How to determine my iPad's age?
Recently found my old iPad while cleaning. Can’t remember when I bought it. Can someone guide me on how to find out its age? Need to know if it’s eligible for software updates. Thanks!
First off, it’s kinda strange you can’t remember when you bought your iPad. Maybe it wasn’t that memorable, huh? But anyway, here’s how you can figure out its age:
  1. Settings - Go to ‘Settings’ > ‘General’ > ‘About’. Look for the model number. You can Google this model number to find out when it was first released.
  2. Serial Number - Again, in the ‘About’ section, find the serial number. This can give a more precise manufacturing date. Websites like Apple’s Check Coverage page can help, but let’s be real—sometimes they don’t work great.
Now, quit worrying about software updates. If your iPad is older than the iPad Air 2 or mini 4, you’re outta luck. Apple cuts off support after a few years, because hey, they want you to buy a new one.
The only good thing is older models can still work for basic tasks—web browsing, reading, or watching videos—if you can handle the occasional slow down. Other brands do this too, but at least some Android tablets get unofficial updates if you’re tech-savvy.
At the end of the day, if it’s over five years old, it’s a glorified paperweight for anything more than basic tasks. catégories
First, not remembering when you bought your iPad is more common than you’d think. Life gets busy, right? Anyway, considering what @techchizkid mentioned, I’d like to add a few points and bring another angle to this.
Physical Inspection
Sometimes the model and series are etched on the back of the iPad. It’s a good shortcut, but you’ll probably still need to Google that model number to get specifics.
Software Eligibility
Apple isn’t always as harsh about updates as some suggest. There are ways to get at least security patches on older devices. Also, the usefulness of your old iPad really depends on what you want to do with it. If a new device isn’t in your budget, there are tweaks to optimize the performance of older iPads for basic tasks. Installing a lightweight web browser like Opera Mini, or a reading app like Kindle, might keep it alive a bit longer.
Performance Hacks
Consider a factory reset. It can breathe some fresh life into that old machine. Just make sure you back up any data you don’t want to lose. Get rid of any bulky apps and disable unnecessary background services to get more out of it.
Third-Party ROMs
If you’re a bit more tech-savvy, there are always unofficial operating system updates. They are a bit of a gamble and involve more tinkering, but could extend the lifespan of an unsupported device. Do your research here; one wrong flash and you can brick your iPad.
Trading Up
If it turns out the device really is too old, think about trading it in. Apple has a trade-in program where they can give you credit towards a new device. It’s worth at least checking out so you’re not left with a total paperweight.
In the end, it’s often a balance between the practical usefulness of the device and the cost of either fixing it up or replacing it. Who knows, you might find that it’s a good little tool for some simpler tasks yet.
First things first, remembering when you got your iPad isn’t that odd. We’ve all had those moments where we can’t remember dates. Now, about figuring out its age and software eligibility, here’s another angle to consider, supplementing what @codecrafter and @techchizkid already shared.
Using Finder or iTunes
If you still have a computer, either a Mac or Windows PC, it might be worth connecting your iPad to it. For Macs running macOS Catalina or later, open Finder. For older macOS or Windows PCs, open iTunes. Here’s a quick rundown:
  1. Connect your iPad to your computer.
  2. Open Finder or iTunes.
  3. Select your iPad when it appears in the app.
  4. Click “Summary” or “General,” depending on the software.
  5. You’ll see the model number, and maybe more info, like iOS version.
The benefit of this method is that you sometimes get more detailed info than just looking on the device.
Checking Apple ID Purchase History
This one’s a bit of a long shot, but if you used your Apple ID to buy the iPad, you might find the purchase in your email history or online receipts. Go to your Apple ID account (appleid.apple.com) and look through your purchase history. It won’t tell you the exact model year but might help piece things together.
Inspecting iOS Version Installed
Sometimes, your current iOS version can tell you a lot about your device’s age. Apple has compatibility lists available on their website. Identify what version you’re running now, and check against the list of supported devices. For example, if you’re running iOS 12, look at which iPads support it.
Considering Battery Replacement
If it turns out that your iPad is old but in good condition otherwise, think about getting the battery replaced. Older iPads tend to have degraded batteries, which can slow down the device a lot. Replacing the battery can give it a new lease on life. You’d be surprised how much difference a new battery can make.
Third-party Diagnostic Tools
There are some third-party diagnostic apps and tools that can help in identifying device details. CoconutBattery for Mac, for instance, can read detailed info about your iPad, including its manufacturing date. These tools often give more info than Apple’s own diagnostics.
Jailbreaking for More Control
If you’re comfortable with a bit of technical challenge, jailbreaking might be for you. Jailbreaking can unlock a range of customization and optimization options for older iPads. You can get access to apps that Apple doesn’t allow and tweak settings to improve performance. Just remember, it’s a bit risky and can void any warranties you might have left or even “brick” your device.
Keep Security in Mind
Without updated iOS, your iPad might be vulnerable to security risks. So, if you decide to keep using it, install apps that help with security. There are third-party security apps available that can provide some level of protection. It’s not perfect but better than nothing.
Final Recap
  1. Finder/iTunes: Connect to see detailed info.
  2. Apple ID Purchase History: Might find purchase details in emails or receipts.
  3. iOS Version Check: Cross-reference with supported devices for clues about age.
  4. Battery Replacement: Consider if the device is old but in good shape otherwise.
  5. Third-party Diagnostic Tools: To read detailed device info.
  6. Jailbreaking: More control and options.
  7. Security Apps: If you decide to keep using an outdated device.
Good luck! If it turns out your iPad is too old, at least you’ll know your options. Whether it’s worth continuing to use or time for a trade-in is something only you can decide based on your budget and needs.
