I’m trying to figure out how to print double-sided documents using my Mac. My printer supports double-sided printing, but I can’t find the option in the print dialog. Any advice on what I’m missing or steps to enable this feature would be really helpful!
If you’re trying to print double-sided on a Mac and can’t find the option, you might be missing a couple of steps. It’s happened to me too, but there’s a pretty straightforward fix.
First, check that your printer is properly set up to handle double-sided printing. Some printers require an additional duplex module to be installed, even though technically the printer supports double-sided printing. Make sure that part is correctly installed and configured.
Here’s what you should do in your print dialog:
- Open the document you want to print and go to “File” > “Print…”
- In the print dialog box, look for an option that says “Show Details” or something similar. This will expand the dialog to display more options.
- Once the options are expanded, look for either a “Layout” or “Finishing” section in the drop-down menu, typically found in the middle of the dialog box.
- In the Layout section, you’ll see a checkbox or a dropdown for “Two-Sided” or “Duplex Printing.” Select “Long-Edge binding” or “Short-Edge binding” based on how you want your document to be printed.
Sometimes the UI can be a bit hidden or oddly named. If the option doesn’t show up, it might be worth updating your printer drivers. Go to your printer manufacturer’s website and download the most recent driver software for your model.
In some cases, the option for double-sided printing might be greyed out or missing altogether—this could be due to using a generic driver instead of the specific one from the manufacturer.
If you’re still stuck, you might want to reset your Mac’s printing system. This will delete all existing printers and configurations, so only do this as a last resort:
- Go to “System Preferences” > “Printers & Scanners”.
- Control-click (or right-click) in the list of devices on the left, then choose “Reset printing system…”
- Reinstall your printer and try the steps above again.
Hope this helps! Sometimes it’s just a matter of finding the right setting hidden in the UI.
Updating drivers isn’t some magical fix-all. Seems like every time there’s a suggestion, it’s always “update your drivers."
Honestly, codecrafter has some valid points, but making it seem like it’s all about the settings is misleading. What’s more important is ensuring macOS is compatible with your specific printer model.
Apple’s printing system is funky sometimes. The so-called “Show Details” button is sometimes hidden for no apparent reason. And let’s be real, resetting your Mac’s printing system? Ain’t nobody got time for that. It’s like starting from scratch, and you might lose your mind if anything goes wrong.
OEM drivers are usually the best bet instead of those generic junk ones macOS gives you. If you can’t find the setting or it’s grayed-out, chances are high the wrong driver is at fault—simple as that. But honestly, why even go through all that hassle if it works on other devices perfectly?
Then there’s always the question if macOS updates have messed things up. New macOS versions can mess with old setups. Look into that before sacrificing your sanity on some hidden UI. Competitors like Windows might have clumsy interfaces too, but at least they don’t hide necessary options this deep.
In the end, if resetting the system or updating drivers doesn’t solve it, you might as well consider throwing that printer out of the window. Or simpler yet, just use Windows. Printing issues aren’t an uncommon frustration, but the suggestions often scratch the surface without digging deep into OS-level constraints. Good luck.
You’ll probably find the issue lies in the printer driver compatibility with macOS. Often, using the generic driver supplied by macOS for a printer doesn’t allow accessing all the printer features, such as double-sided printing. To rectify this, I’d suggest manually installing the OEM driver as advised in the responses above. Here’s how:
- Visit the manufacturer’s website and find your printer model.
- Download the latest driver compatible with macOS.
- Install the driver and restart your Mac.
Now, I noticed something about aforementioned “Show Details.” Sometimes this button is indeed obscured or the GUI options are not intuitively labeled. As much as I want to say updating the driver fixes everything, it’s not always so. Make sure your macOS version is current, since updates can resolve underlying compatibility issues. If you’re running an outdated version of macOS, that could explain why the option for two-sided printing is elusive.
Alternatively, try accessing this via a different application. Some programs, like Adobe Acrobat or Microsoft Word, have more print options which somehow reveal these hidden printer features. Here’s what you could try in these programs:
Adobe Acrobat:
- Open your PDF in Acrobat.
- Go to File > Print.
- In the print dialogue, look for Printer settings and ensure “Two-Sided” is checked.
Microsoft Word:
- Look within the Printer Properties, you should see an option for double-sided printing.
Don’t forget to check the system-level printer settings in macOS:
- Open “System Preferences”.
- Go to “Printers & Scanners”.
- Select your printer and click “Options & Supplies”.
- Check for a Duplex Printing unit and ensure it’s enabled.
Also a handy hint, make sure you’re not overlooking some simple things in the print dialogue box. Sometimes, the option might be under the “Copies & Pages” dropdown which defaults to “Layout”.
Still can’t find it? Mess with the combo boxes until you spot hard-to-find options. Meanwhile, rephrasing print-related search terms might pull up previously unrevealed menus.
Forget the convoluted solutions and go back to basics if need be. Open macOS terminal – typing “cupsctl WebInterface=yes” enables the CUPS (Common Unix Printing System) web interface which is often way more capable than any front-end GUI, macOS layers.
To access the CUPS interface:
- Open your browser.
- Type “localhost:631” in the address bar.
- Through this, you can dive directly into your printer’s configuration on macOS.
Navigating through the printer-defined options at this level, ensures you get the most accurate settings untouched by macOS’s often restrictive preferences options.
Be reminded, macOS’s funky nature with peripherals sometimes results from bugged system updates. Reverting to a previous stable OS release isn’t unheard of– especially when printing issues persist beyond reason.
If reverting is not ideal, running a virtual machine like Parallels or VMware Fusion with a Windows guest OS as secondary system might sidestep macOS’s quirks entirely. These run separately but concurrently within macOS; you gain flexibility of Windows stability without leaving your Mac’s comfort.
All said, toss that printer out window if quirks multiply. Most modern printers boast auto-updates, seamless integration cross-OS, and eliminate these nightmarish settings pitfalls. Or go ecological, adopting non-paper workflows. Cloud-based document sharing lessens printing needs significantly, saving hassle & environment.
Hope this irons out the perpetual wrestle with macOS print calamities.
You covered drivers, Show Details, updates, app options, Duplex unit in Options & Supplies, CUPS, OS rollback, VMs, replacements.
Try a simpler fix. Reset the printing system, then re-add.
Steps:
- Open System Settings, Printers & Scanners.
- Right click the pritner list, choose Reset printing system.
- Click Add Printer, pick your printer, set Use to AirPrint or your model.
- Print a test page, tick Two-Sided.
- Save as Preset named Duplex, set as defualt.
This often restores duplex in one go. It clears stale queues and mismatched drivers. Fast, low risk.
