How can I pair my stylus pen with my iPad?
I recently got a new stylus pen for my iPad, but I’m having trouble connecting it. I’ve tried following the instructions, but it just won’t pair. Has anyone else experienced this? Any tips or steps I might be missing?
First off, congrats on the new stylus pen! Pairing these gadgets can sometimes be a bit of a headache, but we’ll get you sorted.
  1. Check Compatibility: Make sure the stylus you’re using is compatible with your iPad model. Some styluses are only compatible with certain iPad generations. For example, the Apple Pencil 2 only works with iPad Pro models from 2018 and later. If your pen isn’t compatible, it simply won’t pair.
  2. Bluetooth On: Ensure Bluetooth is enabled on your iPad. Head to Settings > Bluetooth and make sure it’s on. The pen will use Bluetooth to communicate.
  3. Apple Pencil-specific Steps:
    • Apple Pencil 1: Plug it into the Lightning port on your iPad and tap the pairing button that appears.
    • Apple Pencil 2: Attach it magnetically to the side of your compatible iPad. It should automatically pair, and you’ll get a notification.
  4. Charge It Up: Whichever stylus you have, make sure it’s got enough juice. Sometimes they come with a very low battery out of the box. Charge it fully and then try pairing again.
  5. Reset Connections: Go to Settings > Bluetooth, find your stylus in the list of devices, and forget it. Then restart your iPad, turn Bluetooth off and on again, and try pairing from scratch.
  6. Firmware Update: Ensure your iPad is running the latest iOS version. Sometimes firmware updates address connectivity issues. Go to Settings > General > Software Update.
  7. Third-party Stylus Issues: If it’s not an Apple Pencil, the pairing process might be different. Consult the manufacturer’s website for specific instructions. Some third-party styluses pair via their own apps rather than the iOS Bluetooth settings.
  8. App Compatibility: Some styluses won’t appear as a Bluetooth device in settings but will work inside specific apps. Open apps like Procreate or GoodNotes and see if the stylus works there.
If you’ve done all that and it’s still not pairing, it might be worth trying to test your stylus on another iPad to see if it’s a problem with the stylus itself. Alternatively, reset your iPad settings as a last resort or contact the manufacturer’s customer support for more specific guidance.
Anyone else run into weird issues like this with styli? Sometimes it feels like voodoo science.
You might find that codecrafter’s pretty thorough checklist covered a lot, but let’s go deeper into some nuances that occasionally get overlooked. Some additional steps and considerations might be just what you need to get that stylus up and running with your iPad.
  1. Environmental Interferences: Sometimes pairing issues can be as trivial as electronic noise. Ensure that you aren’t in an area with too many Bluetooth devices that might be causing interference. Move to a different location or turn off other Bluetooth devices.
  2. Cleaning Connections: For any stylus connecting through the Lightning port or magnetically, make sure both your iPad port and the stylus’ connection points are clean. Dust or grime can impede pairing.
  3. Soft Reset: Beyond just turning off Bluetooth, perform a soft reset on the iPad. Hold the Power and Home (or Volume Up for newer models) buttons simultaneously until the Apple logo appears. This often resolves minor software glitches.
  4. Device Memory: iPads, especially older models, might struggle with too many Bluetooth devices remembered. Go into the Bluetooth settings and remove devices you no longer use.
  5. Reinstall Apps: If your stylus is app-dependent and won’t recognize it, sometimes deleting and reinstalling the app can help reinitialize the necessary software integrations for the stylus.
  6. Hidden Settings: Dig into any hidden or lesser-known settings that might be interfering. For instance, devices using screen readers like VoiceOver or other Accessibility settings might experience pairing issues because of conflicting touch inputs.
  7. Stylus Reset: Some third-party styluses have a reset option generaly found in the manual or manufacturer’s site. This could involve pressing a combination of buttons on the stylus or holding one down for an extended period.
  8. System Log Analysis: Although more technical, you can use tools to look at system logs on your iPad to see if it’s throwing any specific errors related to Bluetooth or Peripheral connections. This can often highlight hidden issues.
  9. Multiple Devices Conundrum: If your stylus had paired with another device before trying it on your iPad, make sure it’s not still ‘remembered’ by the other device. Forget the stylus on any other gadgets and try from scratch on your iPad.
  10. Hardware Issues: Unfortunately, sometimes it’s a hardware issue either with the iPad Bluetooth chip or the stylus itself. Consider borrowing a friend’s stylus to see if it pairs with your iPad or try your stylus on their device. This can help determine where the problem lies.
  11. Firmware on Stylus: Some high-end third-party stylus pens have their own firmware that occasionally requires updates, usually done via an app or computer. Ensure your stylus firmware is up to date.
  12. Consult the Manual: It might sound basic but sometimes we overlook unique manufacturer guidance. Give the manual another read or check the company’s support site for FAQs.
  13. Warranty and Support: Lastly, if all else fails, leverage the product’s warranty or support. Submit a ticket or call their support line. A manufacturing defect isn’t out of the question.
Visualize the steps:
  • Initial quick fixes: Bluetooth, compatibility check, cleaning
  • Advanced resets and system fixes: Soft reset, removing devices
  • Hardware isolation: Trying different stylus or iPad
Normally, it’s the simple things that trip us up, but if after all this you’re still stuck, the manufacturer’s support will likely be your next best bet. There’s an odd satisfaction in getting tech to finally cooperate, right? Anyone else have sneaky ways around their pairing issues?
Sounds like you’re jumping through hoops just to get a fancy pen to work. Here’s the real talk: sometimes all these techy tricks just don’t cut it, and it could simply be your stylus is a dud or your iPad is being finicky.
These compatibility checks are good, sure, but let’s not overly complicate stuff. You check the Bluetooth, you make sure it’s charged, and it either works or it doesn’t. Don’t get too gung-ho about ‘clean connections’—I mean, if you’ve got grime jamming your ports, that’s a whole other issue.
Also, resetting your iPad or doing a ‘Soft Reset’ might sound like a good idea, but it can be overkill. It’s like rebooting a computer for every minor issue. But hey, no harm if it works for you.
Sometimes, these styluses are just plain picky. Maybe consider trying a different brand if all else fails. Logitech and Adonit have some solid alternatives, just to throw it out there. At the end of the day, these gadgets sometimes just decide to work when they feel like it. Don’t go nuts over it.
Try this simpler route. Some iPads block non Apple styluses in Notes.
Do this:
  • Open Settings, Apple Pencil.
  • Turn off Only Draw with Apple Pencil.
  • Open Notes, make a new note, try your pen.
If a Pair prompt shows, accept. If no pairing, test the pen by scrolling Safari and in Sketchbook. If it works there, the Notes setting was the issue. If nothing works, open teh vendor app from the manual QR, update firmware, pair inside the app.
