Ai Resume Review
I just used an AI tool to rewrite my resume, but now I’m not sure if it actually looks better to real hiring managers. Some sections feel generic and I’m worried it might hurt my chances instead of helping. Could you review my AI-edited resume, point out any red flags, and suggest how to improve it for ATS and real recruiters?
AI rewrites tend to sound polished but generic. Hiring managers notice that fast.
Here is a quick way to check and fix it.
  1. Check for “AI smell”
    If your resume has phrases like:
  • “Results driven professional”
  • “Demonstrated track record of success”
  • “Leveraged cross functional synergies”
    It reads like everyone else. Replace those with plain language tied to outcomes.
Example:
“Results driven professional with a proven track record”
Change to: “Sales rep. Closed 120+ deals in 2023, top 10 percent on the team.”
  1. Make every bullet show impact
    Use this pattern for each bullet:
    Action verb + what you did + numbers.
Examples:
  • “Improved onboarding process”
    Change to: “Reduced new hire onboarding time from 10 to 6 days by updating checklists and training docs.”
  • “Managed social media accounts”
    Change to: “Grew Instagram followers from 4k to 9k in 8 months, increased avg post engagement from 2 percent to 4.5 percent.”
If you have no exact numbers, estimate and mark it clear:
“Handled about 20 customer tickets per day with 95 percent+ positive CSAT scores.”
  1. Keep what sounds like you
    Read each line out loud. If it sounds like something you would never say in a conversation, rewrite.
Example:
  • “Spearheaded cross functional initiatives to drive organizational excellence.”
    Change to: “Led a 5 person project team from sales, ops, and IT to launch a new ticket system.”
  1. Fix section headings
    AI tools often add fluffy sections:
  • “Professional Summary” with 4 lines of buzzwords.
  • Long “Skills” lists with 20 items.
Make it tighter:
  • Summary: 2 to 3 short lines max, focused on role, years, niche, and impact.
Example:
“Product manager with 5 years in B2B SaaS. Shipped 3 features that increased retention by 8 to 12 percent. Strong in user research and metrics.”
  • Skills: Only list tools and skills you would feel ok being quizzed on in an interview.
  1. Check length and structure
    General rule:
  • 0 to 7 years experience: 1 page.
  • 8+ years: 1 to 2 pages, but only if the content earns the space.
Sections order:
Name + title
Contact info
Summary (optional)
Experience
Projects (if relevant)
Education
Skills
  1. Tailor for each job
    Take the job posting. Highlight 5 to 8 key skills or responsibilities. Make sure those show up in your bullets and skills section, in similar wording.
Example from posting:
“Experience with SQL, dashboards, stakeholder communication.”
Then in your resume:
“Built weekly SQL based dashboards in Looker for 5 stakeholders in sales and finance.”
  1. Use a quick “human check”
    Ask a friend in your field, or post an anonymized version on the forum, with:
  • Your target role and level.
  • Your current resume.
  • One or two job links you target.
People give sharper feedback when they see the goal.
You did the right thing being skeptical of the AI version. Use it as a draft, not the final product. The more specific and concrete the bullets, the better your chances.
Short answer: the AI version is probably a decent draft, but not “send” ready.
I agree with a lot of what @mike34 said, but I’d actually start from a different angle: structure your resume around what you want next, not what the AI thought sounded fancy.
Here’s how I’d tackle it without repeating their steps:
  1. Start from the job postings, not the AI text
    Pick 2 or 3 roles you actually want and read them line by line. Ask yourself for each bullet on your resume:
  • “Does this help prove I can do that job?”
    If not, it’s either:
  • Deleted
  • Shortened
  • Or rewritten to connect to the target role
The AI tool probably tried to summarize your history. You need it to filter your history.
  1. Look for “who cares?” bullets
    Read each bullet and ask “So what?” like a grumpy hiring manager.
    Example bad:
  • “Collaborated with cross functional teams on various projects.”
    So what? Did you save time, money, customers, mistakes?
    If you can’t answer the “so what,” it either needs impact or needs to die.
  1. Keep some rough edges
    I actually disagree a bit with polishing everything into perfect corporate speak. A tiny bit of personality helps you stand out. Not jokes, not slang, but specific language that sounds like a real person.
    Example:
  • “Helped sales stop losing deals because our data was a mess”
    Then back it up:
  • “Cleaned and standardized 50k+ records, cut reporting errors by ~40% in 3 months.”
Still professional, but doesn’t read like it came from a template factory.
  1. Use role-based mini summaries inside experience
    Instead of a big fluffy “Professional Summary,” put micro context under each job:
    “Operations Coordinator | Focus on reducing manual work and fixing broken processes in a 10 person team.”
    Then bullets that prove you did that. It keeps things anchored to reality and less AI-ish.
  2. Look for “AI fingerprints” in verbs and structure
    AI loves the same verbs: “spearheaded, leveraged, facilitated, optimized, drove, executed.”
    You can keep a couple, but swap most for how you talk:
  • Led
  • Built
  • Fixed
  • Tested
  • Set up
  • Tracked
  • Wrote
    Much less robotic.
  1. Check if your timeline still makes sense
    AI sometimes rearranges or merges things in weird ways. Make sure:
  • Dates line up and there are no magical overlapping full-time jobs you never had
  • Job titles are accurate to what would be verifiable on LinkedIn or background checks
    If the AI “promoted” you in title to sound stronger, that can actually hurt you.
  1. Sanity test with one stranger
    Not a friend who loves everything you do. Someone who is:
  • In your industry or adjacent
  • Willing to be blunt
    Ask them two questions:
  1. “What role do you think I’m going for based only on this resume?”
  2. “What is the strongest thing about me based on what you read?”
    If they guess the wrong role or can’t name a clear strength, the AI generic-ified you too much.
If you want, paste 3 to 5 bullets (no personal info) that feel the most “AI-ish” and the job you’re aiming for, and folks here can help rewrite them into something that sounds like an actual human who does real work.
