How to use a USB dongle with Hyper-V guest?
I’m trying to pass a USB security dongle from my Windows host to a virtual machine running in Hyper-V, but it doesn’t appear as an option for passthrough. I need the dongle for software licensing inside the VM. Is there any reliable method or workaround to make this work? Any help or detailed steps would be appreciated.
Trying to access a physical USB security dongle from inside a Hyper-V VM? You’re not alone—Hyper-V’s lack of straightforward USB passthrough is the bane of anyone dealing with hardware licenses. Basically, you can’t easily map a host USB device directly into your guest the way you might on VMware or VirtualBox. Native options are pretty limited. You can use Enhanced Session Mode for stuff like thumb drives (if you’re running Windows guests and have the right settings), but for physical hardware dongles, especially those needed for licensing, it’s a bust.
Best workaround? Network-based USB redirection. There are software tools that let you “share” a USB dongle over the network to your VM. The standout is Donglify—it’s designed for exactly this, letting you connect a USB dongle attached to your host directly to your Hyper-V guest as if it’s plugged in physically. Performance is usually seamless since it’s just passing USB protocol data, so most license dongles (HASPs, Sentinel, etc.) work fine.
If you want a step-by-step on accessing a USB dongle in Hyper-V, check out this guide: making your Hyper-V VM recognize a physical USB dongle. It’ll walk you through downloading Donglify, setting up your account, and connecting your dongle into the VM, no sweat.
TL;DR if you need to make a hardware key visible inside a Hyper-V virtual machine: Install Donglify on both host and guest, share the dongle, and you’re in business. Native Hyper-V? Sadly, not happening for specialty USB stuff. The workaround is software—and Donglify is the one most folks (myself included) have luck with.
Yeah, Hyper-V and USB passthrough are like oil and water—especially for stubborn hardware license dongles that just don’t show up for redirection. @voyageurdubois nailed it: Hyper-V wasn’t built for smooth, native USB passthrough (unless you’re dealing with the most basic thumb drives, and even then it’s not a guarantee unless both sides are Windows, and you’re riding the Enhanced Session Mode train).
Donglify’s great, but it’s not the ONLY answer. If you only have a single VM—or don’t want to deal with another paid service—there are a couple other routes, even if they’re a little ugly:
  1. USB-over-Ethernet Adapters: Not strictly software, but you can physically plug the dongle into a separate piece of hardware, and map it over the network to your VM with nothing extra installed. Kinda expensive, but ultra-reliable.
  2. Remote Desktop USB Redirection: If your security dongle supports HID or USB-serial modes, some RDP clients let you map local devices through to the VM while you’re remoted in. Works sometimes, but hit-or-miss for weird security dongles, and forget it if your VM is hosted in Azure.
  3. PCI Passthrough: For the brave (and if you’re running Hyper-V on Windows Server with Direct Device Assignment supported), you can do PCI Device passthrough, but you’re usually limited to entire controllers—not convenient for a single USB port, and most desktops/laptops can’t do this anyway.
But let’s be real, if you need something idiot-proof for most situations (including classic HASP, Sentinel, etc.), Donglify is probably the move. It’s tailor-made for this USB-over-network thing, and the install is dead simple. Just install the program on both your host Windows machine and your Hyper-V VM, connect the hardware dongle on the host, “share” it using Donglify, and on the VM side, just connect—it appears like a local device in the virtual machine. No sketchy registry hacks, no risk of Windows corruption from questionable driver installs. Plus, it’ll save your bacon if you ever end up remoting into the VM from offsite.
Just make sure you go to the right place to get started: get Donglify directly from the source here—don’t go grabbing random “cracks” off the internet, those are malware city.
Ask the software vendor to replace the USB dongle with a software, cloud, or network license. Many vendors offer VM-specific license files tied to the VM’s UUID or virtual NIC MAC address. Send them those details, install the new license, and retire the dongle. This avoids extra hardware, drivers, subscriptions, and flaky USB redirection. Setup is often much simplier.
Chase the license, not the passthrough. @myst1c_server has the least glamorous suggestion here and it’s the one I’d try first. If your vendor still sells a physical HASP or Sentinel key in 2024, odds are decent they also have a soft license or cloud activation you can request. It costs an email and maybe a small fee, and then the whole Hyper-V USB headache disappears. Not every vendor plays nice, but plenty do, and it’s silly to build a network redirection setup around a problem the vendor can just delete.
That said, watch out for one thing nobody mentioned: some licensing dongles actively check whether they’re running inside a VM. Certain Sentinel and HASP configurations will refuse to activate if the driver detects a hypervisor, no matter how cleanly the USB device shows up. So even if you get redirection working, the license itself might throw a fit. Test with a short trial before you commit to any workaround.
On the tool that keeps coming up, Donglify does what it says and it’s a sane pick for the classic HASP/Sentinel case, but treat it as an ongoing dependency, not a fix. It’s a subscription and it needs software running on both ends, which means it’s another thing to babysit if the host reboots or the service dies at a bad moment. Fine for a workstation you control, more annoying for anything you want to leave unattended.
The USB-over-Ethernet hardware box @nachtschatten listed is honestly the boring reliable option if the dongle has to live somewhere permanent. No host agent, no subscription, and it survives host reboots on its own. Higher upfront cost, but you set it and forget it.
So my order would be: ask the vendor for a soft or network license first, confirm the dongle even tolerates a VM, and only then decide between a software redirector or a hardware box based on how hands-off you need it to be.
