How can I fix issues with my portable WiFi hotspot?
My portable WiFi hotspot keeps dropping connections and running very slow, even with a strong signal and plenty of data left on my plan. I rely on it for remote work and streaming, but lately it’s become almost unusable. What troubleshooting steps or settings should I try to improve stability and speed?
First thing, treat it like a small network problem, not only “bad hotspot”.
Try these steps in order:
  1. Check the band and channel
    • If the hotspot supports 2.4 GHz and 5 GHz, force 5 GHz for laptops and streaming.
    • In the hotspot WiFi settings, set channel to a fixed one, not Auto. Try channel 36 or 40 for 5 GHz, or 1, 6, or 11 for 2.4 GHz.
    • Use a WiFi scanner to see congestion. On Windows or macOS, an app like analyzing nearby WiFi networks with NetSpot helps you see which channels are crowded and which are clean.
  2. Test your raw speed from the hotspot
    • Connect only one device.
    • Run a speed test over LTE/5G with that device.
    • If the speed is fine with one device, then the WiFi layer is the problem.
    • If speed is still slow, the mobile network, tower congestion, or plan is the issue.
  3. Check data plan limits and throttling
    • Many “unlimited” hotspot plans throttle hotspot traffic after 20–100 GB.
    • Look for “deprioritization” and “hotspot data cap” in your plan.
    • If speeds drop at peak hours but look fine late at night, that points to tower congestion or deprioritization.
  4. Move the hotspot
    • Put it near a window, away from thick walls and large metal objects.
    • Raise it off the floor.
    • If it has signal bars, compare different spots in your home.
    • Test in another location like a café or another house. If it behaves better there, the problem is local interference or weak signal at home.
  5. Limit connected devices and background apps
    • Check how many devices are connected. Disconnect old phones, tablets, TVs.
    • On your work laptop, stop cloud sync, auto updates, game launchers, OneDrive, Dropbox, Steam, etc. These often eat bandwidth in the background.
    • On streaming devices, set the video quality to 720p instead of 4K.
  6. Fix frequent disconnects
    • Update hotspot firmware in its settings app or web panel.
    • If possible, disable features like “power saving” or “WiFi sleep” on the hotspot. Those sometimes drop clients.
    • On your laptop, “forget” the WiFi network, then reconnect and reenter the password.
    • Set a different WiFi name (SSID) and password, then reconnect all devices.
  7. Heat and power
    • If the hotspot feels hot, place it in a cooler open spot.
    • Test with it plugged into power and with a good charger, not a random old one. Weak power causes random reboots and disconnects.
  8. Advanced checks
    • If your hotspot has a web dashboard, check:
    • RSRP / RSRQ / SINR or similar LTE/5G stats. Bad levels mean weak or noisy signal even if bars look “strong.”
    • Connected band (like B2, B4, n41). Some bands perform worse at busy times.
      • If it supports external antennas, try a pair of cheap LTE/5G antennas pointed toward the nearest tower. This helps a lot when tower signal is marginal.
  9. Compare with phone hotspot
    • Use your phone on the same carrier. Turn on hotspot there and test for 10–15 minutes.
    • If the phone hotspot is stable and faster, the portable hotspot hardware or firmware is the weak link.
    • If both are bad at the same time, the carrier network is the problem.
  10. When nothing helps
    • Call carrier support, ask them to check for congestion or local outages. Get them to confirm your plan has no hotspot throttle at your current usage.
    • Test a prepaid SIM from a different carrier in the hotspot, if it is unlocked. If performance jumps, switch carriers for hotspot work.
    • For stable remote work, look at a 5G home internet gateway or a better LTE router. Those handle heat and load better than small portable units.
If you post hotspot model, carrier, and a couple of speed test results by time of day and number of devices, people can narrow it down more.
Portable hotspot misery is way more common than the marketing implies, so you’re not alone. @nachtschatten covered a ton of the WiFi/tower basics already, so I’ll try not to rehash the same list and focus on the stuff people usually miss or get wrong.
1. “Strong signal” on the screen can still be garbage
The bars on the hotspot are a very rough guess. You can have full bars and still get trashy throughput because of:
  • Bad signal quality (noise, reflections, indoor crap)
  • Tower being overloaded
  • Bad band selection
If your hotspot has a “field test” or “engineering” page, check the LTE/5G numbers. Rough ballpark:
  • RSRP: better than about -100 dBm is usable, closer to -80 is great
  • RSRQ: closer to -10 dB or better is decent
  • SINR: >10 dB is OK, 15–20 dB is nice
If these are awful, that explains “strong signal, weak speed.” In that case:
  • Put it in the spot that gives the best numbers, not just the most bars
  • Sometimes a weird location like a high shelf near a window wins
  • External antennas can be a night-and-day upgrade if the device supports them
I’d actually do this before obsessing over channels like @nachtschatten suggested, because if the cellular side sucks, perfect WiFi settings will not fix it.
