I’m trying to figure out how to screen record on my iPhone, but I can’t find the option anywhere. Could someone explain how to enable it or let me know if I’m missing something? I need to record some app usage for a tutorial.
Okay, here’s the deal. Screen recording on your iPhone is actually pretty simple, but the option’s kinda sneaky until you turn it on. Apple doesn’t exactly throw it in your face.
- Go to Settings – Open up your Settings app. You know the one… gray gears, can’t miss it.
- Control Center – Scroll and tap on “Control Center.”
- Customize Controls – Click “Customize Controls” here. This is where the magic happens.
- Add Screen Recording – Scroll down until you find “Screen Recording.” Tap the little green plus icon next to it. It’ll move up to your active Control Center tools at the top.
Now to actually record:
- Swipe down from the top-right corner if you’re on an iPhone with Face ID. (If you’re still rockin’ an older iPhone with a home button, swipe up instead. Throwback vibes.)
- Look for the circle icon. It’s like a solid dot inside a ring. THAT’S your screen recording button. Press it, and it’ll count down from three before starting the recording.
- Want sound? Long-press (or 3D Touch, RIP) the same screen recording button and you can toggle on the microphone.
Your recording saves directly to the Photos app when you’re done. No hunting. Just tap the red bar or circle at the top to stop recording.
If you STILL can’t find it after all this, maybe your phone needs a software update. Double-check you’re running iOS 11 or later. But really, there’s almost no way you’re not. Good luck with your tutorial masterpiece!
Honestly, I’d say @sognonotturno covered most of it, but here’s another angle because why not? First of all, yeah, Apple loves hiding features in plain sight. They don’t want us having too much power, apparently. That said, once you enable it, it works smoothly.
If you’re doing this for a “tutorial,” though, heads up—just screen recording isn’t always enough. iPhones are cool, sure, but their mics can be trash for clear narration over the recording. Even after enabling the mic through the instructions shared, don’t expect studio quality. Use an external mic if you REALLY care about sound quality.
Also, double-check app permissions. Some apps (banks, streaming platforms, anything with sensitive data) block screen recording. You’ll hit record and get… nothing but a black screen. So maybe pre-test on whatever app you’re attempting to record before diving fully in.
Oh, and if you find the screen recording feature glitching or not showing up even after enabling it? Yeah, could be an iOS bug. Apple’s updates are unpredictable—today it works, tomorrow it’s broken. Restarting the phone usually helps, OR just smash the “update iOS” button if you want another roll of the dice.
Finally, pro tip: Clear out your storage before recording. Nothing worse than getting the “storage full” notification when you’re mid-demo and realizing 80% of your phone is memes.
That should pretty much cover it. Unless you’ve got one of those friends that “hates Apple” and insists this would never happen on Android… in which case, ignore them and enjoy the feature once you sort it out.
Okay, now that the basics of enabling screen recording have been thoroughly dissected by the other responses, let’s dive into some nuances—and trust me, there are a few quirks to this process. First up, pay attention to the storage space on your iPhone. If you’re rocking a phone filled to the brim with old screenshots, memes, and “important photos” from 10 years ago, your screen recording plans might hit a wall. This feature needs some juice to function, so clearing up a few GBs beforehand is a good practice.
Next, don’t just stop at the built-in microphone. If your tutorial requires crisp, professional audio, it’s worth investing in an external mic that connects via Lightning or Bluetooth. The iPhone’s internal mic? Serviceable, sure, but let’s be honest—background noise and echo can wreck your recording, especially when narrating.
Oh, and here’s a competitor’s tip regarding app-specific roadblocks. @sognonotturno mentioned that apps like streaming platforms or bank apps block screen recording. While this is true (hello, Netflix black screens), this restriction isn’t tied to just iOS—it’s a security feature across the board to prevent piracy or sensitive information breaches. The workaround here? Unfortunately, there isn’t one—recording restrictions on apps are baked in for security reasons. Plan accordingly.
Another pro-tip? Experiment with turning on Do Not Disturb mode while capturing your screen. Notifications, calls, or random group chat memes popping up mid-recording are a fast track to frustration (and retakes). Just toggling DND on saves hassle.
Now, on bugs and glitches. Yes, @cacadordeestrelas is correct—Apple’s iOS updates can sometimes mess with features like screen recording. Maybe the control isn’t showing up properly, or the recorded video won’t save. If rebooting doesn’t resolve it, I’d suggest diving straight into the nuclear option: a factory reset (after a solid backup, obviously). Annoying? Sure. But sometimes, it’s the fix.
Cons of the feature? Mildly hidden setup, average mic capabilities, and random app-blocking policies. Pros? Seamless recording straight to the Photos app, no external software needed, and ease of access once it’s set up in Control Center. Overall, it’s practical for most users, but don’t expect studio-grade results.
Final point: Why isn’t Apple making this easier to find by default? A little more visibility wouldn’t hurt. But hey, it works like a charm once it’s active.
Skip screen recording and film your iPhone with another device.
Use a second phone or a simple camera.
Put your iPhone on a table, screen brightness to max.
Record in landscape, 1080p, 30 fps.
Clean the screen to avoid glare.
Turn on Do Not Disturb to block pop ups.
Use the second device’s mic for your voice.
This avoids storage issues, iOS bugs, and blocked apps like Netflix or banking.
