How to check WiFi signal strength?
I’m experiencing slow internet speeds and think it’s due to weak WiFi signal. I’m not sure how to measure the signal strength to confirm this. Can anyone guide me on how to check my WiFi signal strength? Thanks in advance.
If your internet speeds are dragging, a weak WiFi signal might be the culprit. Here’s how to check your WiFi signal strength:
  1. On Your Device:
    • Windows: Click the WiFi icon in the system tray. The number of bars indicates signal strength; more bars mean a stronger signal.
    • Mac: Hold the Option key while clicking the WiFi icon in the menu bar to see detailed signal info like RSSI (Received Signal Strength Indicator).
    • Mobile Devices: Usually, the WiFi symbol in the status bar shows signal strength. More bars or segments mean better signal.
  2. Using Command Line Tools:
    • Windows: Open Command Prompt and type netsh wlan show interfaces. Look for the “Signal” field.
    • Mac: Open Terminal and type airport -s to see the signal strength of nearby networks (RSSI values).
  3. Router Interface:
    Sometimes your router’s admin interface can provide signal data. Log into your router using its IP address (usually something like 192.168.1.1 or 192.168.0.1) and check the status or connected devices section.
  4. WiFi Analyzer Apps:
    These apps give detailed insights about your network:
    • NetSpot: This app helps not only check signal strength but also map out coverage areas. You can do a detailed site survey to find dead zones and optimize placement. Available for Windows, Mac, and mobile. Check it out at NetSpot.
    • WiFi Analyzer (Android): Displays signal strength and helps you find less congested channels.
    • Airport Utility (iOS): Enable WiFi Scanner in settings, then use the app to scan for signal strength and details.
Tips for Better WiFi Signal:
  • Reposition your Router: Centrally place it to ensure even coverage. Avoid corners or enclosed spaces.
  • Update Router Firmware: Manufacturers often release updates to improve performance and fix bugs.
  • Reduce Interference: Keep the router away from electrical devices that emit interference like microwaves, cordless phones, etc.
  • Change Channel: Use a less congested channel, especially if you’re in a densely populated area. Many routers automatically select the best channel, but you can manually set it using the router’s interface or a WiFi analyzer app.
Advanced Solutions:
  • Mesh Network: If signal issues persist, consider a mesh WiFi system.
  • Extenders/Repeaters: These devices boost your signal by repeating it.
  • Professional Site Survey: If all else fails, contacting a professional for a detailed site survey might be needed. They can provide tailored solutions for optimal WiFi performance.
Checking your WiFi signal strength is the first step to diagnosing and fixing slow internet woes. By using a combination of built-in tools and apps like NetSpot, you can get a clearer picture of your network’s health and make informed decisions to improve it.
Hey there! I totally get your frustration with slow internet speeds. While @byteguru covered a lot, there are a few other approaches and insights that might help you nail down that pesky weak WiFi signal more effectively.
Built-in Device Tools:
Firstly, let’s talk about your devices:
  • Linux Users: If you’re on Linux, you can use iwconfig in the terminal to see link quality and signal strength. Just type iwconfig and you’ll get details in dBm (decibels per milliwatt).
Enhanced Router Settings:
While using the router interface is a great suggestion, another trick is to look into Quality of Service (QoS) settings, which can prioritize traffic and improve your internet experience even with weaker signals.
Pros and Cons of NetSpot:
@byteguru mentioned NetSpot, which tbh is one of the best comprehensive tools out there:
  • Very user-friendly and offers detailed analytics.
  • Allows visualization of coverage areas, making dead zones apparent.
  • Available across multiple platforms (Windows, Mac, and mobile).
  • It can be a bit overwhelming for non-tech-savvy users due to its myriad of features.
  • The free version has limited functionality; useful features are often behind a paywall.
Competitor Apps:
Did you know there are some other cool apps like InSSIDer or Wireshark? InSSIDer, for example, breaks down the data in a straightforward way, highlighting channel usage and signal strength. Wireshark is more for the advanced user, focusing on packet-sniffing to troubleshoot network problems.
Physical Solutions:
Repositioning Your Router:
Yes, placing it centrally is optimal, but also consider the height. Positioning your router higher up (e.g., mounted on a wall) can often enhance signal spread.
RF Interference:
Try using RF (Radio Frequency) shielding products if you suspect heavy interference from neighboring networks or electronic devices. This can filter out unwanted signals and reduce interference.
Dual-Band Routers:
If your router supports both 2.4GHz and 5GHz bands, ensure you’re using the optimal one. For instance, the 2.4GHz band has a longer range but is more prone to interference. Conversely, the 5GHz band is faster but has a shorter range. Depending on your home layout and needs, choosing wisely can make a difference.
Advanced Tech Tips:
Adjust your router’s antennae. If your router has external antennas, tweak their positions. Typically, a perpendicular arrangement (one vertical, one horizontal) covers a broader area in a multi-level home.
Mesh Networks:
While Mesh Networks like Google Nest WiFi or Eero can be great, they can get pricey. Mesh systems often provide robust connectivity and better coverage but consider your home’s size and layout. Sometimes, investing in high-quality extenders or repeaters is enough.
WiFi 6:
If your devices support WiFi 6 (802.11ax), upgrading might be worth the investment. WiFi 6 routers offer better performance in crowded areas and improved signal efficiency.
