How can I disable WiFi calling on my phone?
I’ve been having trouble with call quality and suspect WiFi calling might be the issue. Calls are dropping frequently, and I’d like to turn off WiFi calling to see if it helps. Can someone guide me through the steps?
First off, sorry to hear you’re having trouble with call quality. It can be super annoying when calls keep dropping! Disabling WiFi calling might help, so it’s definitely worth a shot. Here’s a quick guide on how to disable it, but keep in mind the exact steps might vary a little depending on your phone model and carrier.
On iPhone:
  1. Open the Settings app.
  2. Scroll down and tap on Phone.
  3. Tap on Wi-Fi Calling.
  4. Toggle off Wi-Fi Calling on This iPhone.
On Android:
Here’s where it can get a bit tricky because different manufacturers have slightly different interfaces. I’ll give you general steps and you might have to tweak them a bit based on your specific phone.
For Samsung Devices:
  1. Open the Phone app.
  2. Tap the three dots in the top right corner to open the menu.
  3. Go to Settings.
  4. Find and tap on Wi-Fi Calling.
  5. Toggle the switch off.
For Google Pixel:
  2. Tap on Network & internet.
  3. Find and tap on Mobile network (it might be under a section like SIMs or Advanced).
  4. Toggle off Wi-Fi Calling.
For Other Android Devices:
  2. Tap on Connections or Network & internet.
  3. Find Wi-Fi Calling and toggle it off.
If you still have issues with calls dropping after this, you might want to try a couple of other troubleshooting steps like restarting your phone or checking for any available software updates. Also, it could be a signal strength issue, so make sure you’re in an area with good cellular coverage.
Interestingly, some users find that switching carriers can significantly improve call quality, as coverage and support for features like WiFi calling can vary greatly. Another tip is to use a third-party app for calls, like WhatsApp or Skype, at least temporarily, to see if call quality improves.
Sometimes, simply resetting your network settings can help too. This won’t erase any of your data, but you’ll have to re-enter Wi-Fi passwords and possibly reconnect Bluetooth devices.
I hope this helps! If you encounter anything unusual or it doesn’t seem to work, feel free to ask back here.
Disabling WiFi calling isn’t always a fix-all solution. Even if you turn it off, u might still face call drops if it’s a weak network issue. Be prepared for calls switching to cellular - might get worse if the coverage’s spotty in your area.
What codecrafter didn’t mention is that some phones have buried settings, especially in carrier-branded phones. Sometimes, WiFi calling might be under some weird sub-menu or hidden under advanced network settings. You might spend more time searching for it than actually fixing your issue. Manufacturers aren’t consistent with UI!
Also, just to put it out there - resetting network settings comes at a cost. Losing saved WiFi passwords and paired Bluetooth devices can be a pain if you have multiple saved networks or devices. If it doesn’t work, that’s more hassle for no result.
Anyone thought of using a signal booster? Sometimes weak cell signals result in atrocious call quality. Verizon, AT&T, T-Mobile all sell these. Yeah, they’re pricy but could be worth it if you’re in a dead zone.
For the record, some users have said using apps like WhatsApp or Telegram and doing voice calls through them often have much better quality than your regular network calls. It’s not perfect but hey, it’s an alternative.
And let’s be real, switching carriers can be thousands times more of a headache than toggling WiFi settings off. Carrier customer services are mostly useless in helping with specific device issues! :hamburger:
Hey there, you’re right to suspect Wi-Fi calling might be causing the dropped calls. It can be a bit hit-or-miss depending on your network and device. Disabling it can potentially improve your call quality if Wi-Fi isn’t stable enough.
For folks with more general settings menus, let’s twist the guide given:
For iPhone:
  • Open Settings | Scroll to Phone | Tap Wi-Fi Calling | Turn off Wi-Fi Calling on This iPhone
For Android (general):
  • Go to Settings | Navigate to Network & Internet or Connections (depends on model) | Find Wi-Fi Calling | Toggle it off
Gonna add a bit to the troubleshooting steps, tho:
  1. Signal Strength Check: Weak cellular signals are notorious for dropped calls. If you turn off Wi-Fi calling and rely on cellular, be in a strong service area. Use an app like ‘OpenSignal’ to check signal strength.
  2. Update Software: Make sure your phone is running the latest OS version. Updates often fix bugs related to network connectivity.
  3. Network Reset – With caution: Go to Settings | System | Advanced | Reset Options | Reset Network Settings (as mentioned, you’ll lose Wi-Fi passwords and Bluetooth connections, a bit of a pain).
  4. Check Network Mode: Sometimes, setting the phone to a specific network mode helps. For instance, stick to LTE/4G rather than auto-switching to 3G in low-signal areas.
    • Settings | Network & Internet | Mobile Network | Preferred Network Type | Set it to LTE or 4G only
  5. Alternative Calling Apps: WhatsApp, Skype, Telegram - all decent bets for call clarity. If cellular is flaky, these apps over Wi-Fi might offer stable calls.
I’m not too in on the whole signal booster thing. They can help, but only if your network’s baseline signal is moderately good. No booster can fix a zero-bar situation.
More radical suggestions if call drops persist – Consider switching to a different carrier. Not a fan of this route due to the inconvenience and potential cost but worth exploring if nothing else works.
Lastly, firmware updates from manufacturers sometimes come with vendor-specific fixes. For a Samsung or Google Pixel, check for such updates by going to Settings | Software Update.
Bear in mind - Wi-Fi calling off might hit battery life differently. Phones spend more power hunting for a weak cellular signal over managing robust Wi-Fi connectivity.
If these steps are still leading nowhere, relay the exact scenarios to your carrier’s support, as they might offer insights or fixes specific to their network.
Lemme know how this works for ya. Hope those pesky call drops become past troubles! :hamburger:
Try a simpler test. Turn off Wi-Fi during calls. Open Control Center or Quick Settings, toggl Wi-Fi off. Place 5 calls where drops happen. Log results. If drops fall from 3 of 5 to 0 of 5, Wi-Fi calling was the trigger. Keep Wi-Fi off while you talk. When finished, turn Wi-Fi back on. No settings hunt. No resets. Proof in 2 minutes.
