How can I sniff and monitor serial port activity on my PC?
I’m trying to debug a device that communicates over a serial port, but I can’t see exactly what data is being sent and received. I’d like to capture, log, and analyze all serial traffic between my computer and the device for troubleshooting. What tools or methods can I use to sniff and monitor serial port activity reliably, and are there any tips for setting this up without interrupting the existing connection?
If you want to sniff and monitor serial port activity on your PC and see every byte going in both directions, you have three main paths:
  1. Pure software on the same PC
  2. Software + virtual “sniffer” port
  3. Hardware tap with a second device
I will keep this focused on what you can run today.
  1. Easiest option on Windows: dedicated serial sniffing software
For a straight PC ↔ device setup over RS232, software is usually enough.
A good option is Serial Port Monitor. It hooks into the serial stack and shows:
• TX and RX data in real time
• Hex and ASCII views
• Time stamps for each packet
• Parsed requests and responses for some protocols
Typical workflow:
  1. Close any app that already uses the COM port.
  2. Start Serial Port Monitor.
  3. Select the active COM port, for example COM3.
  4. Set the same baud rate, data bits, parity, stop bits as your device.
  5. Start monitoring, then run your normal app and talk to the device.
You get a scroll of traffic, with direction arrows, so you see exactly what your PC sends and what the device returns. You can also log everything to a file for later analysis.
For people googling “sniff serial port” and similar, check this RS232 sniffer page, it walks through practical usage with screenshots:
detailed RS232 serial traffic sniffer guide
  1. Monitoring traffic between another app and the port
If you already have an app that opens the port and you want to spy on it:
• Use a port sniffer that attaches to an already opened handle.
• Or use a virtual COM port pair and route the existing app through that pair.
With virtual ports you do this:
PC app → COM5 → sniffer layer → COM6 → real device
The sniffer watches traffic between COM5 and COM6. Serial Port Monitor supports this pattern and logs everything.
  1. Linux options
If you run Linux:
• Use strace on the process that talks to the serial port, useful for debugging termios settings.
• Use minicom or picocom to talk to the device directly and log data.
• screen /dev/ttyS0 115200 for a quick test.
• For real sniffing when another app owns the port, use socat or tty0tty to build a virtual pair similar to Windows.
Example quick logger:
stty -F /dev/ttyS0 115200 cs8 -cstopb -parenb
cat /dev/ttyS0 | hexdump -C > serial.log
Not as friendly as GUI tools, but works.
  1. Hardware tap when the PC is not the master
If you have device A ↔ device B and you want to sniff between them, or your PC app cannot be touched, use hardware.
For RS232:
• Get an RS232 Y splitter cable or build one.
• Tap TX and RX lines into a USB to RS232 adapter connected to your PC.
• Run a terminal or Serial Port Monitor on the tap COM port.
For TTL UART:
• Use a USB to UART adapter, connect GND, RX to target TX, and RX to target RX if you want both directions.
• Set voltage to match the device, 3.3 V or 5 V.
Hardware is more work but gives you clean, independent capture and avoids driver conflicts.
  1. What to log and how to analyze
When you sniff serial traffic, configure your monitor to record:
• Hex + ASCII view together. Binary protocols need hex.
• Accurate time stamps, in milliseconds if possible.
• Direction markers, PC → device and device → PC.
Then you can:
• Look for fixed headers or magic values.
• Check for repeating frames, often periodic status messages.
• Compare logs from “working” and “broken” states.
With Serial Port Monitor you can filter by direction, by data, or by event type, which helps when traffic gets noisy.
  1. Typical pitfalls
A few common gotchas:
• Wrong baud rate or parity, output looks like garbage.
• Another app still owns the port, sniffer shows nothing.
• USB to serial drivers being flaky, traffic drops under heavy load.
• Flow control mismatches, RTS/CTS vs none, or XON/XOFF.
