I’m trying to learn how to create an AI agent for a small project, but I got stuck choosing the right tools, setup, and steps to make it work. I’ve read a few guides on AI agent development, but they all seem to skip important details, and now I’m confused about where to start and what actually matters. I need help understanding the simplest way to build an AI agent that can handle basic tasks reliably.
Start small or you’ll waste a week wiring stuff you do not need.
Use this stack:
- Python
- OpenAI API or Anthropic API
- FastAPI for your app
- SQLite first, Postgres later
- LangGraph if you need multi-step flows. Skip it if your agent is simple.
Basic agent loop:
- Take user input
- Add system prompt with role and rules
- Add short memory from prior messages
- Call model
- If model asks for a tool, run the tool
- Send tool result back
- Return final answer
Tools to start with:
- web search
- calculator
- database lookup
- email or Slack action
Keep tools narrow. One tool, one job. Bad tool design breaks agents fast.
Minimal structure:
- /api
- /agent
- /tools
- /prompts
- /tests
Example flow:
User asks, “What orders are late?”
Agent decides to call get_late_orders(order_db).
Tool returns 14 rows.
Agent summarizes rows into plain english.
Important stuff guides skip:
- Logging. Save prompts, tool calls, errors.
- Timeouts. Tools fail a lot.
- Retries. 2 retries is enough.
- Guardrails. Limit which tools the model sees.
- Eval set. Make 20 real tasks and test every change.
If this is your first build, do not start with “autonomous agent” stuff. Build one agent with 2 tools and short memory. Get that workng first. That’s the part most ppl skip.
I’d actually start before the agent loop part @mike34 covered. Figure out what the agent is allowed to decide vs what should stay hard-coded. That split saves a ton of pain.
For a small project, I’d use this rule:
- deterministic code for business logic
- model for language, classification, extraction, summarizing
- tools only when the answer needs fresh data or an action
A lot of first agent builds fail because people let the model do stuff regular code should do faster and cheaper.
Also, don’t obsess over “memory” too early. For many small projects, session state + a few recent messages is enough. Long-term memory is where people burn hours for no reason lol.
One practical setup:
- backend API
- one model wrapper
- one tool registry
- one task router
- one prompt file per use case
And honestly, I slightly disagree with “agent first” framing. Sometimes a workflow with 2 model calls beats an “agent.” Example:
- classify request
- either answer directly or call a specific tool path
- rewrite result for user
That’s simpler to debug and less flaky.
Big thing guides skip: define failure behavior.
- if tool returns nothing
- if model output is malformed
- if request is ambiguous
- if cost/token limit is hit
Write those rules first. Boring, but super improtant. If you want, I can sketch a tiny starter architecture for your exact project idea.
I’d add one layer that a lot of guides miss: evaluation from day one.
@mike34 is right about keeping business logic deterministic, but I slightly disagree on waiting too long to think about observability. Even for a tiny agent, log every step:
- user input
- prompt sent to model
- tool call arguments
- tool result
- final answer
- latency and token cost
If you do not log that stuff early, debugging becomes guessing.
My small-project recipe would be:
Pick one narrow job only
Example: “answer support questions from my docs” is good.
“be my smart assistant” is bad. -
Make a fake version first
Hard-code 10 sample inputs and expected outputs. This gives you a test set before writing agent code. -
Build the boring path before the smart path
Normal API endpoint, clean schema, retries, auth, timeout handling. -
Add the model last
Not first. Last. -
Score it weekly
Did it answer correctly? use tools correctly? hallucinate? cost too much?
Pros for the ‘’: can improve readability if you turn your process into a clearer checklist or starter guide.
Cons for the ‘’: if it stays vague, it won’t help much because AI agent development really depends on scope and constraints.
One opinionated take: don’t use frameworks too early. Plain code plus one model SDK is often better until the pain is obvious. Frameworks look fast, then you spend hours fighting abstractions.
If you share the exact project, people here can tell you whether you need a real agent, a retrieval app, or just a structured workflow.
