I’ve been bombarded with Temu ads on my iPhone recently, and they’re getting really annoying. I’ve tried tweaking some settings, but nothing seems to work. Can anyone share any effective methods or apps to block these ads? Any advice would be greatly appreciated!
Blocking ads on an iPhone honestly feels like a never-ending game of whack-a-mole. You might get rid of one type, and then five more pop up. For Temu ads, you could start by making sure you’ve turned off personalized ads. Go to Settings > Privacy > Apple Advertising and turn off Personalized Ads. That should reduce some of the ads, although Apple will still throw random ones at you.
You could also try a content blocker like ‘’ on Safari. They’re not bad, but honestly, they aren’t a silver bullet. Pros: They can block a lot of annoying ads on websites you visit. Cons: They don’t touch apps, so Temu ads within apps remain untouched. Plus, they sometimes mess with website layouts.
As a next step, you might have to dig into app permissions – Settings > Notifications – and silence or turn off notifications for any apps that seem to push ads. Look into other ad blockers like ‘’ or ‘’ but good luck because they each have their shortcomings. Some don’t even touch in-app ads, which is where Temu might be hitting you hard.
Oh, and ad blockers can slow down your browsing. So basically, there’s no perfect solution. I feel your pain, but unless Apple decides to crack down on ads for real, we’re all kinda stuck with this nonsense.
If we’re talking about effectively blocking Temu ads on an iPhone, honestly, a content blocker alone won’t cut it. Even with stuff like AdGuard or 1Blocker, they mostly only handle web ads. @techchizkid got it right about these blockers not touching in-app ads. It sucks, but that’s the reality.
For a more robust solution, you might need to combine several tactics. Firstly, you could try limiting specific app tracking across your whole device. Go to Settings > Privacy > Tracking, and toggle off “Allow Apps to Request to Track.” Sure, it’s more general, but it might reduce the overall targeting ads including those from Temu.
Another angle is to check the individual app settings. Some apps sneak in advertising via notifications. Head to Settings > Notifications, find the app in question, and either limit its notification types or turn them off completely. This won’t block the ads, but at least you won’t be disturbed by annoying pop-ups constantly.
Additionally, dive into the in-app settings of any app showing the ads. Look for anything that mentions ads or promotions. Some apps bury these settings pretty deep, but toggling them off can sometimes make a big difference.
Also, consider trying a different browser entirely. Browsers like Firefox or Brave have stronger ad-blocking mechanisms built-in compared to Safari. They’re not perfect, but they might give you an edge in one part of the battle.
If you’re seeing ads inside random apps, paid versions or subscriptions can often be an antidote, albeit not a free one. It’s just another way companies are getting us to dish out more cash. Sometimes it’s worth it, sometimes not so much.
Lastly, something people don’t discuss a lot: VPN services like NordVPN or ExpressVPN often come with ad-blocking capabilities. They can filter out some ad traffic that DNS-based blockers miss. But remember, VPNs can slow down your connection, similar to the content blockers messing up site layouts.
In the end, there’s no silver bullet. You kind of have to cobble together a patchwork of solutions. And if you find something that works better, circle back and share the wisdom! This battle against ads is kinda never-ending, huh?
Ah, the eternal struggle against the endless barrage of ads. It’s like we can’t catch a break. I get what @codecrafter and @techchizkid are saying about fighting ads being like playing whack-a-mole, and while they’ve got some solid points, I’ve got a different take on this ad-blocking dilemma. First off, I won’t disagree that personalized ads need to be turned off and content blockers have their place, but here are a few other strategies you can try:
Start with DNS-based Ad Blocking
One way that’s often overlooked is DNS-based ad blocking. Essentially, you change the DNS service on your iPhone to an ad-blocking DNS provider. This won’t block everything, especially in-app ads, but it’s a broader net compared to browser-only solutions. Here’s a quick way to do it:
- Open Settings → Wi-Fi.
- Tap the info icon next to your connected Wi-Fi network.
- Scroll down to Configure DNS.
- Select Manual.
- Remove the old DNS servers listed and add a custom one. Providers like AdGuard DNS (176.103.130.130 and 176.103.130.131) or NextDNS (45.90.28.90 and 45.90.30.90) are good places to start.
Try System-wide Ad Blockers
Apps like AdGuard Pro offer system-wide ad-blocking capabilities. These apps work by creating a local VPN on your device that intercepts and filters ad traffic. Here’s what to do:
- Download AdGuard Pro from the App Store.
- Open the app and configure the VPN profile.
- Enable system-wide ad filtering.
- Customize filters as needed for optimal performance.
Control Background Activity
Ads often sneak in through apps that run incessantly in the background. Go to Settings → General → Background App Refresh. Turn off background refresh for apps you suspect might be responsible for ads.
Tweak App-specific Settings
Dig into the app settings themselves. Many apps give you the option to limit or completely turn off ads. It’s usually buried under privacy settings or notifications.
Brave Browser – A Stronger Alternative
Instead of relying solely on Safari, consider switching to a more ad-resistant browser like Brave. It’s known for its robust ad-blocker and tracker protection. Here’s how you can get started:
- Download Brave Browser from the App Store.
- Open Brave and configure the built-in ad-blocker.
- Set Brave as your default browser via Settings.
Utilize VPN with Ad-Blocking Features
Some advanced VPNs, such as Windscribe or NordVPN, come with built-in ad-blockers. Here’s the setup:
- Subscribe to NordVPN.
- Enable the CyberSec feature, which blocks ads and malicious websites.
- Connect your VPN to start blocking ads.
Custom Privacy Configurations
You can use custom configurations to extend the blocking. This involves more technical tweaking but here’s how:
- Install a configuration profile. You can create one using tools like Apple Configurator.
- Use the profile to restrict certain URLs known for serving ads.
- Deploy the profile on your iPhone.
Final Resort - Reporting and Deleting Apps
If you pinpoint the apps consistently throwing ads, report them.
- Open the App Store, search for the app.
- Scroll down to the Ratings & Reviews section, tap Write a Review.
- Detail the issue regarding persistent Temu ads.
- If it’s unbearable, uninstall the app.
Realities to Manage Expectations
Combining these multiple methods can sometimes mitigate, but not entirely eliminate, ad bombardment. Remember, ad networks are constantly evolving, and they often find new ways around blocking mechanisms. It’s an ongoing chase, but with these strategies, you should manage to reduce the volume significantly.
So yeah, there’s no one-click solution, but by layering these tactics, you can make your iPhone a little less ad-infested. Good luck, and if you find new tricks, do share!
Try advertiser opt outs and mutes. Simple, no VPN or DNS.
- Instal AppChoices from the App Store. Open it adn run Opt Out for all companies. It covers dozens of ad networks.
- Facebook and Instagram. Tap three dots on a Temu ad. Hide ad. Hide all ads from this advertiser.
- YouTube. Tap three dots on the ad. Stop seeing this ad. Mute Temu.
- TikTok. Long press a Temu ad. Not interested.
This targets Temu across major apps fast. You see fewer Temu ads within 24 hours. Repeat hides if Temu pops back.
