How to use Easeus Data Recovery Free?
I accidentally deleted some important files from my computer and I need a reliable way to recover them. I heard about Easeus Data Recovery Free but I’m not sure how to use it. Can anyone guide me on how to retrieve my lost data using this software?
Using Easeus Data Recovery Free is quite straightforward. First, download and install the software from the official Easeus website. Once installed, open the program and you’ll see a list of drives and devices connected to your computer. Select the drive where your important files were deleted and click ‘Scan.’
The quick scan will take just a few minutes, while a deep scan will take longer. Once the scan is complete, you can preview the files before recovering them. Select the files you want to recover, click the ‘Recover’ button, and save them to a different location on your computer to avoid overwriting the deleted files.
If Easeus Data Recovery Free doesn’t find all your files, you might want to check out Disk Drill as an alternative. It’s another reliable data recovery tool that might catch what Easeus missed. Good luck!
For deals on Easeus software, check out this link for a coupon code on Reddit: Easeus Data Recovery Wizard Coupon Code on Reddit.
Easeus Data Recovery Free definitely has a user-friendly interface, but it’s not the only show in town. I’ll add to @reveurdenuit’s advice by pointing out a couple of additional tips that might save you some time and effort.
Firstly, while scanning with Easeus, consider pausing the deep scan if you see your target files early on in the scan. This can save a lot of time. As a side note, sometimes Easeus may show files in a ‘Lost Partition’ which is worth checking out if you’re not finding what you need in the standard scan results.
Also, depending on what type of files you’re trying to recover, you might have better luck with selecting specific file types (e.g. only documents or only images) before you start the scan. This narrows down the search and can speed up the process.
Now, in case Easeus Data Recovery Free doesn’t quite cut it—you might prefer Disk Drill. This software is known for its robust scanning algorithms and user-friendly interface. I’ve found Disk Drill especially useful when Easeus missed some files or when recovering from complex data loss scenarios. It’s definitely worth giving a shot if you’re in a pinch.
As for a great deal on Disk Drill, you should check out this link for various discount coupon codes: Disk Drill Coupon Code on Reddit. It might make your recovery process a bit easier on the wallet too.
If you’re dealing with really crucial or sensitive data, remember that attempting multiple recoveries can sometimes create more complications. Consider using professional data recovery services if things don’t pan out with the software solutions. Good luck!
Easeus Data Recovery Free can be quite simple, but make sure not to overlook a few crucial steps. I noticed no one mentioned the importance of stopping any further file operations on the drive where the deletion occurred. Every new write can reduce the chance of a successful recovery.
Also, another software worth considering is Recuva from Piriform. It’s often underrated but works excellently in cases where Easeus or Disk Drill might not. Recuva sometimes recognizes files that other more recognized apps like Easeus or Disk Drill miss, especially on smaller drives or not-so-complex recoveries.
Concerning Disk Drill, while it boasts powerful scan algorithms and a user-friendly interface, remember that it might not always be as efficient with extremely large volumes. The deep scans can be somewhat sluggish on massive hard drives, and you might find that it occasionally struggles with fragmented files. Disk Drill is also a bit pricier compared to some competitors. But, if you’ve lost important files and time is of the essence, its comprehensive recovery tools are hard to beat.
For instance, Disk Drill allows you to filter your search results by file type, which can significantly speed up your recovery process. And checking out their free version initially could help you gauge the potential results before committing financially.
Keep in mind that Recuva, despite being basic, can sometimes offer quicker solutions and it’s free too, unless you’re going for the advanced features in the Pro version. So while Easeus and Disk Drill are good, don’t limit yourself. Evaluate your specific needs and perhaps even try these different options before making a final decision. And of course, like @reveurdenuit and @espritlibre both pointed out, if the data is exceptionally critical, professional services might be worth investing in.
Try Windows File History or Previous Versions.
  1. Stop using the drive.
  2. Right click the folder where the files were.
  3. Click “Restore previous versions.”
  4. Browse the dates shown.
  5. Open a version, check your files.
  6. Click “Restore” or copy files out to another drive.
If File History was on, recovery success stays high.
If not, for next time, turn it on:
Settings → Update & Security → Backup → Add a drive, pick a disk, turn on automatic backups.