Quick Fixes:
  • Change Your DNS: Slow internet speeds might sometimes be due to DNS resolution. Switch to Google DNS (8.8.8.8, 8.8.4.4) or Cloudflare (1.1.1.1) instead of your ISP’s default.
  • Bandwidth Hogging Apps: Ensure no single device or app is hogging all the bandwidth. Apps like Netflix or large updates can affect overall performance.
DIY Solutions:
Here’s a fun, somewhat quirky tip: aluminum foil! Creating a DIY WiFi reflector using aluminum foil can sometimes enhance your signal. Form a curved shape behind your router to reflect the signal in a desired direction.
Alternatively, use a WiFi analyzer combined with the comprehensive site survey of NetSpot to pinpoint exact weak spots in your home. NetSpot can offer a granular level of detail that simple indicators can’t provide.
Try these tips and see if any of them help alleviate your internet issues. And if things are still sluggish, you might need to consider your ISP speeds or hardware upgrades. Hope you find a solution soon!
Checking your WiFi signal strength doesn’t have to be a Herculean task, and while @techchizkid and @byteguru have provided solid advice, there are some additional angles to explore.
For starters, let’s take a different approach using software and some deeper, technical tweaks. Sure, NetSpot app is recommended heavily, and for good reason. The app allows you to visualize your WiFi coverage in a user-friendly manner. It’s especially useful if you’re dealing with multiple rooms and want to pinpoint those notorious dead zones. Check it out at NetSpot. But let’s sprinkle in some other insights to give you a fuller picture.
Your Router Placement & Settings
OK, major great point on router positioning was already made, but here’s another strategy—elevate your router. You’d be amazed how moving it up a bookshelf can sometimes bump up signal quality. And hey, those fancy router antennas? They’re not just for show. Play around with their angles; a good rule of thumb is to have them perpendicular to each other (one pointing up, the other horizontally).
Inside your router settings, look for advanced options. Ensure you have both 2.4GHz and 5GHz bands enabled if your router supports it. The 5GHz band, while shorter range, is less crowded and provides faster speeds close-up.
Use Built-in OS Tools
For those on Linux, it’s worth reiterating the command line tool iwconfig. This gives a granular view of link quality, signal level, and more. It’s pretty handy if you’re into deep dives.
On Windows, netsh wlan show interfaces is another gem. Look out for the “Signal” field; anything below 50% indicates you’re struggling. Mac folks already know about the Option-click trick on the WiFi icon, but delve into details like Noise and Transmit (Tx) rate for even finer tuning.
External Devices and Hardware Tweaks
@byteguru talked about extenders and repeaters, and he’s spot on—they can be lifesavers. Additionally, check out Powerline Adapters. They use your home’s electrical wiring to transmit the internet from the router to the adapter, which can be excellent if the layout prevents ideal router placement.
Fancy a tech upgrade? If you haven’t already, consider a WiFi 6 router. It’s like upgrading from regular coffee to an espresso shot—more efficient, especially with multiple devices.
Apps and Analyzers
Indeed, WiFi Analyzer apps on mobile devices work wonders. There’s another app you might find even more comprehensive: InSSIDer. The app breaks down your WiFi environment and lets you view channel usage. This is key to finding a less crowded channel.
DIY Quick Fixes
Let’s not sneer at old-school techniques. Aluminum foil DIY reflectors can be a quick fix. Position these behind your router to bounce the signal in the desired direction. Sounds quirky, but it can provide a modest signal boost.
DNS and Background Traffic Management
@byteguru mentioned changing DNS settings, which is less about signal strength but still crucial for perceived speed. Try Google DNS or Cloudflare. Also, managing background traffic properly can save the day. Apps hogging bandwidth will ruin your experience even with a strong signal.
Advanced Fixes and Alternatives
If all else fails, consider hiring a professional to perform a WiFi site survey. They can offer solutions tailored to your setup. While a mesh system like Eero or Google Nest WiFi can be pricey, the coverage they offer is next-level. Mesh systems are ideal for large homes with multiple floors, where a single router just can’t cut it.
And while many praise NetSpot, don’t overlook alternatives like Wireshark. If you’re technically inclined, packet-sniffing helps you diagnose exactly where and how your network might be failing.
Final Thoughts
Tuning your WiFi isn’t a one-size-fits-all endeavor. Experiment with different setups, channels, and tools. Be patient and methodical, and you’ll likely find the sweet spot for your internet needs. Keep exploring tools like NetSpot—its site surveys are particularly helpful for a comprehensive fix.
So, dive in, make those tweaks, and soon enough you’ll be basking in the glory of seamless connectivity.
You already covered placement, antenna angles, built in tools, analyzers, extenders, powerline, mesh, DNS, and pro surveys.
Simpler path: split your bands. Name 2.4 GHz and 5 GHz seperately in the router, for example Home-2G and Home-5G. Connect far rooms to 2.4 for reach. Keep nearby devices on 5 GHz for speed. Set 2.4 channel to 1, 6, or 11, width 20 MHz. Pick the least busy channel. Run Speedtest in three spots, note Mbps and ping. If 2.4 gives steadier ping and fewer drops, you fixed teh WiFi issue without new apps.
