My home wifi signal drops in a few rooms, especially upstairs and on the back patio. I’m thinking about getting a wifi range extender but I’m confused by all the options and reviews. What should I look for to get better coverage, avoid slow speeds, and make sure it works with my existing router?
First thing, make sure the problem is weak signal from the router, not a bad internet line.
Quick checks:
- Stand next to the router with your phone or laptop.
- Run a speed test.
- Go to the bad room, run the same test.
If speed drops a lot and WiFi bars drop, a range extender or mesh makes sense.
Key stuff to look for with a WiFi extender:
Same WiFi standard as your router
If your router is WiFi 5 (802.11ac), get a WiFi 5 extender.
If router is WiFi 6 (802.11ax), match it.
Mixing old and new standards often wastes money. -
Dual band at minimum
Get 2.4 GHz and 5 GHz.
Avoid cheap single band extenders.
5 GHz gives better speed, 2.4 GHz reaches farther.
Good extenders use 5 GHz as backhaul to the router, then broadcast both. -
Placement matters more than brand
Do not put the extender in the dead zone.
Put it about halfway between router and weak area, where your device still shows 2 to 3 bars from the main router.
If you place it in a room with 1 bar, it repeats a weak signal, so everything stays slow. -
Ethernet backhaul is king
If you have ethernet in the house, or can run a cable, use an “access point mode” extender.
Plug extender to router with ethernet, disable its extender mode, use it as a second WiFi access point.
This gives much better speed than repeating over WiFi. -
Consider mesh instead of a basic extender
Traditional extenders:
- Often cut speed in half on the repeated network.
- Give you a second SSID like “HomeWifi_EXT” so you keep switching networks.
Mesh systems:
- Single network name across the house.
- Better roaming between floors.
- Designed for multiple nodes from day one.
If your home is 2 floors and patio, a 2 or 3 node mesh kit often beats a random extender stuck in a wall.
- For upstairs and patio in particular
- Place the router as central as possible, not in a corner of the house.
- Avoid placing it in a closed cabinet or behind a TV.
- For upstairs, put the extender roughly above or below the router.
- For patio, try an extender near the wall closest to the patio, not out on the edge of the house.
Use a WiFi survey tool before you buy
Instead of guessing, map your signal.
Install NetSpot on a laptop, walk around the house, and create a quick signal heatmap.
A tool like WiFi analyzer and coverage optimizer helps you see where the signal drops and where an extender or mesh node should sit. -
What specs to ignore a bit
- “AC1200 / AC1900 / AX1800” marketing numbers. They are total bandwidth, not what you get in real life.
- Crazy antenna designs and “high gain” buzzwords.
Focus on: - WiFi 5 or WiFi 6
- Dual band or tri band
- Ethernet port for access point mode
- Good placement
Simple buying plan:
- On a tight budget, get a dual band WiFi 5 extender with an ethernet port, use it in AP mode if possible.
- If you want it to just work everywhere, replace router plus extender idea with a 2 or 3 node mesh system.
- Use NetSpot once before and once after to see that your upstairs and patio signal improved.
If your current router is from your ISP and sits in the worst spot in the house, replacing or moving that box often helps more than any fancy extender.
If your WiFi dies upstairs and on the patio, a range extender can help, but it’s super easy to buy the wrong thing and make it worse.
@andarilhonoturno already covered the basics (match WiFi standard, dual band, placement, mesh, etc.), so I’ll add stuff that usually gets skipped:
1. Check if a range extender is even the right tool
Everyone jumps to “buy extender,” but sometimes:
- Your ISP router is garbage
- The router is in a terrible spot (corner, basement, closet)
- 2.4 GHz is overcrowded from neighbors
Before buying an extender, log into the router and:
- Change WiFi channel on 2.4 GHz (try channels 1, 6, or 11)
- Turn OFF “auto” channel if it keeps jumping around
- Turn ON both 2.4 GHz and 5 GHz if only one is enabled
If small tweaks fix the patio and most of upstairs, an extender might just be a band‑aid you don’t need.
2. Prioritize this over fancy marketing
When you look at extenders, focus on:
Roaming support / 802.11k/v/r
This helps your phone smoothly switch between router and extender. Without it, your phone clings to the weak signal until it’s unusable. Most reviews don’t mention this at all. -
Same brand as your router if possible
I slightly disagree with the “brand doesn’t matter” idea. For pure signal strength, sure, physics is physics. But for roaming and stability, matching brands can help, especially if they support a “one WiFi name” or “mesh-like” mode between router and extender. -
Dedicated backhaul on tri-band extenders
If you don’t want full mesh but still want decent speed, look at tri-band extenders where one 5 GHz band is just for talking back to the router. It avoids the “half speed” issue of basic extenders.
