Can you help me choose the right CRM software for my small business?
I’m overwhelmed by all the CRM software options and online reviews. I run a small business and need a CRM that’s easy to use, affordable, and actually helps track leads and follow-ups without a lot of extra fluff. What CRM tools have worked best for you and why, and what should I watch out for before committing long-term?
I went through this same mess last year for a 5‑person shop. Here is what worked and what wasted time.
First, write down only what you need:
  1. Store contacts and companies
  2. Track leads, deals, and follow‑ups
  3. Simple pipeline view
  4. Email logging and reminders
  5. Easy for non‑tech folks
  6. Low cost per user
Ignore everything else. No marketing automation. No “AI insights”. No 20 dashboards.
Good options for a small business:
  1. HubSpot CRM (free + paid)
  • Core CRM is free for basic use
  • Clean UI, works for non‑technical users
  • Deals board is simple and fast
  • Email logging via Gmail/Outlook works well
  • Tasks and follow‑ups are easy to set
  • Add‑ons get expensive once you add automation or marketing features
  • Reporting on the free plan is limited
    Use this if you want something simple, start free, and you do not mind future upsell pressure.
  1. Zoho CRM
  • Cheap paid plans compared to others
  • Strong contact and deal tracking
  • Custom fields, workflows, decent reporting
  • Works if you grow and need more features later
  • Interface feels cluttered
  • Setup takes longer
    Use this if you want low cost and you do not mind a bit more setup complexity.
  1. Pipedrive
  • Built around a visual pipeline
  • Drag and drop deals, easy follow‑ups
  • Good for sales teams that only need leads and deals
  • Email sync works fine
  • Add‑ons raise price
  • Some features behind higher tiers
    Use this if you mainly care about pipeline and follow‑up, and less about marketing stuff.
  1. “CRM in your inbox” style options like Streak (for Gmail)
  • Lives in Gmail, no separate app
  • Simple pipelines for leads and deals
  • Good for solo or 2‑3 person teams
  • Only works with Gmail
  • Gets messy as you scale
    Use this if you live in Gmail all day and want the smallest learning curve.
Practical way to choose without losing your mind:
Step 1: Hard budget
Decide a max per user, per month. Example: 15–25 dollars per user. Remove anything above it.
Step 2: Non‑negotiables
For a small business, I would mark these as must‑have:
  • Pipeline board with stages
  • Deal and contact linking
  • Email logging and “next activity” or task reminders
  • Mobile app that is not trash
Step 3: 3‑day trial process
Pick 2 tools, not 10. I suggest HubSpot and Pipedrive first.
In each trial, do this:
  • Add 10 real leads
  • Create 5 deals and move them through 3 stages
  • Log emails from your real inbox
  • Set follow‑up tasks and see how reminders look
  • Check how fast each screen loads and how many clicks you need
If you can not do all of that in one short session without reading docs, the tool is too complex for your use case.
Rough picks by situation:
  • If you want free to start and light use: HubSpot free
  • If you hate clutter and like visual boards: Pipedrive
  • If you are very price sensitive and ok with more setup: Zoho CRM
  • If you live in Gmail and are solo: Streak
What I ended up with:
We started on HubSpot free. After 3 months, we paid for Pipedrive instead, because:
  • Pipeline view was faster to use
  • Follow‑up “activities” were clearer
  • Team needed fewer clicks per action
Cost was about 20 dollars per user per month, which was fine once we saw it stopped leads falling through the cracks.
Whatever you pick, lock in a simple workflow:
  • Every new lead goes into one pipeline stage
  • Every open deal has a next activity with a date
  • No deal stays “stale” for more than X days without touch
The CRM does not fix anything if the team does not follow that rule. The best one is the one your team really uses every day.
You’re not crazy, CRM land is actually that confusing.
I mostly agree with @voyageurdubois, but I’d add a slightly different angle: before tools, decide how disciplined your team really is. That matters more than free vs paid.
A few quick, non‑fluffy picks and how they feel in daily use:
1) HubSpot CRM
Good if you:
  • Want something your team will “get” in 30 minutes
  • Are ok living inside a browser all day
  • Plan to maybe add marketing later
What people underrate: the Chrome extension + email logging is actually solid. What I don’t love: once you want “just one more” feature, pricing jumps fast. If you’re extremely cost sensitive long term, that can sting.
I’d only pick HubSpot if:
  • You’re fine with eventually paying
  • You want a polished UI and don’t want to fiddle with settings much
2) Pipedrive
This is usually my top rec for exactly your use case: track leads, follow‑ups, simple pipeline, no circus.
Pros in real life:
  • Sales people actually use it because the pipeline is just drag & drop
  • “Next activity” feature quietly forces follow‑ups without nagging
  • Decent mobile app for quick notes after calls
Downsides:
  • Can get pricey once you tack on extra add‑ons
  • Reporting is “good enough,” not amazing
If your main pain is “I keep forgetting to follow up,” Pipedrive fits better than HubSpot in my experience. Here I slightly disagree with the “start free on HubSpot” idea: if you already know you’ll use a CRM daily, it can be better to start on the paid tool you’ll keep instead of migrating in 3–6 months.
