How do I migrate from Dropbox to Google Drive?
I’m trying to switch from Dropbox to Google Drive but don’t know the best way to transfer all my files. Dropbox storage is full, and I recently upgraded my Google Drive. I need a seamless method to move everything without losing any data. What are your recommendations?
Switching from Dropbox to Google Drive can be done more smoothly by using a combination of manual steps and third-party tools. Here’s a roundup of methods people usually prefer:
  1. Manual Download and Upload: Simply download your files from Dropbox to your computer and then upload them to Google Drive. This can be time-consuming, especially if you have a lot of files, but it requires no technical expertise.
  2. Use Google Drive’s File Upload Option: Log in to Google Drive, go to the main interface, then click on the ‘New’ button followed by ‘File upload’ or ‘Folder upload.’ Drag and drop your downloaded files from Dropbox to there.
  3. Third-Party Tools:
    • MultCloud: This is a web-based management tool where you can directly sync Dropbox to Google Drive. Just link both your Dropbox and Google Drive accounts to MultCloud, and you can transfer your files within its interface.
    • CloudMounter App: The CloudMounter app is another solid option to transfer files between cloud services. It allows you to map Dropbox and Google Drive as local drives on your computer, facilitating an easier drag-and-drop operation. It’s handy because you won’t need to download and upload files manually, which saves a load of time.
  4. Google Takeout: Create an export from Dropbox using Google Takeout, then import it into Google Drive. It’s more of a one-time solution and works well for large batches of data.
Each method has its pros and cons, and the best option largely depends on the volume of files you are dealing with and how seamless you want the transfer process to be.
For more detailed step-by-step instructions, you might want to check out the discussion on Dropbox to Google Drive migration.
Good luck with your migration!
If you’re feeling adventurous, you might want to try using a command-line tool like rclone. It’s a powerful tool for managing cloud storage, and it supports Dropbox and Google Drive among many others.
You’d have to install rclone, then configure it for both your Dropbox and Google Drive accounts. Once that’s done, you can use a single command to transfer files from your Dropbox to Google Drive. This method might be overkill if you’re not comfortable with command-line interfaces, but it’s powerful and efficient for large file batches.
Also, while the CloudMounter app is a great tool, another alternative you might want to consider is the Insync application. Insync provides a more user-friendly interface for syncing cloud storage accounts and offers a straightforward drag-and-drop functionality similar to CloudMounter, but with a few added perks such as more granular control over file synchronization.
It’s worth noting that if you go for rclone, you don’t have to worry about intermediary steps like downloading to your local machine and you can automate the transfer, which is a big plus if you have tons of files.