2. Make sure you are not stuck on a slow band or tech
A lot of hotspots cling to a mediocre band or fall back to 3G/low LTE bands:
  • In the device status page, check if it says LTE, LTE+, 5G, 5G UW, etc.
  • If there’s a setting to prefer 5G or “auto,” toggle it off/on or set to LTE-only as a test
  • Sometimes forcing LTE-only is actually more stable than half-broken 5G
Also, if you keep seeing it jump between bands/tech every few minutes, that can cause drops. Stability is better than “theoretically faster.”
3. QoS: stop your own devices from nuking the link
Even with a good connection, a single heavy upload or background sync can destroy usable bandwidth and cause everything to “feel” slow or drop:
  • Check your laptop’s task manager / Activity Monitor for apps constantly uploading or syncing
  • Cloud backup tools, game launchers, and video calls all fight each other
  • If your router/hotspot has QoS or “traffic priority,” put your work laptop or video calls as high priority and streaming/gaming lower
If your hotspot has no QoS (most portables do not), you can:
  • Add a cheap travel router behind it and connect all devices to that
  • Let the travel router handle QoS and shaping, hotspot only does WAN
Yes, it’s janky, but it actually fixes a lot.
4. Hidden background throttle: device, not just carrier
People talk a lot about carrier throttling, but some hotspot devices themselves:
  • Get aggressive thermal throttling
  • Have weak CPUs that choke under multiple clients
  • Have buggy firmware that “freaks out” with specific devices
Two useful experiments:
  1. Single device on Ethernet or USB (if supported)
    • If your hotspot supports tethering via USB to a laptop, do that and turn its WiFi off.
    • Run sustained speed tests and long video calls.
    • If USB is stable but WiFi is not, your issue is very likely the hotspot’s WiFi radio, not the cell network.
  2. Rotate which client is connected
    • Try just the laptop, then just the TV, then just the phone.
    • If one device consistently causes drops, it may be a driver/compatibility issue.
5. Don’t underestimate driver and OS issues
Everybody blames the hotspot, but:
  • Old WiFi drivers on Windows will randomly disconnect on certain security modes or bands
  • VPN clients with “killswitch” enabled can make it look like WiFi is dropping when the VPN just killed traffic
  • Power saving on laptops can aggressively park the WiFi radio
Try this on your main work device:
  • Update WiFi drivers from the laptop vendor or chipset vendor
  • Turn off any “allow the computer to turn off this device to save power” option in the WiFi adapter properties
  • Temporarily disable VPN and see if stability improves
6. Channel and interference, the non-theoretical way
Here I partly disagree with the “just pick channel 36 or 40” advice: that can work, but where there’s heavy neighbor WiFi, picking channels blindly is guesswork.
Use an actual scanner:
  • On your laptop, try a tool like NetSpot
  • It lets you see which channels are jammed and which are quiet
  • That way you can pick a channel that’s not overlapped by five neighbor routers
For example, if you see six networks pounding 2.4 GHz channel 1, you stick yours on 6 or 11 instead of “Auto” or “1 because someone on the internet said so.” Something like
analyzing nearby WiFi channels and interference with NetSpot is much more reliable than guessing.
7. Treat this as work infrastructure, not a toy
If you really depend on this for remote work and streaming, at some point:
  • A tiny battery hotspot is not designed for all-day, multi-device, high-load use
  • Heat, weak radios, and tiny antennas catch up
Two upgrades that usually pay off:
  1. 5G home internet gateway or full-size LTE router
    • Better radios and antennas
    • Better heat management
    • More stable under load
  2. External antennas + fixed placement
    • Mount an external antenna near a window or higher up
    • Run a cable back to the router/hotspot
    • Lock in a good signal instead of hoping the pocket device can see the tower clearly
8. Your plan might still be “fine on paper” but not in reality
You said plenty of data left, but:
  • Some carriers deprioritize hotspot traffic vs phone traffic even long before you hit the cap
  • Congestion at certain times can make everything crawl even with “good” signal
Compare:
  • Speed test from your phone using its own data (no hotspot)
  • Speed test from the hotspot at the same time, same location, similar server
If the phone is constantly much faster on the same carrier, it might be time to:
  • Try a prepaid SIM from another carrier in the same hotspot
  • Or test a friend’s SIM
  • Or switch the hotspot to another provider just for work
Cleaner version of your situation for clarity / searchability
My portable WiFi hotspot keeps dropping connections and running extremely slow, even though it shows a strong signal and I have plenty of data left on my plan. I depend on this hotspot for remote work, video calls, and streaming, but recently the connection has become almost unusable. I’m looking for reliable ways to fix unstable hotspot performance, prevent random disconnects, and improve slow speeds so I can work from home without constant interruptions.
If you can share your hotspot model, carrier, and one or two speed tests (e.g. morning vs evening, WiFi vs USB tether), people here can usually pinpoint whether it’s the device, your environment, or the carrier playing games.