3. For your layout in particular
Upstairs + back patio is a classic “router is stuck on one side of the house” situation.
Try this order:
- Move the router as close to the center of the house as your cables allow. Even 6–10 feet can change upstairs coverage.
- If you buy one extender:
- Put it roughly between router and stairs (for upstairs focus)
- Or midway between router and the wall closest to the patio
- If you care more about patio streaming / music, prioritize that wall placement
- If upstairs and patio are on oppisite sides, a single extender is often not enough. That’s where I’d skip straight to a 2‑ or 3‑node mesh, even if reviews for extenders look cheaper and tempting.
4. Ignore useless stuff, but not all of it
@andarilhonoturno is right that “AC1200 / AX1800” numbers are marketing, but I wouldn’t ignore them totally. Use them like this:
- Don’t pay extra just to jump from AC1200 to AC1750 in a small house
- Absolutely avoid anything below AC750 or old “N” extenders
- For multiple people streaming upstairs + patio, AC1200/AX1800 is a sane baseline
Weird “8Dbi mega antennas!!!” is mostly nonsense. What matters is where you place the thing and how it talks back to the main router.
5. Use a WiFi survey tool instead of guessing
This is where most folks just wing it and then write bad reviews.
Install NetSpot on a laptop or desktop, walk around your home, and you’ll literally see where the signal falls off. It makes choosing extender spots way easier.
You can grab it on their site here:
analyzing and improving your WiFi coverage
Run it:
- Before buying, to see how bad upstairs and patio really are
- After installing the extender, to verify that you actually improved coverage instead of just moving the dead zones
6. When a new router beats any extender
If your ISP router is:
- Older than 5 years
- Stuck on WiFi 4 / 802.11n
- Sitting next to a metal cabinet or giant TV
Then spending on a new main router with strong radios + better antennas is sometimes smarter than stacking extenders on a weak base. A good WiFi 6 router in a decent location + one extender (or one extra access point) usually beats a bad router + multiple repeaters.
7. Quick buying checklist for your case
For upstairs and patio:
- WiFi 5 or WiFi 6 extender
- Dual band minimum, tri-band if you want better speeds
- Ethernet port in case you ever run a cable and turn it into a full access point
- Same WiFi standard and ideally same brand as router
- Support for seamless roaming if you hate your phone sticking to the wrong signal
If you find you’re about to buy two extenders, strongly consider a 2‑ or 3‑node mesh kit instead. One purchase, cleaner roaming, less headache.
And yeah, reviews are a mess because half of them are people who put the extender literally in the dead zone and then complain it’s slow. Do yourself a favor and use NetSpot, move the router a bit if you can, then pick a dual‑band or tri‑band extender that supports your router’s WiFi version.
Skip the extender for a second and zoom out: your “whole system” matters more than any single gadget.
1. Start with your layout strategy
Given you have upstairs + patio issues, think in zones:
- Zone 1: Router floor, near center of the house if possible
- Zone 2: Vertical coverage (upstairs) directly above or below the router
- Zone 3: Horizontal push toward the patio
One extender placed smartly usually covers either Zone 2 or Zone 3 well, not both. If those are on opposite sides, that is where a lot of “extenders suck” reviews come from. In that case, two nodes (mesh or router + wired AP) is far more realistic.
I slightly disagree with the idea that matching WiFi standard is always crucial. In practice, a well placed WiFi 5 extender on a WiFi 6 router can outperform a badly placed WiFi 6 extender. Position and backhaul beat protocol version most of the time.
2. Use tools, but treat results like hints, not laws
Both @mikeappsreviewer and @andarilhonoturno already mentioned surveying, and they are right. Where I’d extend that:
- Use something like NetSpot not only for signal strength but also for noise and overlapping networks. That tells you when 2.4 GHz is basically a parking lot jam and 5 GHz is the only sane lane.
- Do one quick survey with doors open and closed, especially for upstairs bedrooms and the door to the patio. Closed doors can block more than you expect.
