Need A Data Recovery Community That Can Advise On A RAW Drive
My external hard drive suddenly started showing up as RAW after I disconnected it, and now I can’t open it or access years of photos and important files. I’m looking for data recovery advice, safe next steps, and tools that might help me recover data from a RAW drive without making the problem worse.
When a drive suddenly shows up as RAW, I would not start throwing fixes at it. I’ve seen people run repair tools too fast and make the recovery job worse. Sometimes it’s plain file system damage. Other times the drive itself is starting to die. Those two cases do not get handled the same way, and one bad move early on can cost you files you still had a shot at saving.
If the data matters, I’d get live input first instead of following random step lists.
One place worth posting is this Facebook group:
https://www.facebook.com/groups/datarecoveryhelp
What I like about a recovery-focused group is the back and forth. You post the full story, add screenshots, show what Disk Management says, and people who deal with broken drives all the time will usually spot things a generic guide misses. A lot of blog posts push stuff like CHKDSK or tell you to format first and recover later. I would be careful with both. Fine if your only goal is reusing the disk. Bad idea if your files come first.
Reddit is another option, mostly the data recovery subreddits. I’ve found useful replies there, though the quality swings a lot. One person gives a clean, safe next step. The next guy tells you to run a write-heavy repair command with almost no context. So, I’d treat Reddit like a place to compare opinions, not a place where you follow every reply in order.
Older tech forums are still around too, and some of the specialized recovery ones get more technical than social platforms do. If you’re able to post SMART info, Disk Management screenshots, scan results from recovery tools, or details about partition structure, those forums tend to be better for slower, more methodical troubleshooting.
Wherever you ask, include the stuff people need right away:
Drive type. Capacity. File system, if you know it. Your operating system. What happened right before it turned RAW. Whether the full size still shows correctly. Whether the drive clicks, buzzes, or makes any other odd noise. And list every fix you already tried, even the small ones. Saves time. Also stops people from telling you to repeat somthing risky.
Stop plugging it in over and over. RAW after an unsafe disconnect often means file system damage, but if the drive drops out, stalls, or makes odd noise, treat it like failing hardware first.
I agree with @mikeappsreviewer on avoiding CHKDSK. I disagree a bit on Facebook being the first stop. For RAW drives, I’d post in a data recovery community where replies stay searchable and techs ask for the right info fast. Try get RAW drive recovery help from a focused data recovery community.
Do this first.
Power the drive off.
Do not format it.
Do not run repair tools.
Check SMART with CrystalDiskInfo if the drive stays connected.
Grab a screenshot of Disk Management.
If SMART shows bad sectors, pending sectors, or the USB bridge keeps disconnecting, clone the drive first with HDDSuperClone or ddrescue. Recover from the clone, not the original.
If the drive is quiet, full size shows right, and SMART looks clean, software like DMDE, R-Studio, or UFS Explorer is a better path than Windows fixes.
SEO-friendly version of your issue.
External hard drive shows RAW after disconnect, now photos and files are inaccessible. Looking for safe data recovery steps, trusted tools, and a reliable data recovery community for advice before making things worse.
Post the drive model, capacity, OS, and what you tried alredy. That saves time.
RAW after unplugging is one of those cases where the cause matters more than the symptom. @mikeappsreviewer is right about not jumping straight into Windows “fixes,” and @sternenwanderer is right that searchable recovery communities are usually more useful than random social replies. I’d lean a little more toward a dedicated forum-style place than Facebook, mostly because the advice stays visible and easier to compare later.
I’d post it here first: get focused help for a RAW external hard drive
What I’d add that hasn’t been said much yet is this: pay attention to behavior, not just status. A drive showing RAW is bad, sure, but a drive that goes RAW and also hangs File Explorer, takes forever to mount, disappears during reads, or makes the whole system lag is waving a giant red flag for hardware trouble. In that case, even “safe sounding” scan tools can push it too hard.
Also, if this is an external drive, the enclosure itself can be the problem. Bad USB cable, weak power supply, flaky USB bridge board, all can make a healthy-ish drive look worse than it is. I would test with a different cable, different port, and if it has an external power brick, check that too. Not endless plugging and unplugging, just a controlled check. People forget the enclosure is part of the chain.
For posting in a data recovery community, include:
  • exact drive model
  • whether it is HDD or SSD
  • whether capacity shows correctly
  • SMART screenshot if possible
  • Disk Management screenshot
  • whether the drive was exFAT, NTFS, etc
  • any weird noise or disconnecting
  • what tools you already ran
Search-friendly summary of the issue:
External hard drive shows RAW after disconnecting, and now photos and files cannot be accessed. Need safe data recovery advice, trusted recovery tools, and a reliable data recovery community before attempting repairs or formatting.
Do not “initialize,” do not format, and honestly do not keep poking at it because curiosity kills recoveries too lol.
One small disagreement with @jeff: I would not even trust a “clean-looking” SMART report too much on some USB externals, because bridge chips love hiding ugly details. So if the drive behaves inconsistently, I’d judge the symptoms more than the SMART screenshot.
What I’d do that complements what @sternenwanderer and @mikeappsreviewer already covered is verify whether the RAW state is only a partition issue or whether the partition table itself got scrambled. In Disk Management, note whether the volume still has the expected size and whether the space is shown as a normal partition or just unallocated. That distinction matters because a RAW volume with correct size can be a much simpler recovery case than a drive suddenly showing strange layout changes.
Also check this from a second machine if possible. Not to keep experimenting forever, just to rule out a Windows USB stack hiccup. I’ve seen a drive mount RAW on one system and read normally on another long enough to image it.
Pros of using a data recovery community:
  • people can spot warning signs from screenshots fast
  • searchable threads help compare advice
  • less chance of blindly following generic repair guides
  • mixed skill levels
  • sometimes too much conflicting advice
  • social groups can push rushed tool suggestions without enough diagnostics
So yes, a data recovery community is useful, but I’d treat it like triage, not gospel. Post the screenshots, then wait for pattern-based advice instead of trying every suggested utility. If the files are irreplaceable, the best “tool” may still be stopping now before the drive gets worse.
