Need help recovering data from an old WD My Passport drive
I found an old WD My Passport backup drive that may have important photos and documents, but it’s no longer opening properly on my computer. I’m trying to figure out the best data recovery option without making things worse or losing anything important. Looking for advice on safe WD My Passport data recovery methods, software, or whether a professional recovery service is the better choice.
I’ve had a few WD My Passport drives go sideways, so yeah, I know the feeling. Most of mine were fine for years, then one day one started acting off and my stomach dropped. From what I’ve seen, these drives usually hold up decently, sometimes better than some Seagate models, but when one starts misbehaving, it gets ugly fast.
First step, stop using it now. If files were deleted, or the drive is freezing, disconnecting, or showing weird errors, every extra minute of use raises the odds of overwriting data or pushing a weak drive closer to failure.
Open Disk Management from the Start button menu. If the Passport shows up there with the right capacity, even if Windows labels it as RAW or Unallocated, you still have a decent shot at handling recovery yourself. If it is clicking, grinding, or not appearing in Disk Management at all, I would stop there and look at a recovery lab instead.
What I’d do first
If the computer still detects the drive, I’d start with recovery software. After trying a bunch of tools over time, the one I keep coming back to for WD Passport issues is Disk Drill.
Why this one. It reads the file systems these drives usually use, including NTFS, FAT32, and exFAT. In plain terms, it covers the common setups you’re likely dealing with on a My Passport.
One thing I learned the hard way, if the drive is slow, drops connection, or hangs during reads, do not keep hammering it with repeated scans. Use the byte-to-byte backup option in Disk Drill first. Make an image of the whole disk, sector by sector, then scan the image instead of the drive itself. I’ve had one dying WD drive get worse mid-scan, and I wish I had imaged it first. This step lowers wear on shaky hardware.
Other tools people reach for
  1. If you deleted a few files and the drive seems healthy otherwise, Recuva is worth a shot. It looks old. It feels old too. Still, for a simple delete mistake, it’s fast and easy.
  2. If you know your way around partitions and low-level disk stuff, TestDisk is one of those tools people keep around for a reason. It’s free, text-based, and sometimes it restores access by repairing the partition layout instead of forcing a full recovery pass. I’d be careful with it, though. It doesn’t hold your hand, and a wrong write to the disk is bad news.
One thing people mess up with My Passport drives
  1. Do not pull the drive out of the enclosure unless you know exactly what model you have and what you’re dealing with. A lot of WD My Passport units use hardware encryption tied to the USB board inside the case. I’ve seen people remove the bare drive, hook it up another way, and then panic because the data looks blank or corrupted. The files are often still there, but without the original USB controller, the contents show up as nonsense. If the USB port is damaged, repair work on the original board makes more sense than bypassing the enclosure.
  2. If you enabled a password through WD Security, you need that password. No shortcut here. The hardware AES-256 encryption on these drives is serious. Recovery software won’t read your files until the drive is unlocked with WD’s own utility.
Once you get your files back, set up some kind of backup routine. I don’t mean anything fancy. WD points people toward Acronis these days, which is fine, but even copying your important folders to another external drive, OneDrive, or Google Drive is better than reliving this mess again.
Stop plugging it in and poking at it. Old Passports fail in two common ways. File system damage, or hardware trouble. The fix depends on which one you have.
I agree with @mikeappsreviewer on one big point. Do not shuck the drive. A lot of WD My Passport units tie the data to the USB board. If you bypass it, the files often look corrupted even when they are fine.
Where I differ a bit, I would check SMART health before a full recovery scan if the drive stays connected long enough. Use CrystalDiskInfo on Windows. If you see reallocated sectors, pending sectors, or tons of read errors, stop stressing the drive. Image it first. If SMART does not load, or the drive keeps dropping off, that leans hardware.
My triage order:
  1. Try a diff cable, diff USB port, no hub.
  2. Check Disk Management and Device Manager.
  3. Check SMART.
  4. If readable, clone or image first.
  5. Recover files from the image to a different drive.
For software, Disk Drill is still one of the better picks for old external drives because it handles damaged partitions and deep scans photos well. If you want a quick walkthrough, watch how Disk Drill recovers files from an external hard drive.
One more thing people miss. If the drive spins up, then freezes Explorer, do not keep retrying file copy. That behavior often means weak sectors. Scanning the image is safer. If it clicks, beeps, or smells hot, skip DIY. Lab time. Price hurts, but overwriting your last shot hurts more.
I’d be a little more cautious than @mikeappsreviewer and @byteguru on one point: I would not jump straight into any repair action at all, even “safe-looking” ones, if the files are truly important. Recovery first, fixes later. Chkdsk, format prompts, WD utilities that offer to “repair” stuff, all of that can make a bad sitaution worse fast.
What I’d do:
  1. Plug it in once with a short known-good cable, directly to the PC.
  2. If it appears, copy only a few small non-important files as a test.
  3. If it hangs, disappears, or crawls, stop doing normal file copies.
  4. Recover from it, or better, recover from an image of it.
Also, small but important thing: check whether the drive is asking to unlock with WD software. Some My Passport models are encrypted by default at the hardware level, so if it looks unreadable outside the original USB board, that may be why.
If you want a decent overview of recovery tools, this guide to the best data recovery software for external hard drives is actually useful.
For DIY, Disk Drill is a solid place to start if the drive is still detected. I like it more for old photo/document drives than some of the barebones tools because the preview is handy and it handles messed-up partitions pretty well. But I’d install it on your main drive, never on the WD itself.
Big rule: recover files to a different drive. Not back onto the My Passport. People do that and then wonder why stuff vanishes. Kinda brutal, but yeah.
If the drive clicks, beeps, or gets abnormally warm, skip software. That’s lab territory, no question.
One thing I’d add to what @byteguru, @ombrasilente, and @mikeappsreviewer already covered: check the drive on a different OS before you assume the disk itself is toast. I’ve seen old My Passport drives mount read-only on Linux or a Mac when Windows just spins forever. That does not “fix” anything, but it can tell you whether you’re fighting Windows, the file system, or the hardware.
My take is slightly different on SMART too. Useful, yes, but not always decisive on USB externals because some bridge boards hide the real health data or report junk. So if SMART looks fine but the drive is still stalling, I would trust the behavior more than the report.
If it does show up long enough to work with, Disk Drill is reasonable here, mostly because it can work from a disk image and that is the safest DIY path on an aging Passport.
Pros of Disk Drill:
  • good image-first workflow
  • easy preview for photos and documents
  • handles missing partitions and RAW volumes pretty well
  • deep scans can take forever on flaky drives
  • not the cheapest option
  • if the hardware is actually failing, software won’t save it
My rule for old externals: if it disconnects under load, stop “testing” it. Every retry is wear. If the data matters a lot, spend your remaining reads on imaging, not browsing folders. If it is making new noises, skip DIY entirely.
