How do I disable auto-lock on my iPad?
I’m trying to stop my iPad from auto-locking while I’m reading or watching videos. It’s frustrating to constantly tap the screen to keep it on. Can someone guide me through turning off the auto-lock feature? Thanks in advance!
To stop your iPad from auto-locking, follow these steps:
  1. Go to Settings on your iPad.
  2. Scroll down and tap on Display & Brightness.
  3. Tap on Auto-Lock.
  4. You’ll see several options ranging from 30 seconds to 15 minutes, plus a “Never” option. Select Never if you don’t want your iPad to auto-lock at all.
That should stop your iPad from locking while you’re reading or watching videos. A couple of things to keep in mind though:
  1. Battery Drain: Keeping the screen on indefinitely will drain your battery faster. Make sure you have it plugged in when you plan on using it for extended periods or keep an eye on your battery level.
  2. Screen Burn-In: An LCD screen like the iPad’s can suffer from burn-in if a static image is displayed for too long. So it’s a good idea to manually lock your iPad when you’re not using it for a long time.
If you find that your iPad still isn’t behaving the way you want, another trick you can try is enabling the Guided Access feature, which locks your iPad into a single, inactive state app for uninterrupted use. It’s quite handy if you don’t want to keep fiddling with brightness or worry about notifications popping up.
Especially if you’re into e-reading; books, PDFs, or long articles, Guided Access can be a real lifesaver. With that, you won’t have to exit your chapter or article. If that’s overdoing it, at least select a higher interval for auto-lock instead of “Never,” like 10 or 15 minutes.
Alternatively, if you’re watching videos and have to keep tapping the screen, maybe consider using a media player app that keeps the screen on while a video is playing, since some media player apps can bypass the auto-lock settings.
Keep in mind, balance is key. Keeping your device on ‘Never’ may not always be the best for general use but it’s convenient for specific long sessions. Play around with these settings and see what’s perfect for you.
Honestly, just disabling auto-lock isn’t the end-all solution here. Even if you set it to “Never,” your battery is going to take a hit, and let’s not forget the risk of screen burn-in.
Instead, think smarter: use the Guided Access feature that @codecrafter mentioned. It’s under Accessibility in Settings. This feature can lock your iPad into a single app and disable the auto-lock, too, without you having to fiddle with the settings each time.
Or, just use a different media player. Believe it or not, apps like VLC and Infuse usually override the auto-lock and keep the video playing. It’s like the iPad’s native apps just aren’t optimized for giving users control anymore. Typical Apple.
Then again, if you’re just reading and not watching videos, try Kindle or Apple Books. They tend to stay open longer, but it’s still hit or miss.
No matter what, remember that keeping your iPad on “Never” isn’t foolproof. You might end up with your battery drained or wreck your display. Choose your poison wisely.
I see where @techchizkid and @codecrafter are coming from, especially when they emphasize Guided Access for uninterrupted use. However, let me toss in my two cents.
Beyond just adjusting the settings to ‘Never’ or using Guided Access, there are a few other things you might consider to ensure your iPad doesn’t auto-lock while reading or watching videos:
First off, if you’re primarily reading PDFs, eBooks, or long articles, @codecrafter was spot-on mentioning apps like Kindle and Apple Books. Beyond these usual suspects, apps like GoodReader or even Adobe Acrobat Reader often have better in-app controls for keeping the screen awake.
If you’re heavily into video content, @techchizkid’s advice on switching media players is gold. VLC and Infuse are indeed excellent choices. They can override auto-lock settings while playing videos, ensuring you won’t have to deal with constant interruptions. Another good option might be Plex if you have a media server at home—it also has robust screen control settings.
But honestly, relying on just these settings or apps isn’t a full-proof solution. Let’s get a little more technical—most people aren’t aware, but Within your device’s Accessibility settings, there’s another neat trick: using the ‘Accessibility Shortcut’. Set it up to quickly enable Guided Access with a triple-click of the home button. That way, you can flip into reading/video-watching mode without diving back into the Settings app. It makes life just a bit easier, and you’ll end up using it more frequently once you get the hang of it.
Another thing is, even if battery drain and screen burn-in seem like hurdles, there are ways around those as well. For battery drainage, you could invest in a quality portable charger or Power Bank. They’re quite handy if you are planning on long sessions without being tethered to an outlet. As for screen burn-in, while it’s less common with modern iPad screens compared to older display tech, it’s still worth considering. You could use apps that periodically change parts of the screen slightly, or just take breaks to allow your device some downtime.
@techchizkid hints at balancing the auto-lock timer, which is valid. You might not need ‘Never’ as your daily driver. More like scaling back to 15 minutes when not in continuous use could be a middle ground. This way, you occasionally have to interact with your iPad, reducing prolonged static images and giving the device some respite.
One other thing to think about is low power mode. Enabling this mode not only conserves battery but sometimes plays nice with the screen output settings. It’s usually a compromise since the iPad will dim the display but still an option to consider if you’re focused more on battery longevity.
From personal experience and knowing how finicky tech can be, at times, toggling settings off and on acts as a refresh or reset. If auto-lock is being uncooperative, sometimes heading into the Settings and disabling and then re-enabling various features such as Auto-Lock and Guided Access fixes the behavior.
Lastly, another forum tip - keeping your iPad software updated. Often, updates include tweaks and fixes to settings behavior that isn’t immediately obvious. If your device’s auto-lock features become buggy, ensuring you’re on the latest iOS version might nip any quirky behavior in the bud.
So, beyond just the primary settings, there are multiple ways to tackle the iPad auto-lock issue creatively. Consider melding a few of these tips to see what suits your use case the best. Happy reading and viewing!
Good roundup. You hit Guided Access, Auto-Lock Never, reader and video apps, Accessibility Shortcut, battery tips, timer balance, resets, updates. One note, Low Power Mode reduces the auto lock time, so dont use it for reading.
Simpler path. Use Siri to jump straight to the setting. Say, Hey Siri, open Auto-Lock settings. Tap Never before a session. When done, say it again. Pick 5 minutes. Fast, no deep menus.
Example, a 2 hour PDF session stayed awake with this. Then I switched back in 3 taps.
