How Can I Change the Channel Without a Remote?
I lost my TV remote and now I can’t figure out how to change channels. The buttons on the TV are limited, and I need a quick way to switch channels without buying a new remote right away. Looking for easy ways to change TV channels without a remote.
Misplacing the remote sucks, but you still have a few solid options.
Start with the TV itself. I’d check the edges first, then the back panel, then underneath. A lot of sets hide the controls there. Sometimes you get a row of buttons, sometimes one small joystick-looking nub. It’s clunky, yeah, but it works for volume, input, and channel changes when you’re stuck.
If your TV is a smart TV, I’d skip the button hunt and use a phone instead. This is usually the part people miss: your phone and the TV need to be on the same Wi-Fi network. I’ve seen people spend 20 minutes thinking the app was broken, then notice the phone was on cellular or a guest network. Check that first.
The app I’d use is TVRem remote app.
I tried stuff like this before and some remote apps felt half-baked. This one seems more usable. Once both devices are on the same Wi-Fi, you open the app and the phone turns into a full remote. You get channel controls, volume, guide access, and the usual navigation.
What stood out to me is the brand support. It works with Samsung, LG, Roku, Fire TV, Android TV, Google TV, and Apple TV. So if your place has a mix of TVs and streaming boxes, you’re not juggling three different apps. It also avoids the annoying parts a lot of these apps shove in your face. No subscription wall, no constant ads, and typing is easier since you use your phone keyboard instead of clicking across the TV alphabet one letter at a time. Voice search helps too.
For anyone who checks reviews before installing anything, it’s sitting at 4.8 stars across a few thousand ratings, which at least tells me it’s not some random abandoned app. More info: https://mac.eltima.com/tvrem-universal-tv-remote/
Small catch. Phone remote apps depend on the TV being a smart model with Wi-Fi support. If your set is older and not connected like that, I wouldn’t waste time fighting it. Use the built-in buttons or pick up a cheap universal remote and call it done.
If you share the TV brand or model, I can help narrow down which route makes sense.
One more route besides what @mikeappsreviewer listed.
If you have a cable or satellite box, use its front panel. A lot of boxes still have CH up/down buttons, or at least a menu and arrow keys. Same idea for a DVR. Changing the channel on the box matters more than the TV if you watch live TV through it.
If your provider has an app, use it. Xfinity, Spectrum, DirecTV, Dish, and others let you change channels or cast live TV from your phone. It’s not perfect, but it works in a pinch.
Also check if you have HDMI-CEC turned on. On some setups, a streaming stick remote changes TV input and controls basic navigation. People forget this and keep hunting for the TV remote for no reason, lol.
If none of that works, grab a used universal remote from a thrift store or walmart bin. Faster than fighting hidden TV buttons for 2 days striaght.
One workaround I don’t see mentioned by @mikeappsreviewer or @codecrafter is using the channel number directly from another paired device.
If you have a game console, Blu-ray remote, soundbar remote, or even some keyboard remotes plugged into the TV or streaming box, try the directional pad and number keys there. A surprsing number of TVs accept basic commands from USB or HDMI accessories, especially if you’re already on live TV. Not elegant, but it can save you.
Also, if your TV has voice control built in, try saying “channel up” or “go to channel 7” near the set itself. Some newer Samsungs, LGs, and Fire TVs listen hands-free if that feature was enabled before. People forget this exists becuase nobody uses it until the remote vanishes.
If it’s an antenna setup, another annoying-but-real option is to re-run channel scan and use the last-channel or favorites shortcut from the TV menu. Kinda clunky, yeah, but better than being stuck on one station forever.
A couple options the others did not really dig into:
  1. Hotel mode / lock mode check
    Some TVs have channel controls disabled in settings, especially older LG, Philips, and budget sets. If the side buttons seem useless, try holding Menu or Input on the TV itself for 10 to 15 seconds. On some models that unlocks fuller controls.
  2. Use the TV’s web interface
    A few smart TVs expose control through a browser on your local network if network remote was enabled before. Type the TV’s IP into your phone browser. Not common, but worth trying if the set shows network info in settings.
  3. External tuner shortcut
    If you use an antenna, a cheap digital tuner box can be a temporary workaround. You leave the TV parked on one HDMI/input and change channels on the tuner instead. Honestly, this is less annoying than fighting hidden TV buttons.
  4. CEC can be flaky
    I slightly disagree with @codecrafter on HDMI-CEC being a reliable fix. It helps sometimes, but brand-to-brand behavior is messy. Great when it works, weird when it doesn’t.
As for @techchizkid and @mikeappsreviewer, the phone-app route is valid if your TV is already on Wi-Fi. TVRem remote app is one option.
Pros for TVRem remote app: easy setup, phone keyboard is faster, can replace multiple remotes.
Cons for TVRem remote app: useless if the TV is offline, older non-smart TVs may not work, setup can fail on guest Wi-Fi.
If you want the fastest no-remote move, I’d check for a hidden joystick button first, then borrow any universal remote before spending time on edge-case tricks.
