I’m trying to play Pokémon Infinite Fusion on my Android phone but can’t figure out the best way to do it. I’ve tried downloading a few emulators, but nothing seems to be working. Can anyone guide me on the correct steps or recommend a reliable emulator? I really want to make this work and would appreciate any help or advice. Thanks!
I had the same issue awhile back, and I found a pretty decent way to get Pokémon Infinite Fusion running on Android. It’s a bit of a workaround so hang tight.
First off, Pokémon Infinite Fusion isn’t designed for mobile, so you won’t find a native Android app or ROM for it. Instead, you gotta run it through an RPG Maker emulator. The best tool I found for this is called JoiPlay. You can find it on the Google Play Store.
Here’s a step-by-step that should help:
Download and Install JoiPlay: Go to the Play Store and search for JoiPlay. Install both JoiPlay and its required plugin for RPG Maker games.
Get the game files on your phone: You need the actual game files. If you haven’t already, download Pokémon Infinite Fusion for PC from the official site or wherever it’s hosted. The file is usually a ZIP/RAR. Extract it on your PC first, then transfer the extracted folder to your phone’s storage. You can use a USB cable or a cloud service like Google Drive or Dropbox for this step.
Setup in JoiPlay: Launch JoiPlay. You’ll see a (+) button to add a new game. Tap that, enter a name for your game (like “Pokémon Infinite Fusion”), and navigate to the game folder you transferred in the previous step. Specifically, point it to the .exe file within the main game folder.
Play the Game: After setting it up, you should see the game listed in JoiPlay’s main menu. Tap it, and it should start right up!
A couple of tips: Make sure your phone has enough processing power and RAM, 'cause this setup can be a bit demanding. Also, if the game crashes or has performance issues, tinkering with JoiPlay settings or freeing up some phone resources usually helps.
Some people face issues with controls, though. If that’s a problem for you, consider getting a Bluetooth controller that works with Android. They can make gameplay way smoother, especially for games not designed for touchscreens.
This method works pretty well, but if JoiPlay doesn’t cut it for you, another alternative is to use an Android browser to access cloud gaming services like Parsec or GeForce Now. You set up everything on your PC and stream the game directly to your phone.
Hope this helps, and feel free to ask if you hit any snags!
Oh man, JoiPlay might work for some, but it’s not exactly foolproof. Like, yeah, it’s a clever workaround but the performance can be all over the place, depending on your phone specs and even the version of Android you’re using. Plus, tinkering with settings whenever something goes wrong? No thanks.
Honestly, I’m all about simplicity. If you’re already struggling with emulators, why not just keep it basic? Use a remote desktop app like TeamViewer or Microsoft Remote Desktop. Set up the game on your PC and just stream it to your phone. It’s way easier than dealing with JoiPlay quirks, trust me. Just make sure you have a solid internet connection.
Also, someone mentioned Parsec. That’s actually a pretty solid bet if you want better performance and fewer headaches. It’s basically a gaming-oriented version of remote desktop, and you won’t even need Bluetooth controllers. Just use your phone’s touchscreen as a kind of touchpad.
And let’s be honest, playing games meant for PC on a mobile is never going to be ideal, no matter what. Controls are awkward, and performance can lag unless you’re running top-tier hardware. Sometimes it’s just not worth the hassle. If you’re that desperate to play on the go, maybe look into the Switch’s Pokémon titles instead. At least they’re optimized for handheld gaming.
Alright folks, I see some solid advice from @techchizkid and @codecrafter, but I gotta say I’m surprised no one mentioned using Wine for Android. It’s a little more involved in the setup but offers more control and is often less clunky than the JoiPlay method. However, I’ve got a few different angles for you too.
1. Using Wine for Android
Wine is a well-known Windows compatibility layer that allows you to run Windows applications on Unix-like operating systems. And yes, there’s a version for Android too.
- Download Wine for Android: Head over to the WineHQ website and grab the latest .apk suitable for your architecture (usually x86 or ARM).
- Install Wine: Drag the .apk onto your device or use an OTG cable to transfer it from a USB. Enable ‘Install from Unknown Sources’ in your device’s settings and install the .apk file.
- Transfer Pokémon Infinite Fusion: Similar to the steps mentioned earlier, get the game’s files onto your device, either via USB cable, cloud storage, or even a larger SD card if applicable.
- Run Pokémon Infinite Fusion: Open Wine, navigate to where your game’s .exe file is stored, and start it up. This method might also involve a bit of trial and error, particularly with Wine settings, but it offers a lot more flexibility.
2. Streaming from PC with Moonlight
One thing both @techchizkid and @codecrafter kind of touched on is remote play, but let’s dig into one of the best tools for this - Moonlight.
Moonlight is an open-source implementation of NVIDIA’s GameStream protocol. Here’s how you can set it up:
- NVIDIA GPU Required: Ensure your PC has an NVIDIA GPU that supports GameStream.
- Install GeForce Experience: Download and install NVIDIA GeForce Experience on your PC. Enable GameStream within the application.
- Install Moonlight on Android: Download and install the Moonlight app from the Google Play Store. Ensure both your PC and phone are on the same network.
- Pair Moonlight with Your PC: Open Moonlight on your Android device, find your PC, and pair them by entering the given code on each device.
- Setup Pokémon Infinite Fusion: Add Pokémon Infinite Fusion to your list of streamable games in GeForce Experience. Launch the game through the Moonlight app on your phone.
This method provides incredibly low-latency streaming, even better than Parsec for some users. Plus, if you already have the NVIDIA setup, this is an easy add-on.
3. Android Virtual Space
While Wine or RPGMaker emulators are cool, running a full virtual environment can sometimes be the ultimate workaround. Apps like VMOS can run a virtual machine with Android on Android, which could then potentially be used to emulate a PC environment.
- Download VMOS: Find VMOS in the Google Play Store and install it.
- Setup Virtual Machine: Open VMOS and follow the setup instructions to create a virtual Android environment. This virtual Android could potentially run Wine, JoiPlay, or even PC emulators that couldn’t run directly on your host OS.
- Transfer Files and Install Game: Same steps as above, get the files into your virtual machine and set everything up there.
Additional Tips:
- Battery and Performance: Streaming or emulating this way can be battery-draining and heavy for performance. Make sure your device is well-charged or connected to power.
- Control Scheme: Using a Bluetooth controller is highly recommended. You can connect via Bluetooth settings and map the keys in-game for seamless play.
- Backup Your Progress: Regularly back up your game saves. Losing progress due to crashes or bugs can be a pain. Using cloud storage can help you maintain seamless gameplay across different setups.
Personally, I think the Moonlight method offers the best blend of performance and ease, especially for RPGs like Pokémon Infinite Fusion where reaction time isn’t hyper-critical. But if you’re a hands-on, DIY enthusiast, setting up Wine for Android gives more tweaking opportunities and less dependency on network performance.
It’s worth mentioning doing a bit of trial and error with the methods mentioned can be quite fun if you’re into tech tinkering, and you might even stumble across a new favorite setup.
Hope this helps some of you out there!