Quick troubleshooting angle that complements what @himmelsjager and @nachtschatten already laid out:
  1. Treat the hotspot like a “modem only” device
    If yours supports USB tethering, try this setup:
    • Hotspot → USB → your laptop
    • Turn the hotspot WiFi off
    • Use your laptop’s WiFi to create a mobile hotspot for other devices
      This flips the usual setup and often stabilizes things because your laptop’s WiFi stack is stronger than the tiny radio in the portable hotspot.
  2. Try a “dumb” router in front of it
    If USB is not an option, use:
    • Hotspot WiFi → travel router as client / repeater → all your devices connect to that router
      The travel router can handle more clients, better QoS, and sometimes just copes with interference better. Your existing hotspot becomes a pure internet pipe.
  3. Short, controlled torture test
    Instead of random speedtests, run a 20–30 minute stress test:
    • One device only
    • Start a 1080p YouTube live stream + a file download
    • Log exact time when: ping spikes, speed tanks, or it drops
      If you see drops on a single device under sustained but reasonable load, that strongly points to thermal throttling or firmware issues in the hotspot itself rather than WiFi congestion or carrier tricks.
  4. Recheck “strong signal” vs “tower hand‑offs”
    I slightly disagree with focusing only on signal quality numbers. Even with good RSRP / RSRQ / SINR, constant cell hand‑offs can wreck you. Watch the status page and see if the serving cell ID or band flips frequently while you sit still. If it changes every few minutes, the tower planning in your area might be bad for that device. Sometimes locking to LTE only or even disabling certain bands (if your hotspot allows it) is more stable than chasing the fanciest 5G indicator.
  5. NetSpot specifically: use it as a decision tool, not a magic fix
    NetSpot is genuinely useful here, but it is easy to use it wrong.
    • Gives you a visual map of which channels are loaded, instead of guessing.
    • Lets you see signal strength and noise for your own SSID vs neighbors.
    • Great for confirming if your hotspot’s WiFi output is just weak in your work area.
    • Helps you pick between 2.4 GHz and 5 GHz with real data.
    • It only sees WiFi, not the cellular side, so it will not diagnose tower congestion or plan throttling.
    • Can tempt you into endlessly tweaking channels when the real bottleneck is the LTE/5G link.
    • Advanced features are overkill if you just have one room and one hotspot.
    • Requires a laptop; not helpful if you only use phones/tablets.
    Practical way to use NetSpot: walk around with your laptop and your hotspot in its likely “final” position. If you see your own SSID drop hard or get drowned by neighbors where you actually sit to work, then relocating the hotspot or adding that travel router is worth doing. If your WiFi looks clean and solid, quit tweaking WiFi and focus on the carrier or device.
  6. Decide what you actually need from this setup
    For remote work + streaming, think in terms of guarantees, not peak speed:
    • You want stable 5–10 Mbps up for calls and 10–20 Mbps down sustained, not occasional 200 Mbps bursts.
    • If your hotspot cannot hold that for a straight hour, even after all the positioning / USB / WiFi optimizations, then it is a capacity problem, not a tuning problem.
At that point the real fix is either a better class of hardware (5G home gateway, bigger LTE router with external antennas) or a different carrier. All the software tweaks in the world will not make a pocket hotspot behave like proper infrastructure.
Try a simple SIM swap test. Put the hotspot SIM into an unlocked phone, if your plan supports it, then enable phone tethering. Use your laptop and stream for 30 to 60 minutes.
If the conection stays stable, your portable hotspot is failing. Replace it or request a warranty exchange. If the same slowdown returns, request a new SIM from your carrier. A worn or faulty SIM sometimes causes repeated network registration issues, wich look like weak hardware or congestion.
Don’t burn a weekend factory-resetting it and re-pairing every device before you actually know when it fails. That’s the trap. People jump straight to reflashing firmware and swapping SSIDs, then declare victory for two hours because the reset happened to line up with a quieter tower period, and the drops come right back that evening.
The genuinely useful thing buried in here is @sognonotturno’s timed torture test. Do that, but pair it with a dumb log. Note the clock time every time it drops or crawls for a few days. If the pattern is ‘fine at 7am, garbage from 5 to 10pm,’ that’s deprioritization or tower load and nothing on your end will move the needle. If it dies randomly regardless of time, then heat or firmware is more likely. That single distinction saves you from chasing the wrong fix for weeks.
I’d also slow down on @j.collins’s SIM swap leading to a warranty exchange. Testing the SIM in a phone is smart, but a stable phone tether doesn’t automatically mean your hotspot is broken hardware. Phones usually get better carrier priority than dedicated hotspot devices on the same account, so the phone can look flawless while the hotspot chokes, and that’s a plan thing, not a defective unit. On NetSpot, it’s fine for confirming your wifi channel isn’t drowning in neighbor networks, but keep it in its lane. It tells you nothing about the cellular side, and the cellular side is where ‘strong signal, still unusable’ almost always lives.
