How To Humanize Ai Content
I’ve been using AI to help write blog posts and website copy, but the content still sounds stiff and obvious to readers. I tried editing it myself, but it still doesn’t feel natural or engaging. I need help making AI-generated content sound more human, authentic, and conversational without losing quality or SEO.
AI text sounds stiff for 3 main reasons. It stays too clean, too balanced, and too generic.
What helps:
  1. Feed it raw material.
    Give it your notes, sales calls, support emails, Slack chats, reviews. Human writing starts with human input. If you prompt from a blank page, you get blank-page copy.
  2. Make it write from one person to one person.
    Tell it who is talking, who is reading, what they want, what they fear, and what words they use. Example. “Write like a shop owner talking to a first-time customer who feels unsure about price.”
  3. Cut the fake polish.
    Remove phrases like “in today’s fast-paced world” and “seamless solution.” People skim past that stuff. Keep contractions. Use uneven sentence length. Leave a little texture.
  4. Add specifics.
    Bad. “Our tool saves time.”
    Better. “Our team cut weekly reporting from 3 hours to 25 minutes.”
    Specifics make copy feel lived-in.
  5. Edit for opinion.
    AI avoids strong takes. Humans don’t. Add a stance. Add a preference. Add a small bias. “We tested long homepage copy. Shorter won by 18%.” Now it sounds like someone was there.
  6. Read it out loud.
    If you trip on a line, rewrite it. This catches most robotic phrasing fast.
  7. Keep 20 to 30 percent human-written.
    Best results I’ve seen come from using AI for structure, then rewriting the intro, transitions, and close yourself. Those spots matter most.
My simple workflow:
AI for outline.
AI for rough draft.
You rewrite first 150 words.
You replace generic claims with proof.
You cut 15 percent.
You add 2 real examples.
Done.
If you want, post a short sample here and ppl can help de-AI it.
Big thing nobody mentions: humanizing AI copy is less about “making it warmer” and more about making it less explain-y. AI loves to complete the thought too neatly. Real people skip steps, imply things, and trust the reader to keep up a little.
So when you edit, stop fixing grammar first. Fix the logic. Ask:
  • would a real person actually say this in this order?
  • is this sentence answering a question nobody asked?
  • did it over-explain something obvious?
  • does every paragraph sound like it’s trying to win an award for being clear lol
I agree with a lot of what @himmelsjager said, but I slightly disagree on keeping a set % human-written. Sometimes 10% human input is enough if it’s the right 10%. A sharp opening, one real opinion, one weirdly specific observation, and suddenly the whole piece feels alive.
Also try this: interview your own draft.
Take a stiff sentence like:
“Our platform helps businesses improve efficiency and streamline workflows.”
Then interrogate it:
  • says who?
  • for what kind of business?
  • what workflow?
  • what changed after using it?
  • what was annoying before?
That usually forces the generic sludge out of it.
Another trick: add asymmetry. Human writing is rarely perfectly balanced. If every paragraph has the same length, same rhythm, same tidy conclusion, readers smell AI instantly. Break the pattern a bit. Short paragraph. Then a longer one. Then a sentence fragment. Feels more real.
And honestly, some AI copy should stay a little rough. Over-editing can make it weird in a diff way. Natural writing has a few bumps in it. That’s normal.
I’d add one thing to what @himmelsjager said: sometimes the problem is not the wording at all. It’s that AI writes from the outside of a topic, not from inside it.
Human copy usually has stakes. Preference. Mild bias. A point of view.
So instead of asking AI to “write a blog post about email marketing,” give it tension:
  • write this for a founder who is tired of vanity metrics
  • argue that smaller lists can outperform bigger ones
  • include one thing most marketers do wrong
  • sound like someone who has actually had to send the emails
That changes the texture fast.
Also, read the draft out loud. Anything that feels annoying to say will feel annoying to read. I cut way more by ear than by rules.
One small disagreement with the “rough is good” idea: rough only helps if the thinking is sharp. Messy + generic still reads fake.
If you’re using a tool like ', pros are speed and consistency. Cons are sameness and that polished-but-hollow tone. Good for first drafts, bad for final voice unless you push it hard.
My rule: keep AI for structure, examples, and angle testing. Keep humans for opinions, transitions, and endings. That split usually works better than trying to “humanize” every line afterward.
