How do I print double-sided on my Mac?
I’m having trouble figuring out how to print on both sides of the paper using my Mac. I’ve gone through the printer settings and can’t seem to find the option for double-sided printing. Can anyone guide me through the steps or let me know if there might be something I’m missing? Really need to get this sorted out for a project due soon.
You know what, printing double-sided on a Mac isn’t as user-friendly as they make it out to be. Seriously, Apple likes to tout their products as intuitive, but come on. Here’s the rundown:
When you hit “Print,” click on “Show Details” to reveal more settings. It’s tedious, but that’s where the good stuff is. Look for “Layout” and you’ll find “Two-Sided” there. Pick “Long-Edge binding” or “Short-Edge binding.” Now, this process is far from straightforward. ‘Show Details’ isn’t exactly obvious, and it’s buried under unnecessary clicks.
And let’s be real, even if you find it, not every printer supports double-sided printing, even if it says it does. So don’t be surprised if your old reliable HP or cheaper Canon model doesn’t cooperate. Sometimes the printer drivers for MacOS are inadequate and buggy. With Windows, you get more straightforward printer control panels, but here, it’s like deciphering a puzzle.
Other options? You could use third-party software, but those aren’t always reliable and might cost you. All in all, the whole thing shows Apple’s inconsistency in software usability.
It’s true, Apple’s so-called intuitive design can sometimes be a head-scratcher, especially with printing. The “Show Details” trick is a good tip, but let’s not ignore another potential workaround: your print dialog box settings can vary depending on the application you’re using and the print driver installed.
Before blaming Apple entirely, it’s worth checking if your printer truly supports double-sided printing. You’d be amazed how many printers claim they do but fail in practice. But assuming you did your homework when buying the printer, let’s tackle the potential steps here:
Application-Specific Printing Options:
  1. Word or Excel (from Microsoft Office): Sometimes these applications override system settings. Look under Preferences or Print Settings within the app. You might find a checkbox for “Two-Sided” printing in the Microsoft Print dialog box itself.
  2. Adobe PDF Reader: When printing a PDF, you often get a different set of print options. The setting for double-sided printing here might appear under “Properties” or “Advanced” in Adobe’s print menu.
System Preferences:
  1. Go to System Preferences from your Apple menu and select Printers & Scanners. Choose your printer from the list and click Options & Supplies. Under the Driver tab, ensure that the “Duplex Unit” option is checked if your printer has this feature.
  2. If the Duplex Unit option isn’t visible, your printer might need a driver update. Head to the printer manufacturer’s website and check for the latest MacOS-compatible driver for your model.
Using Preview:
  1. If you’re using Preview (Mac’s default for images & PDFs), open your document, hit Command + P, then click on Show Details in the print dialog. As mentioned before, under the Layout drop-down, look for the Two-Sided option. Here, you can choose Long-Edge or Short-Edge binding.
Resetting Print System:
  1. As a last resort, you can try resetting your print system. Go to System Preferences > Printers & Scanners, right-click within the printer list, and select Reset printing system. This clears all your printer settings and often resolves weird bugs.
While @techchizkid is right about some older or cheaper printers being unreliable, certain Mac-specific print issues can also stem from outdated or corrupt print drivers. Updating those can often bypass a lot of frustration.
Third-Party Solutions:
If you still find yourself stuck, there are third-party print management solutions like Printer Pro or Printopia. These apps can sometimes offer more robust settings and compatibility if you frequently encounter printing issues on your Mac – though as noted, some of these have additional costs.
However, I’d hesitate to say Mac’s system is entirely less user-friendly than Windows. Both have quirks. On Windows, the print dialogs can be equally convoluted depending on the printer’s manufacturers’ software. We’re trading one complexity for another.
Pragmatic Tip:
One quirky, albeit practical, approach: if you can’t get the double-sided setting to work, you can manually flip the paper halfway through printing. Time-consuming but useful for short documents.
Advanced Users:
For those comfortable using the Terminal (Mac’s Command Prompt equivalent), configuring CUPS (Common UNIX Printing System) can be an extremely powerful way to access more detailed print settings. To access CUPs:
  1. Open Safari (or any web browser) and type localhost:631/printers.
  2. This direct access to printer settings might provide you more control, including forcing double-sided prints if your printer’s firmware supports it.
Considering all this, the balance is about knowing where to look. Mac’s environment sometimes feels like solving a riddle, but once you familiarize yourself with these paths and potential pitfalls, the process becomes more manageable. Don’t overlook your printer’s manual either; sometimes they offer Mac-specific setup guidance that isn’t obvious online or in forums.
Hopefully, these pointers help bridge the gap, making double-sided printing less of a scavenger hunt on your Mac. If any other users have more creative solutions, let such ideas flow!
Yea, the print settings on a Mac can be quite the treasure hunt, you’re not wrong. But let’s tackle this from another angle—how about cloud printing? Google Cloud Print was an excellent solution before it was phased out, but similar services still exist. Some modern printers support other cloud printing services or come with their own apps that might offer more seamless double-sided printing features.
Also, while the show details trick and exploring application-specific settings (like in Word or Preview) are solid tips, it’s worth mentioning that sometimes the connection type matters. USB connections might yield different options compared to wireless or network printing setups. If all else fails, reconnecting your printer via a different method might unlock features that were previously hiding.
Talking about the CUPS web interface, delve into it more. It’s a bit advanced, sure, but not out of reach for non-tech-savvy people:
  1. Open any web browser.
  2. Type localhost:631.
  3. Click on Printers.
  4. Select your printer and you’ll find heaps of additional settings for paper handling, including double-sided printing options.
Yeah, it’s not as sexy as clicking a couple of buttons, but this trick often unveils settings the standard print dialog hides. And honestly, it’s a game-changer.
One thing that @techchizkid glossed over: checking for firmware updates on both the printer and your Mac. It’s boring but essential. Outdated firmware can cause a ton of hidden issues, including the lack of double-sided printing. Most printer manufacturers have a firmware updates page on their site, and a quick visit can save a load of headaches.
Lastly, for those willing to invest a bit, higher-end printers generally offer much more reliable double-sided printing on Mac. If printing is a significant part of your workflow, it might be worth considering an upgrade. Brands like Brother or Epson tend to have better support and reliability for Mac users, based on user feedback.
Hope this adds a different perspective, and maybe makes the Mac printing puzzle slightly less brain-melting.
Try this simpler route. Enable the duplex unit in the driver.
  1. System Settings, Printers, select your printer, Options & Supplies, Options. Tick teh Duplex Unit installed. Save.
  2. Print again from Preview or Word. Choose Two-Sided.
  3. If Duplex is missing, remove the printer, add it again. Pick AirPrint first. If still missing, add once more using the vendor driver.
  4. Save a Preset with Two-Sided set to On.
This fixes duplex for many Brother and HP models. I’ve seen it work in under 2 mins. If paper curls, set Media Type to Plain.
