Are Tech Influencers Ruining How We Evaluate Products?
I’ve noticed I keep second-guessing product reviews because so many tech influencers seem more focused on hype, affiliate links, and sponsorships than honest feedback. I recently bought a device based on popular YouTube and TikTok recommendations, and it did not live up to the praise at all. I need help figuring out how to spot trustworthy tech reviews, avoid biased influencer marketing, and make better buying decisions.
Yep. A lot of them are.
The issue is simple. Their money often comes from links, sponsors, early access, and staying friendly with brands. If they trash a product too hard, they risk losing access. That shapes the review, even when they act ‘honest.’
I treat influencer reviews like ads with extra steps.
What works better:
  1. Watch reviewers who show flaws fast.
  2. Look for long-term reviews, 3 to 6 months later.
  3. Read user forums, Reddit, Best Buy, Amazon 3-star reviews.
  4. Search for specific failure points. Battery drain, heat, bugs, warranty.
  5. Avoid buying on launch week. Let normal poeple find the problems.
  6. Check if the reviewer bought it or got a free sample.
  7. Compare 3 to 5 small creators, not one huge channel.
Big channels are often good for specs and demos. They are weak at telling you what living with the device feels like.
You got burned once, which sucks, but it teaches the right lesson. Use influencers for info, not decsions.
Yeah, kinda. But I don’t think influencers ruined product evalution by themselves. They just exposed how lazy most of us get when shopping. We want one entertaining person to save us 8 hours of research, and brands know it.
I mostly agree with @reveurdenuit, especially on using influencers for info, not decisions. Where I’d push back a little is this idea that big channels are automatically compromised and small ones are automatically real. Small creators can be even more desperate for clicks, freebies, and “hot take” engagement. Different incentive, same mess.
What changed for me was treating reviews less like verdicts and more like personality tests. Some reviewers care about cameras, some about gaming, some about aesthetics, some about repairability. If their priorities aren’t yours, even an “honest” review can send you straight into a bad buy.
Also, watch for what they don’t measure. If somebody spends 12 minutes on b-roll and 30 seconds on software stability, that tells you a lot. Same with vague praise like “feels premium” or “super fast” with no real comparison.
Honestly the best signal for me now is how a product holds resale value after 6 to 12 months. If people dump it fast, that usually means the honeymoon wore off real quick lol.
So yeah, influencers skew things, but the bigger problem is we started confusing content with testing. Those are not the same thing.
