I just got an iPhone 14 Pro Max and I can’t figure out how to screen record. I need to make a tutorial video for a project, but I’m stuck. Can anyone guide me through the steps?
Congrats on your new iPhone 14 Pro Max! You’ve got a powerful device in your hands, and thankfully, screen recording is pretty straightforward. Here’s a step-by-step guide to get you through it:
1. Enabling Screen Recording in Control Center
First, you need to make sure that screen recording is added to your Control Center.
Open the Settings app: Go to your iPhone’s home screen and tap on the Settings app.
Go to Control Center: Scroll down and tap on “Control Center.”
Customize Controls: Tap “Customize Controls.” You’ll see a list of controls that you can add to your Control Center.
Add Screen Recording: Look for “Screen Recording” in the “More Controls” section, then tap the green plus “+” button next to it. This will move “Screen Recording” to the “Included Controls” section at the top.
2. Starting a Screen Recording
Now that screen recording is in your Control Center, here’s how to start recording:
Open Control Center: Swipe down from the top-right corner of the screen. This opens the Control Center on the iPhone 14 Pro Max.
Start Recording: Look for the screen recording button, which looks like a solid dot inside a circle. Tap it. A 3-second countdown will appear, giving you a little prep time before the recording starts. After the countdown finishes, the recording starts automatically.
Red Status Bar: While recording, you’ll notice a red status bar or a red bubble in the top-left corner of the screen, indicating that recording is in progress.
3. Accessing Microphone Audio
If you need to record a voiceover or any background audio while recording the screen, make sure to enable your microphone:
3D Touch / Long Press: On the screen recording button inside the Control Center, use a long press (or 3D Touch) to bring up more options.
Microphone Audio: You’ll see a microphone icon at the bottom of the pop-up. If it says “Microphone Off,” tap it to turn it on. It should say “Microphone On.”
4. Stopping the Recording
Once you’ve got your footage, here’s how to stop the recording:
- Stop Recording: Either tap the red status bar or bubble at the top of the screen, then tap “Stop” in the pop-up. Alternatively, you can return to the Control Center and tap the screen recording button again.
5. Viewing Your Recording
To view your recording, do the following:
Photos App: The recording will be saved automatically to your Photos app. Open the Photos app and look in the “Recents” album or the “Screenshots” album.
Trim & Edit: You can trim and edit your video directly within the Photos app. Just open the video, tap “Edit,” then use the sliders to trim the footage or use the editing tools at the bottom for more adjustments.
Tips for Creating Tutorial Videos
- Practice the Flow: Go over what you want to show in your tutorial before hitting record. This helps make the final recording smoother.
- Speak Clearly: If you’re narrating, speak clearly and concisely.
- Highlight Key Details: Utilize gestures or any digital highlight tools available to emphasize important points.
Troubleshooting Issues
If you run into any issues, like the recording abruptly stopping, try these troubleshooting tips:
- Storage Space: Ensure you have enough storage on your iPhone for the recording.
- Restart Your Device: Sometimes a simple restart can fix glitches.
- Software Update: Make sure your iPhone is running the latest version of iOS.
Alternative Apps
While the built-in screen recording feature is quite powerful, if you need more advanced features like annotation or live streaming, you can check out third-party apps like:
- TechSmith Capture: Great for professional-looking screencasts.
- DU Recorder: User-friendly and offers more advanced recording options.
One last thing: If your tutorials involve sharing sensitive information, be careful to hide or blur it out. You can use video editing software for this purpose.
Good luck with your project!
Seeing that @byteguru provided a very detailed guide, I’ll just add a few additional tips that may enrich your recording experience.
If you find the built-in screen recording feature lacking in some areas, you might want to explore apps like Loom or ScreenFlow. Loom offers powerful features like instant sharing and annotations. ScreenFlow, although paid, provides high-end editing features including transitions, text overlays, and more – making it particularly useful for polished tutorials.
Also, if you’re looking for voice clarity in your tutorials, consider using an external microphone like the Rode SmartLav+, which connects directly to your iPhone. It significantly ups your audio game compared to the internal mic, capturing cleaner and more professional-sounding audio.
One thing to be cautious about – as engaging as screen recording is, it can eat up storage quickly, especially if you’re recording in high resolution. So, make sure to regularly transfer your files to your computer or an external storage device if you’re doing longer or multiple takes.
Finally, to build on byteguru’s troubleshooting tips, pay attention to your battery level. Screen recording alongside other high-power tasks drains your battery fast. Plugging in your phone during recording sessions can save you from a sudden shutdown.
Oh! And try using AssistiveTouch. This feature keeps the visible button on your screen small and out of the way, handy if you don’t want the Control Center swipe covering crucial parts of your tutorial.
That’s it from me! Hope your project turns out great!
Screen recording on the iPhone 14 Pro Max isn’t that complex, but come on - creating a tutorial with just the built-in screen recording? It’s limiting. Third-party apps like Loom or ScreenFlow aren’t just bells and whistles; they’re necessary tools for serious users. In-built tools often miss out on advanced features like sophisticated editing or file management, making third-party apps indispensable.
That advice about using AssistiveTouch? Really? It’s more distracting than helpful. Clunky UI and misplaced buttons can ruin your recording. Opt instead for a stable setup and you can avoid unnecessary complications.
The internal microphone is also meh. If you strive for any semblance of professionalism, invest in an external mic. While Rode SmartLav+ is a suggestion, you have other options like Shure MV88 - a little less obvious but equally good.
One major downside to the entire screen recording frenzy on iPhone is the drain on battery and storage. The built-in tool is notorious for gobbling up resources. Always be plugged in if you’re planning a long session.
And guys, let’s not kid ourselves. For those who think built-in tools are the end-all, you’re in for a shock when it comes to post-editing. Apple’s built-in editor is basic – like, stone-age basic. You need something robust, like Adobe Premiere Rush or iMovie, for any real editing work.
In short, don’t lean on the built-in tool as your savior. Consider it more of a last resort.
