Is It Still Possible To Recover Data From Corrupted USB Drive?
My USB drive suddenly stopped opening after I moved important work files and family photos onto it. Now it says the drive is corrupted and asks me to format it, but I really need those files back. I’m looking for help with safe USB data recovery options that might work before I make things worse.
I’ve had this happen, and yeah, it sucks. A USB stick goes from normal to unreadable in one plug-in, and if it has stuff you care about, your stomach drops fast.
What I’ve seen, most of the time, is damage to the file system, not instant file deletion. The data is often still sitting there. The drive structure is what got messed up. I’ve run into it after pulling a drive without ejecting it, losing power mid-transfer, random file system errors, bad sectors on aging flash storage, malware, and old drives doing old-drive things.
First thing I’d check
You need to figure out whether this looks like file system corruption or the USB itself dying.
Recovery software makes sense if your drive does some of these:
  1. It shows up in Disk Management or Disk Utility.
  2. Windows or macOS says it needs formatting.
  3. The file system shows up as RAW, unreadable, or inaccessible.
  4. The storage size appears correctly.
I’d stop and think twice about DIY stuff if any of this is going on:
  1. The USB is not detected at all.
  2. It keeps disconnecting and reconnecting.
  3. Your computer hangs when you plug it in.
  4. The connector or casing looks physically damaged.
  5. The files matter enough where one bad move would hurt.
Do not do these first
Don’t format it. Don’t run CHKDSK yet either. I learned this the hard way years ago. Repair tools write changes to the drive, and if your goal is file recovery, writing comes later. I recover first. I try repairs after.
What I’d try on my own
If the USB is still being detected, I’d start with Disk Drill. I’ve used it on broken USB file systems before. What helped me was that it scans the device itself, so it isn’t depending on a clean, healthy partition structure to find files.
The steps are simple enough:
  1. Install Disk Drill on your computer. Do not install it onto the damaged USB.
  2. Plug in the USB drive.
  3. Open Disk Drill and pick the USB from the list.
  4. Click Search for Lost Data.
  5. Wait. Some scans take a while.
  6. Preview what turns up.
  7. Recover everything to another drive, not back to the same USB.
If the drive feels shaky
If it disconnects, slows to a crawl, or acts weird during reads, I’d make a byte-for-byte backup first and scan the image instead of hammering the original stick over and over. I did this once with a flaky flash drive and it saved me from losing access halfway through. Less stress on the failing device, better odds you get one clean shot.
After the files are safe
Then I’d bother trying to fix the USB.
  1. Run CHKDSK if you’re on Windows.
  2. Run First Aid in Disk Utility if you’re on macOS.
  3. Reformat the drive if the repair tools don’t clean it up.
  4. Test it with a large copy job, both writing to it and reading back from it.
If corruption shows up again after formatting, writes fail, files vanish, or the drive starts throwing errors, I’d retire it. USB flash drives are cheap. Repeating data loss isn’t.
Yes, recovery is still possible if the USB still shows up in your system. The format prompt does not mean your files are gone. It often means the file table got damaged.
I agree with @mikeappsreviewer on one big point, do not format first. I also would not keep plugging it in over and over on differrent PCs. More mount attempts means more stress if the flash memory is failing.
What I’d add is this.
  1. Check the drive health before doing repair attempts.
    If Windows sees the USB in Disk Management with the correct size, your odds are better. If size shows as 0 bytes, or the drive drops offline, stop DIY stuff.
  2. Try a different USB port, not a hub.
    Bad ports and weak front panel power cause weird read errors. I’ve seen this more than once.
  3. Make an image first if the drive is unstable.
    On Linux, ddrescue is better than running repeated scans on a shaky drive. On Windows, USB imaging tools exist too. Scan the image, not the stick, if posssible.
  4. Use file recovery before file system repair.
    Disk Drill is a solid pick here because it handles corrupted USB drives well and lets you preview files before recovery. Recover to your internal drive or another external disk.
  5. Skip CHKDSK at the start.
    Small disagree with people who run repair tools early because they want the drive to open again fast. That sometimes works, but it also changes metadata and makes later recovery worse.
After recovery, then test fixes or reformat it.
Also, if you want a quick visual walkthrough, this quick guide to recover data from a corrupted USB drive is easy to follow.
If the USB has work docs and family photos only in one place, and the drive keeps disconnecting, stop now and go pro. That is the point where DIY gets risky fast.
Yep, sometimes you can still recover it, even after the lovely “this drive needs to be formatted” message. That alert is often about the file system being messed up, not your files being insta-deleted.
I mostly agree with @mikeappsreviewer and @sonhadordobosque, but one small thing: I would not spend too much time testing it on a bunch of systems just to “see if it works somewhere.” If the flash memory is degrading, every extra read can make things worse. A little over-cautious? maybe. But I’ve seen USB sticks go from “half-readable” to “totally dead” real fast.
What I’d do differently is check whether the controller is still talking properly to the OS:
  • In Device Manager or System Information, see if the USB identifies normally
  • In Disk Management, check if it shows the right capacity
  • If it shows the wrong size, 0 bytes, or a nonsense name, that points more to hardware trouble than simple corruption
If it is visible, use recovery software before any repair attempts. Disk Drill is a legit option for corrupted USB drive recovery because it can scan past a damaged partition table and pull files by signature too. That matters for photos a lot. Just recover to a different disk, obviosly.
One more thing people skip: if the recovered photos open but look partly gray or cut off, that usually means memory failure, not software failure. In that case, stop DIY.
Also, this Facebook discussion on flash drive recovery tips and real-world fixes might be worth a skim if you want more user experiences.
If the drive is clicking, overheating, disconnecting, or freezing File Explorer, I’d stop messing with it and go straight to a pro.
