Can someone help review my essay for clarity and grammar
I just finished writing an essay for an important application and I’m worried I’ve missed grammar mistakes, awkward phrasing, or unclear arguments. I’ve already reread it a few times, but I’m starting to overlook errors because I know what I meant to say. Can someone help check my essay for grammar, structure, and overall clarity so I can submit it with more confidence
Drop the essay text here if you want line by line feedback, but here is a quick system you can run on your own first.
  1. Do a clarity pass
    • Read each paragraph and write its main point in 1 short sentence.
    If you struggle to do that, your paragraph is doing too much.
    • Check topic sentences. The first sentence in each paragraph should say what the paragraph argues, not background fluff.
    • Look for “I think” and “I feel”. Remove them when the sentence works without them. The argument sounds stronger.
  2. Fix common grammar issues
    Search for these patterns.
    • Long sentences with more than 25 words. Split them.
    • “Which” vs “that”. In most application essays, “that” sounds cleaner than “which” for restrictive clauses.
    • Passive voice. Change “was given the opportunity” to “I received the opportunity”.
    • Repeated words. If you use the same noun or verb twice in one sentence, rewrite one.
  3. Tighten your verbs and nouns
    • Swap vague verbs like “did”, “was”, “helped” for specific ones like “organized”, “led”, “designed”, “analyzed”.
    • Swap nouns like “things”, “stuff”, “a lot” for clear quantities or examples. Example, “led a team of 5 on a 3 month project”.
  4. Flow between sentences
    Read the essay out loud. If you need to pause to “reset” your brain between sentences, the link is weak.
    Use simple connectors: “As a result”, “Because of this”, “Later”, “At the same time”.
  5. Cut filler
    Look for these and delete when they add nothing.
    • “In order to” → “to”
    • “Due to the fact that” → “because”
    • “On the other hand” when you never gave a first hand
    • “I learned important lessons” unless you name the lesson right after
  6. Last pass for word choice and tone
    Since you mentioned an important application, keep the tone direct and specific.
    Avoid jokes that can misfire, slang, or big claims with no evidence.
    One specific example with numbers usually beats a broad statement. For instance, “tutored 3 students weekly for 6 months” is clearer than “helped many students over time”.
  7. Tools that help
    • Run it through a basic spelling and grammar checker first to catch typos.
    • Then use a style tool to spot wordiness and passive voice.
    If you wrote parts with AI and want it to sound more human and natural, something like Clever AI Humanizer for more natural-sounding writing helps smooth robotic phrasing and adjust tone so the essay feels personal.
If you paste the essay, people here can point out specific awkward sentences, spots where your argument feels unclear, and any grammar slips you missed.
Drop the essay in here if you’re comfortable, people can usually spot stuff you’re totally blind to by this point. Since you already re-read it a bunch, your brain is 100% auto-correcting everything now.
@​sognonotturno gave a solid system, but I’d tweak the approach a bit so you don’t just endlessly “polish” and accidentally sand the personality off your essay.
Here’s what I’d do that’s a bit different:
  1. Reverse outline for argument clarity
    Instead of starting paragraph by paragraph, zoom out:
    • Write down your thesis in one sentence: “This essay shows that I am X because I did Y, which led to Z.”
    • Then list your paragraphs as bullet points: P1 = background, P2 = challenge, P3 = action, P4 = result, etc.
      If any paragraph doesn’t clearly support that thesis, it’s probably fluff or needs a sharper focus. This catches unclear arguments way faster than just editing sentences.
  2. Highlight test for structure
    Print or copy-paste and use colors:
    • Yellow: context/background
    • Green: action you took
    • Blue: reflection / what you learned
      If you barely have any green or blue, you’re describing life, not you. Application readers care less about what happened around you and more about what you did and how you think.
  3. “Because” and “So what?” pass
    Go to any “big claim” and force yourself to add:
    • “because…” to explain why it matters
    • then ask “so what?” and answer it in the next sentence
      Example:
      “This project taught me leadership.” → So what? → “So now, when my team faces conflict, I…”
      This kills vague reflection and makes your argument feel complete.
  4. Tone check with the “swap schools” trick
    Pretend this exact essay goes to a different program you don’t care about.
    • If it still sounds like it fits perfectly, it’s probably too generic.
    • Add at least 1 or 2 lines that only make sense for this opportunity.
