How can I enable pop-ups on my iPad?
I can’t access certain features on some sites because pop-ups are disabled on my iPad. I’ve tried looking through the Safari settings, but I couldn’t figure it out. Could someone guide me through the steps to enable pop-ups? Thanks in advance!
If you’re having trouble with pop-ups on your iPad, don’t worry—it’s a common issue, and the steps to fix it are pretty straightforward. You’ll basically need to tweak your Safari settings. Here’s a step-by-step guide that’s beginner-friendly:
  1. Open Settings: First, you need to access the ‘Settings’ app on your iPad. It’s usually a gray gear icon.
  2. Find Safari: Scroll down through the left-hand menu in Settings until you see Safari.
  3. Pop-Up Blocking: Click on Safari and find the option that says ‘Block Pop-ups’. This option is located under the ‘General’ section.
  4. Disable Blocking: By default, this option is turned on. You’ll just need to toggle it off. You’ll slide the button to the left, and it should turn from green to white/gray.
That’s pretty much it! Once you’ve disabled the pop-up blocker, Safari should allow pop-ups, and you shouldn’t have any issues accessing site features that rely on them.
Just a heads-up though: Be cautious when enabling pop-ups because some sites can be pretty aggressive with them. Could end up with a lot of annoying ads if you’re not careful. You might also want to re-enable the pop-up blocker after you’re done with the specific site that needed it.
Oh, and while you’re at it, it might also be a good idea to enable ‘Fraudulent Website Warning’ under Safari settings if it’s not already on. Adds a little extra security, ya know?
Hope that helps!
@codecrafter has provided a pretty solid walkthrough for enabling pop-ups on your iPad. It’s true that the ‘Block Pop-ups’ setting in Safari is usually the culprit. Follow those steps, and you should be good to go.
However, there’s a point of contention I’d like to raise. Instead of completely turning off the pop-up blocker, which might expose you to unwanted ads and potentially harmful sites, you have another option: enabling pop-ups selectively for trusted sites.
Here’s a slightly different approach:
Custom Pop-Up Management
Safari + Content Blockers: Instead of disabling the pop-up blocker entirely, consider using content blockers. These can give you more granular control over which sites can show pop-ups. Several third-party blockers are available in the App Store that you can customize to allow pop-ups only on specific sites.
Steps for Using Content Blockers:
  1. Download a Content Blocker: Head to the App Store and download a reputable content blocker app—some top picks include 1Blocker, AdGuard, etc.
  2. Configure the Blocker: Open the app and configure settings to allow pop-ups for specific sites.
  3. Enable Content Blocker in Safari: Go back to the Settings app:
    • Tap on ‘Safari’.
    • Scroll down to ‘Content Blockers’ and enable the blocker you downloaded.
  4. Adjust Blocker Settings as Needed: You may need to periodically revisit the blocker app to fine-tune which sites should be allowed to display pop-ups.
Avoid Site-Specific Pop-Up Issues
It’s helpful to address the problem on a case-by-case basis rather than blanket disable all pop-up blocking.
  1. Open the Site: Navigate to the site that requires pop-ups.
  2. Temporary Disable Pop-Up Blocker: Disable the ‘Block Pop-ups’ option in Safari as mentioned by @codecrafter.
  3. Perform Task: Complete the action that requires the pop-up.
  4. Enable Blocker Again: Once done, go back and re-enable the ‘Block Pop-ups’ setting to keep your browsing experience clean and safe from unwanted ads.
Additional Settings for Safety
@codecrafter also mentioned enabling ‘Fraudulent Website Warning’. I’d add a couple more for a safer browsing experience:
  1. Enable ‘Prevent Cross-Site Tracking’:
    • This keeps websites from tracking your activity across the web.
    • Found under Settings → Safari, switch the toggle for ‘Prevent Cross-Site Tracking’ to on.
  2. Block Cookies (Optional & Advanced):
    • For added privacy, you can selectively block cookies, but this can disrupt some sites’ functionality.
    • Navigate to Settings → Safari → Block All Cookies. Use cautiously as it might require signing in frequently.
Temporary Allow on Per-Site Basis - Quick Fix
For those who don’t wish to deal with apps or prolonged settings adjustments, you might temporarily enable pop-ups while visiting a site. This method is a bit of a quick fix:
  1. Visit Needed Site: Make sure to visit the site needing pop-ups.
  2. Disable Blocker: Switch off the ‘Block Pop-ups’ quickly just for that session.
  3. Perform Site Actions: Do whatever is needed on the site.
  4. Re-enable Blocker: Immediately turn pop-ups back off after leaving the site.
Summary
To encapsulate, while disabling the pop-up blocker as @codecrafter suggested is a solution, an enhanced method allows for finer control over what gets through. Using content blockers for selective site permissions and temporarily adjusting settings for specific pages can balance convenience and security seamlessly.
Overall, without repeating too much: considering a middle ground of temporary adjustments or selectively allowing pop-ups via third-party apps could be less risky and might reduce intrusive ads.
So you want to enable pop-ups on your iPad? Honestly, letting those annoying pop-ups through might make sense for one or two important sites, but it’s a huge security risk and plain annoying most of the time. You’ll soon be swamped with ads and junk. Sure, @codecrafter’s steps work, and @byteguru’s suggestion to use content blockers is a bit more sophisticated, but both overlook the major pain you’re signing up for enabling pop-ups.
First off, allowing ALL pop-ups? That’s a bad move. If you prefer a less invasive solution, try using the ‘Reader Mode’ in Safari for a cleaner experience. Reader Mode can sometimes bypass pop-up blockers without turning them off completely. Here’s how:
  1. Open Safari: Go to the website that’s giving you trouble.
  2. Activate Reader Mode: Tap the AA icon in the address bar and select ‘Show Reader’.
This isn’t perfect and doesn’t help with interactive pop-ups, but it’s a middle-ground without risking your sanity.
Moreover, if you really need certain pop-ups, try toggling ‘Block Pop-ups’ OFF temporarily. Here’s the quick way:
  1. Open Settings: Navigate to Safari settings.
  2. Toggle ‘Block Pop-ups’ OFF: Do your business on the site and toggle it back ON immediately after.
  • Enables necessary site features.
  • Easy to switch as needed.
  • Opens the floodgates to annoying ads.
  • Potential security risks.
Additionally, those third-party blockers like 1Blocker or AdGuard are just another way to complicate your life. They might help, but installing yet another app is a hassle and can bog down your browsing speed. They also aren’t perfect—some pop-ups still sneak through.
For occasional use, going through the manual toggle dance is annoying but keeps you safe. Long-term, stick with default settings unless you enjoy endless pop-ups and potential security threats.
Your points are fair, but they miss a simpler fix. Use long press to opne the pop up as a new tab.
Steps:
  1. In Safari, find the button or link that spawns the pop up.
  2. Press and hold.
  3. Tap Open in New Tab, or Open in New Window on iPad.
  4. Complete the task, tehn close the extra tab.
This avoids changing settings, keeps blockers on. Works on login or payment flows I test. If it fails on a specific site, try Request Desktop Website, then repeat the long press.
