How do I start cleaning out my iPhone photos?
My iPhone storage is almost full because my Photos app has years of pictures, screenshots, duplicates, and random downloads. I’m not sure what to delete first, how to back things up safely, or the best way to organize everything without losing important memories. Any tips for cleaning out iPhone photos efficiently?
The biggest thing I learned doing this with about 35,000 photos and videos: don’t try to fix the whole library by hand in one marathon session. I did that first, and after hours of scrolling, tapping, selecting, and deleting, it barely felt like I had made a dent.
A better way is to knock out the easy stuff first, then use a tool for the messy parts.
Start with the regular Photos app. It’s still good for obvious junk, especially if you use the swipe gesture to select a bunch of photos at once instead of tapping every single one. I’d also work from albums instead of the main library. It’s easier to stay focused when you’re only looking at screenshots, downloads, videos, or one specific group of photos.
Also check whether the album you’re in has Select All. If it’s a screenshots album or some other folder full of stuff you already know you don’t want, that can save a ton of tapping.
Where Photos started falling short for me was duplicates and “almost duplicates.” The built-in Duplicates album was fine for exact copies, but my real problem was stuff like burst shots, ten versions of the same picture, old screenshots, Live Photos I didn’t care about anymore, and large videos taking up space.
That’s when I moved over to Clever Cleaner. That ended up saving the most time.
It grouped similar photos, picked out screenshots separately, found big videos, suggested the best shot from a set, and let me turn Live Photos into normal still images when I didn’t need the motion part. Instead of grinding through tens of thousands of individual items, I was reviewing smaller groups that actually made sense. The swipe-style review helped too, since you’re deciding on batches instead of one photo at a time.
I still checked things before deleting them, but the app handled most of the sorting. What looked like it was going to take multiple weekends ended up being more like a couple of evenings.
If you’re trying to free up iCloud storage too, keep in mind that iCloud Photos is the same library across devices. Deleting a photo from your iPhone also deletes it from iCloud Photos. That’s what you want if you’re cleaning house, but it’s not the same as just removing something from the phone while keeping it in iCloud.
And after you delete a bunch, empty Recently Deleted. Until that album is cleared, the photos can still take up storage, so your iCloud number may not drop much right away.
If storage space is the main issue, go after the large stuff before worrying about hundreds of normal photos. For me, the biggest wins were:
  1. old long videos
  2. screen recordings
  3. screenshots
  4. Live Photos
  5. random media saved from messaging apps
Deleting a few forgotten videos freed up way more space than removing a huge pile of regular pictures.
One thing I’d still do at the end is a pass on a computer if you have one. After the obvious junk was gone, I connected the iPhone to my Mac and did the more picky sorting on a bigger screen. Comparing similar shots and organizing albums is just easier that way.
My basic workflow would be:
  1. Use Photos first for obvious junk, and use Select All where it makes sense.
  2. Use Clever Cleaner for duplicates, similar shots, screenshots, large videos, and Live Photos.
  3. Empty Recently Deleted.
  4. Do the final picky cleanup on a Mac or PC if possible.
  5. Spend 10-15 minutes every week clearing new screenshots, blurry shots, and duplicates so it doesn’t pile up again.
That was much faster than trying to manually power through the entire library in one day.
A phone that is full because of videos is a different problem than a phone that is full because of 20,000 tiny screenshots. I’d check Settings > General > iPhone Storage > Photos first, because that tells you whether you need a big-space attack or just a clutter cleanup. I agree with @mikeappsreviewer about not manually scrolling forever, but I’d slow down before deleting anything in bulk and make a separate backup that is not just iCloud Photos. iCloud Photos is syncing, so if you delete there, it disappears everywhere. Export the important stuff to a computer, external drive, Google Photos, OneDrive, or whatever you trust, then clean. After that, start with videos and screen recordings, then screenshots, then duplicates or similar shots. Apps like Clever Cleaner can make that last part less painful, but I’d still treat its suggestions as “review this faster,” not “delete blindly.”
Don’t delete anything until you know whether you’re fixing phone storage or iCloud storage.
Those are two different cleanups. If your iPhone itself is full but you have plenty of iCloud space, the fastest fix may be turning on iCloud Photos with “Optimize iPhone Storage.” That keeps smaller versions on the phone and stores originals in iCloud. It is not organization, and it will not reduce your iCloud bill, but it can stop the phone from choking while you clean at a normal pace.
I agree with the warning above about iCloud Photos syncing deletions everywhere. The extra step I’d take is boring but important: after you copy photos somewhere else, actually open that backup and check a few old videos, Live Photos, and random older pictures before deleting from the phone. A backup you have not checked is more like a guess.
For cleanup order, I would not start with sentimental camera photos. Start with low-risk folders: screenshots, screen recordings, saved memes, downloads, duplicates, and app junk. Then deal with big videos. Leave family/travel/important albums for later when you are less likely to rush. Tools like Clever Cleaner can be useful for finding similar shots, but I would still avoid approving huge delete batches while tired. That is how the wrong “almost duplicate” gets deleted.
After deleting, empty Recently Deleted only when you are sure. Until then, treat it like your undo button.
A 60GB camera roll with no outside copy is a very different cleanup from a 60GB camera roll you’ve already exported and checked. I’d make a small “keep forever” backup first, then be ruthless only with app-created junk like screenshots, receipts, QR codes, wallpaper saves, and delivery photos. Cleaner apps can help find candidates, but they can’t know which bad-looking picture is still important to you.
