I turned on Gemini by accident and now it keeps showing up when I use Google services. I can’t find a clear setting to disable Gemini or switch back to the old experience, and it’s getting in the way of how I normally use my account. I need help figuring out how to turn off Gemini on my device or Google account.
If Gemini keeps popping up, the fix depends on where you turned it on.
For Google Search:
- Open the Google app or go to google.com.
- Tap your profile picture.
- Open Settings.
- Look for AI Overviews, Search Labs, or Labs.
- Turn off anything tied to Gemini or generative AI.
For Android:
- Open the Gemini app.
- Open Settings.
- If you see a switch for Google Assistant features or Gemini as your assistant, change it back to Google Assistant.
- On some phones, go to Settings, Apps, Default apps, Digital assistant app, then pick Google Assistant.
For Gmail, Docs, and other Workspace apps:
- Open the app.
- Go to Settings.
- Look for Gemini features, smart features, or Workspace Labs.
- Turn them off one by one.
If you joined an experimantal Labs feature, go to labs.google.com or the app’s Labs page and leave the test. Some accounts do not show one big off switch, which is annoyng, so you have to disable each feature in each app.
If you say which Google service keeps showing Gemini, people here can point to the exact menu.
There usually is not one master off switch, and that’s the part Google makes weirdly hard. I mostly agree with @sternenwanderer, but I’d add this: sometimes Gemini is not “on” in the normal settings at all, it’s tied to your Google account activity or a specific product banner you accepted once.
A few extra places to check:
- Go to myaccount.google.com and look under Data & privacy for anything labeled AI, experiments, or personalized features.
- In Chrome, check if Gemini is just opening from the New Tab page, sidebar, or a pinned shortcut. Removing that can make it feel “gone” even if the account setting isnt obvious.
- If it’s on Android and keeps hijacking the power button or voice trigger, clear defaults for the Gemini app, then disable or uninstall updates if your phone lets you.
- In Workspace, if this is a work/school account, you might not be able to turn it off yourself. Admin setting, annoyngly.
Also, sign out and back in after changing stuff. Google settings can be slow to stick, which is super frustating. If you say whether this is Search, Gmail, Android assistant, or Docs, people can narrow it down fast.
I’d push back a little on @sternenwanderer here: sometimes the fastest fix is not hunting for a hidden Gemini toggle, but changing the default app or feature that is calling it.
If this is on Android:
- Open Settings > Apps > Default apps > Digital assistant app
- Switch from Gemini back to Google Assistant, or set it to None if your phone allows it
- Then open the Gemini app page and turn off “Open supported links” if that option exists
If this is Gmail/Docs/Search in the browser:
- Check Labs, experimental features, and side panel settings inside that specific product
- A lot of Gemini surfaces are product-level UI modules, not one account-wide master switch
One more thing people miss:
- Try a different browser profile or Incognito
If Gemini disappears there, it is probably a sync/customization issue, extension, or cached flag, not a permanent account setting.
Pros of ‘’: can make answers/features faster to access.
Cons of ‘’: messy rollout, inconsistent settings, hard to fully disable.
Honestly, Google split this across too many menus. That is the real problem.