So, if you want something quick and GUI based on Windows, Serial Port Monitor is a good pick for full serial traffic capture, logging, and analysis. On Linux, use a mix of screen, socat, and a hardware tap when software hooks are not enough.
If software sniffing + virtual ports covers 90% of use cases, the other 10% is where people pull their hair out. That 10% is where the interesting stuff happens.
@​mike34 covered the “use a proper sniffer like Serial Port Monitor / virtual COM” angle pretty well. I’ll focus on some different tricks and situations that usually get ignored.
1. When the serial device keeps rebooting or dropping out (USB‑serial weirdness)
One thing most tools won’t show you clearly: what happens when the USB‑serial bridge disconnects and reconnects under the hood.
On Windows:
  • Watch Device Manager while you’re running your test.
  • Check if the COM port number changes or briefly disappears.
  • Combine that with Serial Port Monitor logging. You’ll actually see gaps in timestamps where the driver drops.
That’s very different from “no data” and can explain random freezes or half packets.
2. When the app insists on grabbing the port first
Sometimes you can’t easily insert a virtual pair or change the app’s config. In that case, I don’t like relying only on stack‑hook sniffers, because some older software pokes the driver in weird ways.
A workaround:
  • Use a simple “shim” process that opens the real COM port.
  • Shim talks to the device and exposes a TCP socket.
  • Your original app connects over TCP instead of COM (if it supports that, many industrial apps do).
  • Then you can log everything at the shim level.
Typical shim tool: socat on Linux, or a tiny custom app if you can code. This is more robust than trying to sniff a handle you don’t fully control.
3. Catching control signals, not just data
Most people only log RX/TX bytes. That’s not always enough.
If the protocol relies heavily on RTS/CTS or DTR/DSR for state, you want to see:
  • When RTS is asserted/deasserted
  • When DTR toggles
  • Break conditions
Some GUI sniffers show this, but I’ve seen folks completely misdiagnose issues because they only looked at the data stream.
So, when you set up Serial Port Monitor or any similar tool, don’t just stare at the hex view. Enable logging for:
  • Line status changes
  • Flow control events
  • Break events
Then correlate “device stopped talking” with “CTS dropped right before that”.
4. The “latency” problem nobody talks about
Everyone focuses on bytes. Almost nobody checks for timing problems.
Your protocol might rely on:
  • Minimum delay between frames
  • Response timeout windows
  • Inter‑byte gaps for autodetection
Some sniffers show timestamps, but you actually need to use them:
  • Look for patterns like: request at T0, reply at T0 + 5 ms, but occasionally reply jumps to 500 ms.
  • Compare logs from a “good” PC vs the “problem” PC.
If the delay correlates with CPU spikes or USB hub usage, the issue is not your protocol, it is the environment.
This is where Serial Port Monitor’s timestamps become really useful, not just pretty.
5. When the protocol is binary and “human eyes” are useless
If traffic is binary and you’re trying to visually decode it in hex, you’ll go blind.
Different tactic:
  1. Capture a long session to file (pcap‑style or plain binary from Serial Port Monitor or any logger).
  2. Write a tiny script (Python is easiest) that:
    • Searches for recurring headers (e.g., 0xAA 0x55)
    • Counts packet lengths
    • Checks simple checksums (sum of bytes mod 256, XOR, CRC guesses).
Even without knowing the spec, you can often:
  • Identify frame boundaries
  • Guess sequence numbers
  • Spot error frames / NAKs
You do the heavy lifting offline instead of trying to read 0x00 0x1F 0x8C by eye.
6. When neither software nor a simple Y cable works
I’ll mildly disagree with relying too much on a single PC sniffer in some cases.
If:
  • You have random framing errors
  • You suspect noise on the line
  • Devices are far apart or in an industrial plant
Then I would skip pure software entirely and go for:
  • A proper USB logic analyzer that can decode UART (Saleae style, or cheaper clones).
  • Hook it directly to TX/RX/GND.
  • Capture hours of traffic and analyze glitches, bit timing, framing errors.