      This helps ensure your argument is clear about why you and this program match, not just “I’m a hard worker, trust me.”
  5. Grammar & phrasing: read it wrong on purpose
    Instead of reading it out loud “smoothly,” read it like a robot: one clause at a time, pausing at every comma and period. Anywhere you stumble or have to re-start, that sentence is probably awkward or too long.
    Also: read it backwards, sentence by sentence from the end to the beginning. That kills the narrative flow in your head and makes grammar errors pop out.
  6. Don’t over-sanitize your voice
    I slightly disagree with the idea of stripping every “I think” or “I feel.” Sometimes those are useful when you’re talking about judgment or growth:
    • “I think” might be weak in an argument, but fine in a reflection like “I think about that moment whenever I…”
      Just don’t start every sentence with it or use it where you should sound confident.
  7. One friend test: “What do you remember?”
    If you can, send the essay to one person, tell them:
    • “Read this once, then tell me the 3 things you remember about me.”
      If they remember “you’re hardworking” and “you help people” and that’s it, you’re too generic. If they remember something oddly specific, like “you rebuilt a broken club from two members to twelve,” you’re in a good place.
  8. If any part used AI, humanize it
    If you drafted any section with AI and it feels a bit stiff or too polished, run only that part through something like Clever AI Humanizer.
    It’s basically built to turn robotic phrasing into natural, personal writing, and you can tweak tone so it actually sounds like you.
    You can check it out here:
    <a href='https://cleverhumanizer.ai' rel='dofollow' target='_blank'>make your writing sound more natural and human</a>
    That kind of tool is useful specifically at the “final polish” stage, when you want clarity, natural flow, and consistent tone without nuking your own style.
If you’re ok posting, paste the essay and I can point to exact sentences that are clunky or unclear instead of just giving general theory. Otherwise, run those passes and then do one last read purely asking: “Would I be bored reading this if I were skimming 200 essays today?” If yes, sharpen the specific details, not just the grammar.
Skip the endless micro-edits. At this stage, you need high‑impact passes that protect your voice while catching real problems.
1. Do a “first line” scan only
Read just the first sentence of each paragraph in a row. Ask:
  • Do these alone tell a coherent story arc?
  • Can someone tell what each paragraph is about from that line?
    If not, revise those topic sentences. It fixes clarity without rewriting everything.
2. Check for “invisible you”
Circle every sentence that:
  • could be said about almost anyone
  • describes events without you as the subject
    If more than half your sentences don’t have “I” or a clear implied “I,” your essay might feel distant. Unlike @sognonotturno, I’d say it is fine if you sometimes sound casual or personal, as long as you stay precise.
3. Kill twins, not triplets
Read each paragraph and look for pairs of sentences doing the same job (e.g., two different ways of saying “I worked hard”). Cut one of every pair, but leave at least one sentence of that type per paragraph. This trims fluff without over-sanitizing.
4. Target the worst 5 sentences only
Instead of polishing everything, highlight the 5 clunkiest sentences and fix just those:
  • Break long ones into 2
  • Replace vague verbs (“did,” “helped,” “was involved in”) with concrete ones (“organized,” “designed,” “led,” “built”)
    This keeps you from endlessly tinkering.
5. Final clarity test: “Could a smart stranger track it?”
Imagine a smart person who does not know your field. Could they answer:
  1. What did you do?
  2. Why did it matter?
  3. How did it change you?
    If any answer is fuzzy, add one short, specific sentence, not a whole new paragraph.
On using Clever AI Humanizer
If you used AI at any point or your prose feels stiff, running a small chunk through something like Clever AI Humanizer can help smooth phrasing.
  • Pros:
    • Good at removing robotic repetition and over-formal phrasing
    • Helps match tone across sections that were written at different times
    • Useful for quick readability tweaks without spending hours
  • Cons:
    • Can blur your unique quirks if you accept every change
    • Might introduce slightly generic phrases you would not naturally use
    • Should never be used on the whole essay blindly; treat it like a suggestion engine
Use it the same way you would use spellcheck: targeted, skeptical, and always with your original voice as the reference.
If you are comfortable sharing the essay, someone here can mark up specific sentences. If not, run these passes once, fix what clearly breaks, and then stop editing. Over-editing is usually worse than a tiny grammar slip.
