious completed-transfer record. Keeping a free queue-based client installed alongside it costs nothing and covers that gap.
Whichever option you try, use the remaining subscription period to run the exact jobs that matter:
Connect with your SSH key and passphrase
Confirm the server fingerprint instead of blindly accepting it
Resume an interrupted upload
Preserve timestamps if your workflow needs them
Change remote permissions
Compare or synchronize folders
Upload many small files, not only one large test file
Check whether failed transfers are easy to find and retry
My short version would be regular FileZilla if you just want to remove the Pro fee, WinSCP for a Windows-heavy technical workflow, Cyberduck for occasional cloud access, and CloudMounter when everyday file-manager access matters more than having a traditional transfer queue. There is no reason to replace Pro with another paid subscription unless its cloud-provider support is something you use regularly.
If your computer runs indexing, antivirus, or backup jobs against mounted drives, I’d favor a traditional transfer client. A mount can make remote storage convenient, but local software may scan folders, create metadata files, or generate unexpected traffic. That is the main reason I wouldn’t automatically treat CloudMounter as a drop-in FTP client replacement.
For basic FTP/SFTP work, the free FileZilla edition is the lowest-effort move, while WinSCP makes more sense on Windows if logs and repeatable jobs matter. CloudMounter fits better when you constantly open and edit remote files through Finder or File Explorer. Whichever route you take, check where passwords are stored, whether it uses the system keychain or SSH agent, and how easily credentials can be removed. Protocol support is obvious. Credential handling and background file access are the details that usually become annoying later.
Don’t uninstall FileZilla Pro until the replacement has completed a real job from start to finish. Keep both clients installed and compare hidden files, symlinks, timestamps, permissions, overwrite prompts, and default transfer mode. Those small differences cause more trouble than the actual connection setup.
The free FileZilla suggestion is sensible if you never use Pro’s cloud connections. On Windows, WinSCP is the better pick when you need synchronization or repeatable transfers. Cyberduck is fine for lighter use across Windows and macOS, while a mounted-drive tool suits editing remote files more than deployments.
Before renewal, run the same folder through both clients and compare the remote result. A cheaper client is not a bargain if it silently skips dotfiles, follows a symlink unexpectedly, or changes permissions.
Don’t grab the free FileZilla installer from the first download link you see. The official one can push bundled offers during setup on Windows, and half the ‘FileZilla’ results are repackaged mirrors. Watch the installer screens and decline the extras, or you’ll trade a subscription fee for adware. Small thing, but people switching to save money skip right past it.
The credential export advice from @logictiger2445 is the real gold here, and I’d push it one step further. Before you cancel anything, actually try logging into one server with the exported details in the new client. Half the time a saved password in FileZilla was set years ago and nobody remembers it. An export file full of hosts you can’t authenticate against is useless, and you won’t find out until the Pro sub is already gone.
On CloudMounter, it makes sense as a mounted-drive tool if you’re mostly editing remote files in place, and @jack41 nailed the caveat about background scanners hitting the mount. What I’d add is a simpler decision rule: if your job ends with ‘did the upload actually finish,’ stay with a queue-based client. If your job is ‘open, edit, save, close,’ a mount is nicer. Most people doing website work fall into the first bucket, so free FileZilla or WinSCP covers them without paying for anything. The mount is a comfort feature, not a replacement for a transfer log.
A personal laptop and a company-managed machine are very different replacement cases. Mounted-drive apps can run into security policies, admin approval, endpoint scanning, or restrictions on remote volumes, while a normal SFTP client is usually easier to get approved. If either computer is managed by work, test that before paying for CloudMounter or anything similar. Otherwise you may cancel FileZilla Pro only to discover the convenient replacement is blocked by IT.
Don’t assume a mounted drive will behave exactly like a local disk just because Finder says it does. Editors often save by creating a temporary file, renaming it, and deleting the original, which can produce permission surprises or stray lock files on SFTP servers. That makes CloudMounter convenient for browsing, but I’d test your actual editor before paying for it, because apparently “save this file” can become a minor systems-administration project. If Pro’s cloud support is mostly unused, cancel renewal and keep standard FileZilla for now. Shopping for a perfect replacement can wait until you find a feature you genuinely miss.
