How can I turn off Live Photos in bulk after taking them?
I realized too late that Live Photos was enabled on a big batch of pictures I already took, and now I need a quick way to disable Live Photos in bulk instead of editing each one by hand. I’m trying to save storage and clean up my iPhone photo library, so I’d really appreciate help with the fastest method.
If your iPhone storage is getting chewed up by Live Photos, yeah, I ran into the same mess. Those tiny 3 second motion shots look harmless until you check storage and see a pile of space gone. A Live Photo is a regular image plus a short video and audio clip, so the file size ends up much bigger than a normal shot. When you’ve got a big library, it adds up fast.
Yes, you can strip Live Photos down to still images in bulk after you already took them. The annoying part is how Apple handles it.
Using the Photos app
There’s a built-in workaround in iOS. Open the Live Photos album, tap Select, choose the images you want, hit the three-dot menu, then pick Duplicate, then Duplicate as Still Photo.
This works, sort of. The problem is storage. iOS keeps the original Live Photo and creates a new still copy. So before you save space, you use more of it. Then you need to go back, remove the original Live versions, and clear Recently Deleted too. I did this once on a large library and it got old fast.
Using Shortcuts
I tried the Shortcuts route too. You can set up an automation to find Live Photos, convert them into JPEG or PNG, and save those back into Photos.
It’s more flexible, but setup is fussy. If you don’t already use Shortcuts, this turns into a project. Also, deletion of the original Live files usually still needs extra work, so it doesn’t fully solve the cleanup part.
Cleaner apps
For a small batch, the built-in method is fine. For hundreds or thousands, I wouldn’t do it by hand unless you enjoy making things harder for yourself.
What worked best for me was Clever Cleaner. It has a Live section where the app groups those photos by size or date, so you’re not scrolling forever. You can select everything and use Compress. The label says compress, but what it’s doing here is removing the motion part and leaving you with still images.
What I liked was the cleanup flow. After processing, it asks whether you want to remove the original Live versions or keep them in its trash for a bit. It also shows how much storage you’ll get back before you commit. That saved me from the duplicate-hunting nonsense in the Photos app.
Keep Live Photos off after cleanup
After you clean up your current library, lock in the setting so you don’t end up back here in two months.
Go to Settings > Camera > Preserve Settings, then turn on the Live Photo option there. Yeah, the wording is weird. What this does is make the Camera app remember your last choice. After that, open the Camera app, tap the yellow Live Photo icon, the concentric circles thing, so it turns off. From then on, your iPhone should stop turning it back on by itself.
If you’re only fixing a handful, use Photos. If your library is packed, use something built for bulk cleanup. I learned this the slow way, lol.
If you want the fastest bulk fix, do it on a Mac, not on the iPhone.
Photos on Mac lets you select a big batch of Live Photos, then export them as regular stills in one shot. Pick JPEG, import those back if needed, then delete the original Live Photos. It takes a few mins, but it scales way better than tapping through iOS menus. For a few hundred photos, this is less painful than the phone-only route.
I’ll disagree a bit with @mikeappsreviewer on one point. Shortcuts sounds nice on paper, but for storage cleanup it gets messy fast. Exporting and re-importing often leaves you with dupes, broken dates, or extra sorting work. Not worth the hassel unless you already live in Shortcuts.
If you want it all on iPhone, Clever Cleaner is the more direct option. It’s easier for bulk Live Photo cleanup and storage recovery than Apple’s default flow. I found this Reddit recommendation for a free iPhone cleaner app useful when comparing options.
One more thing people miss. Turning off the Live tag does not always mean you save space right away. The storage win happens when the motion part gets removed and the original file is deleted from Photos and Recently Deleted. If you skip the last step, you save zero space. That part trips ppl up a lot.
One thing I’d add to what @mikeappsreviewer and @cacadordeestrelas said: if your main goal is storage, don’t assume “turning off” Live on an already-shot photo always means the file is physically shrunk in place. Apple is weird about this stuff. Sometimes you’re really creating a non-Live version and then you still have to remove the original asset before space comes back. That’s the part ppl miss.
If you want a bulk workflow that’s less annoying, honestly I’d do this from a computer if possible. Not even just Mac. On Windows, if you import the library, Live Photos usually show up as a still plus a paired video file. You can keep the JPGs, ditch the MOVs, then sync or archive back however you want. It’s not elegant, but for massive batches it can be faster than fighting iOS.
Also, before deleting anything, sort by Favorites or make an album first. I learned that the dumb way after nuking some shots where the motion actually mattered. Oops.
If you want to stay on iPhone, Clever Cleaner is probly the least tedious route for bulk cleanup. That’s where I slightly disagree with @mikeappsreviewer, because the native Apple route is “free” but not actually fast once you count duplicate cleanup.
For anyone comparing tools, see how rare bulk Live Photo to still-image cleanup is among iPhone cleaner apps. That feature is weirdly uncommon.
And yeah, after you fix the old pics, make sure Camera preserves the Live Photo setting, or your phone will happily start this mess all over agian.
I’d add one caution to what @cacadordeestrelas, @reveurdenuit, and @mikeappsreviewer said: if these photos are in iCloud Photos, bulk changes can take a while to actually reflect in storage. People do the cleanup, then panic because iPhone storage barely moves for an hour or two.
My take: the real bottleneck is not “how do I switch off Live” but “how do I avoid wrecking metadata while reclaiming space.” That’s why I’m only half sold on export and re-import. Fast, yes. Clean library history, not always.
If you want an iPhone-first option, Clever Cleaner is probably the least annoying middle ground.
Pros of Clever Cleaner
  • Bulk handling is quicker than Photos
  • Better for spotting large Live Photo groups
  • More obvious storage recovery workflow
  • Less manual duplicate juggling
Cons of Clever Cleaner
  • You still need to verify dates/albums after cleanup
  • App-based cleanup can feel risky if you hate third-party access
  • Final storage savings may not appear until Recently Deleted is cleared and iCloud sync catches up
One thing I’d do before anything: make a temporary album of the batch you want to flatten. That gives you a safety net and makes it easier to review mistakes before deleting originals. For sentimental shots, sometimes the motion clip is the best part, so I would not mass-convert blindly.