Software sniffers won’t tell you that the voltage level occasionally dips or edges are sloppy. Hardware capture will.
7. Capturing boot‑time or early handshake you usually miss
Another subtlety: if your device sends important bytes immediately on power‑up or reset, many terminal apps and sniffers miss it because the port isn’t open yet.
Workarounds:
  • Open the port with your sniffer first, then power‑cycle the device.
  • If that still misses early stuff, use a logic analyzer or USB‑serial tap that is “always listening” electrically, independent of the OS.
This is a very common gotcha on bootloaders or diagnostic banners.
8. Practical logging strategy that actually helps debugging
Whatever tool you use (including Serial Port Monitor):
  • Always log both hex and ASCII simultaneously.
  • Record:
    • Port config at the top (baud, parity, flow control)
    • Start time and stop time
    • What the user did (“pressed button X here”, “device reset here”) as comments or timestamps in a separate file
Then when you share logs with others (or future you), you can actually make sense of them instead of trying to guess what happened at line 18324.
9. Getting a solid tool on your machine
If you’re on Windows and want a straightforward way to capture serial data, inspect traffic, see timestamps, and export the logs, using something like Serial Port Monitor is usually the least painful approach.
You can grab installers and versions tailored for that here:
download a powerful serial traffic analyzer for Windows
That plus a basic understanding of timing, flow control signals, and maybe a simple script for offline parsing will put you miles ahead of the “just open Putty and hope” crowd.
In short: don’t just think “see bytes.” Think:
  • Bytes
  • Timing
  • Control lines
  • Environment (USB hubs, cable quality, noise)
  • Repeatability (logs you can replay and compare)
Once you treat it like that, sniffing and monitoring a serial port turns from black magic into something pretty methodical.
Try the application’s own debug logging before adding sniffers or hardware.
Open its settings or config file. Enable options named “debug,” “trace,” “protocol log,” or “communications log.” Set the level to verbose. Reproduce one short test, then inspect the log for sent and recieved frames, timestamps, errors, and retries.
Many device tools also support diagnostic commands such as LOG=3 or DEBUG=ON. Save each test in a seperate file and record the baud rate and action performed. This avoids port conflicts and takes minutes to set up.
Software that hooks the driver can hide the exact bug you’re chasing. If your problem is timing related, adding a stack hook or a virtual port pair inserts its own tiny delays into the path. So you sit there staring at clean logs, everything looks fine, and the moment you pull the sniffer out the device flakes again. @hoshikuzu is right that timing matters, but the catch nobody mentioned is that a software sniffer is part of the timing.
That’s why for anything where you suspect framing errors, inter-byte gaps, or a device that’s picky about response windows, I’d reach for a passive hardware capture before I trusted a software trace. A cheap USB logic analyzer clone runs a few dollars and just listens on the wire. It doesn’t touch the data path, doesn’t own the port, and doesn’t care which app is talking. You get the real edges and the real gaps, not a version filtered through Windows.
For plain ‘what bytes are going back and forth’ debugging on a normal PC to device link though, software is genuinely fine and much less faff. Serial Port Monitor is a reasonable pick there for the hex plus ASCII view and the logging, as long as you remember it’s showing you what the driver saw, not necessarily what was on the copper. Treat it as your first look, not your final proof.
One correction to the general vibe of the thread. People keep jumping to fancy captures before checking the boring stuff. @apiapi4 is dead on about turning on the app’s own debug log first. Half the time the device or the software already logs the frames with retries and error codes labeled, which beats reverse engineering hex by hand. Do that, confirm your baud and parity are actually right, and only then decide whether you need a sniffer at all.
The place all of this falls apart is a live system you can’t interrupt. If the device is in production and you can’t power cycle it or steal the port, a Y tap or logic analyzer is your only honest option, because anything that opens the port risks yanking DTR and resetting the device the second you connect. Worth knowing before you learn it the hard way.