3) Zoho CRM
Cheap and flexible, but honestly, for very small teams it can feel like using Excel with opinions. Powerful, yes. Friendly, not really.
I’d only choose Zoho if:
  • You’re okay poking around settings for a few hours
  • You like customizing fields and views
  • Money is tighter than time
4) Streak (if you live in Gmail)
If your browser is 90% Gmail all day, Streak turns your inbox into a light CRM.
Nice when:
  • It’s just you or a tiny team
  • You don’t want “one more app”
Breaks down when:
  • You need better reporting or multiple pipelines across teams
  • You ever move off Gmail
Super simple decision fork
Forget 10‑tool spreadsheets. Use this:
  1. Do you rely on Gmail and hate extra tools?
    → Try Streak.
  2. Do you want visual pipeline, minimal fluff, ok with $15–$25/user?
    → Go Pipedrive first.
  3. Do you absolutely want to start free, might add marketing later, and are fine with upsell emails?
    → Go HubSpot CRM.
  4. Is your #1 criteria “cheapest decent thing” and you can handle a learning curve?
    → Zoho CRM.
One thing I’d do differently from @voyageurdubois
They suggest picking 2 tools and doing a 3‑day trial. That works, but I’d actually:
  • Pick 1 tool to start
  • Use it seriously for 2 weeks with real leads
  • Only switch if:
    • Your team is actively avoiding it
    • You cannot easily see “who needs a follow‑up today”
People burn more time jumping between trials than they ever save by “perfectly” choosing.
Final blunt filter:
If your team is not very organized:
  • Pick Pipedrive. It forces a bit of discipline.
If your team already runs on spreadsheets and is fairly organized:
  • Start HubSpot free, upgrade or migrate later if you hit walls.
Doesn’t have to be more complicated than that.
You already got solid, tool‑by‑tool breakdowns from @ombrasilente and @voyageurdubois, so I’ll skip rehashing their checklists and come at it from a different angle: what usually goes wrong for small teams picking a CRM.
1. Decide “where your CRM lives”
This matters more than people admit:
  • If your team lives in email:
    Streak and similar “CRM in Gmail” tools feel natural.
  • If your team lives in the browser already (Docs, web apps, etc.):
    HubSpot, Pipedrive, Zoho fit better.
  • If most work is on the road / phone:
    Weight the mobile app almost as heavily as the web UI.
Both @ombrasilente and @voyageurdubois focused on features and cost. I’d slightly disagree with starting from budget only. A $10 cheaper tool that your team barely touches is a hidden cost.
2. Three things I’d test before you commit
Whatever you trial, ignore advanced stuff and test these:
  1. How fast can you add a new lead while on a call?
    Time it. If it takes more than ~20–30 seconds, your team will revert to sticky notes.
  2. How obvious is “who do I call today?”
    You should have a single view that answers this without digging through filters or reports.
  3. What happens if someone is lazy?
    Good CRMs quietly nudge with “overdue” activities, badges, or a simple “no next step set” warning.
If a CRM passes those three tests, it is already in the top 10 percent for a small shop.
3. Why you might not want the most popular choice
  • HubSpot CRM:
    Great UX, strong ecosystem. But if you absolutely know you will never do marketing automation or fancy stuff, all that potential can turn into clutter and upsell noise. For a tiny team that just wants a follow‑up machine, it can start to feel like a hotel lobby for one guest.
  • Zoho CRM:
    Incredibly capable for the price. I agree with the others that it is good for budget and growth, but for a non‑techie crew, the menus and options can be overwhelming. You might spend more time taming it than using it.
  • Pipedrive:
    Super strong for simple pipelines. Where I disagree a bit with the “just start on Pipedrive” stance: if your sales volume is low and your cycles are long, a full pipeline CRM can be overkill. In that case, a lighter, inbox‑centric tool often wins.
4. About the product title: ‘’
Since you mentioned it, quick pros and cons of the ‘’ in this context:
Pros
  • Focused feature set that does not drown you in modules
  • Typically simpler onboarding for small teams compared with heavyweights
  • Better fit if you want to track leads and follow‑ups without complex marketing layers
  • Less brand recognition than HubSpot or Pipedrive, so fewer tutorials and community tips
  • Integration ecosystem is usually smaller, so if you rely on niche tools you might hit limits
  • Reporting and automation may feel basic compared with Zoho CRM or Pipedrive once you scale
Basically, ‘’ makes sense if you want an affordable, stripped‑down CRM that stays close to your original requirements and you are okay not having a huge app marketplace behind it.
5. How I’d narrow it, given everything already said
Taking into account what @ombrasilente and @voyageurdubois laid out, plus the above:
  • If your main fear is “lots of fluff and confusion”:
    Lean toward Pipedrive or ‘’ and keep configuration minimal.
  • If your main fear is “hidden cost creep”:
    Lean toward Zoho CRM or ‘’ and accept a bit more setup work.
  • If your main fear is “the team ignores it”:
    Prioritize the tool that feels most like where they already work:
    • Email centric → Streak
    • Web app centric → HubSpot or Pipedrive
    • Minimalist and cheap → ‘’
One last note: it is better to pick a “good enough” CRM and lock a simple daily habit than to find the “perfect” platform. In practice, the team discipline you build around it beats almost any feature list.