Pros of NetSpot:
- Clear visualization of weak spots and interference
- Helps you pick extender / mesh node locations with actual data
- Makes it easy to compare “before” and “after” changes
Cons of NetSpot:
- More useful on a laptop than a phone, so a bit less convenient
- Can overwhelm beginners with all the metrics unless you stick to the basics (RSSI and noise)
You do not need to obsess over every graph. Use it to answer just two questions: “Where is the main dropoff?” and “Did my fix actually help?”
3. Choose between extender, wired AP, or mesh based on how you use the space
Instead of “what is the best device,” ask “what traffic lives where”:
- Mostly web browsing upstairs, streaming on patio: a single solid dual band extender placed between router and patio, vertically aligned for upstairs, can work.
- Gaming upstairs, video calls, and streaming on patio at the same time: that starts to argue for either
- a wired access point upstairs (if you can run cable) or
- a 2 or 3 node mesh.
A lot of people underestimate how bad “repeat over WiFi and share that same band with clients” can get when multiple devices are busy. That is where mesh with dedicated backhaul or a simple wired AP wins.
4. Avoid the trap of chasing “perfect roaming”
Both other posts touched on roaming features like 802.11k/v/r and brand matching. Helpful, yes, but here is the catch:
- Many phones still make poor roaming decisions even with those standards.
- For a typical house, the biggest jump in experience is going from “barely any signal in that room” to “decent signal,” not from “okay handoff” to “perfect handoff.”
So if extending coverage means you end up with two SSIDs (like “Home” and “Home_Upstairs”) and you need to occasionally flip manually, that might be a small price for solid speeds everywhere. Perfect roaming is nice, not mandatory.
5. Where I would put hardware in your scenario
If you keep a single router plus one add‑on:
- Router: as central and high as your wiring lets you. Avoid floor level and metal clutter.
- Add‑on device:
- Priority upstairs: place the device on the floor below, roughly under the central upper hallway or stair landing.
- Priority patio: place it near the wall that faces the patio, as close to the middle of that wall as your outlet and furniture allow.
If you catch yourself wanting to buy two cheap extenders, stop and price out an entry mesh kit instead. Even a budget mesh often outperforms a Frankenstein stack of extenders.
6. Mental checklist before you click Buy
- Do I know where my big weak spots are from a quick NetSpot pass, not just guessing?
- Can I move the router even a little closer to the center or higher up?
- Is one device supposed to fix two opposite directions (upstairs and far patio corner)? If yes, reconsider and maybe plan for two nodes instead of one extender.
- Am I okay with “good coverage everywhere” even if roaming is not perfect, or do I specifically care about walking around on calls?
@mikeappsreviewer and @andarilhonoturno already nailed the technical fundamentals. The extra win now is in treating your house like a small network design project: map it with NetSpot, decide which zones truly matter, then pick extender / AP / mesh based on how heavily you use those areas.
Try a powerline Wi-Fi kit. It sends your internet conection through your home’s electrical wiring.
Plug one adapter beside the router and connect Ethernet. Place the Wi-Fi adapter upstairs or near the patio. Choose G.hn or HomePlug AV2, gigabit Ethernet, and a solid return policy.
Plug adapters directly into wall outlets, never surge protectors. Performance varies between electrical circuits, so test speeds before keeping it. This avoids extender placement and weak wireless backhaul.
Patio coverage is the part that quietly wrecks these plans, and nobody upstream really flagged it. Outdoor signal behaves nothing like a spare bedroom. You’ve got an exterior wall (often brick, stucco, or foil-backed insulation) plus open air with no walls to bounce the signal back to you. An extender parked in the living room can look great on paper and still die two steps past the sliding door. If the patio matters to you, the realistic fix is a node near the wall that faces it, or an actual outdoor-rated access point, not a repeater buried inside the house.
On the powerline idea from @cloudworks8444, it can work, but I’d temper expectations for the patio specifically. Patio and outdoor outlets are frequently on a different circuit or behind a GFCI, and powerline throughput tanks the moment the two adapters aren’t on the same run. Great for a fixed spot upstairs, iffy for anything outdoors. Test it and keep the receipt like they said.
The survey advice earlier is solid, and NetSpot is fine for spotting where the drop happens indoors. Just know it maps what your laptop can reach, so for the patio you’ll be walking outside with the laptop to get real numbers rather than reading a heatmap from the couch. Use it to confirm the weak spot, then decide between one well-placed node or two. If upstairs and patio are on opposite ends, one extender chasing both is the setup that generates all those angry reviews.
