I just started a new job and my employer asked me to set up direct deposit, but I’m confused by the routing number, account type, and whether I need a voided check. I don’t want my first paycheck delayed or sent back. Can someone walk me through exactly how to set up direct deposit safely and correctly with my bank and employer?
Here is the simple version so your first paycheck hits on time.
- Get the right routing number
Your bank often has two routing numbers.
• One for ACH / direct deposit
• One for wires
You want the ACH routing number.
Find it by:
• Logging in to your bank app or website, look under Account details or Direct deposit info
• Or call your bank and say: “I need the ACH routing number for direct deposit to my checking account.”
Do not guess from Google. Some banks use different numbers by state.
- Find your account number
Use one of these:
• In your bank app under the specific account
• On a paper check
• Routing number is 9 digits on the bottom left
• Account number is next number to the right
Do not mix them up. Routing is for the bank. Account is for you.
- Choose account type
Your choices on the form:
• Checking
• Savings
Use checking if you have checks or if your bank app labels it as checking.
Use savings only if you really want money into the savings account and your employer allows that.
If you are unsure, pick checking. Most payroll goes to checking.
- Do you need a voided check
It depends on your employer.
Common setups:
• Some only want the form filled out
• Some want a voided check attached
• Some accept a direct deposit form from your bank
A voided check is simple:
• Take a blank check from your checkbook
• Write “VOID” across the front in big letters
• Do not sign it
Attach it to the payroll direct deposit form if your employer asks.
If you do not have checks, ask your bank for:
• A direct deposit form or
• A “direct deposit letter” on bank letterhead that lists your name, routing number, and account number
Most payroll departments accept that.
- Double check everything
Before you hand in the form:
• Confirm the routing number is the ACH one
• Confirm every digit of your account number
• Confirm you checked “checking” or “savings” correctly
• Make sure your name on the form matches what is on your bank account
A single wrong digit can send the money back to your employer. That can delay your first check a whole pay cycle.
- Ask payroll about timing
Some employers need one pay cycle to “pre note” or test the info.
Ask them:
• “Will my first check be direct deposit, or will the first one be a paper check while you verify?”
That sets your expectations so you do not panic when payday hits.
- Quick example
Say your bank app shows:
• Account type: Checking
• Routing (ACH): 123456789
• Account: 000123456789
On your employer form you put:
• Bank name: ABC Bank
• Routing number: 123456789
• Account number: 000123456789
Attach voided check or bank letter only if they ask.
Once it is set up, you do not need to redo it unless you change banks or close that account.
Routing number / account number stuff feels more confusing than it actually is, so here’s how I’d keep your first check from going on a field trip.
First, tiny disagreement with @caminantenocturno: I would not rely on the numbers printed on an old check if your bank has had mergers or you moved states. Those usually work, but I’ve seen payrolls bounce because the checkbook routing was “legacy” and the bank app showed a new ACH routing. If your bank has an in‑app “get direct deposit details” button, trust that over the physical check.
A few practical points that don’t just repeat what was already said:
Use the bank’s own wording
In your app or online, look specifically for:- “Set up direct deposit”
- “Get paid early”
- “Employer direct deposit info”
Those screens usually give you: - Exact routing (ACH)
- Exact account number
- Sometimes a prefilled PDF you can hand to HR
That avoids you mis‑reading tiny numbers on checks.
Watch out for multiple accounts in one bank
If your app shows:- “Checking ****1234”
- “Savings ****5678”
Make sure you are copying the numbers from the account you actually want to get paid into. Biggest screw‑up I see in payroll: people copy their savings account number, select “checking” on the form, and then wonder why the deposit fails.
Confirm with HR how picky they are
Ask your payroll/HR:- “Do you require a voided check or is the bank’s direct deposit letter enough?”
- “Is the first check always paper or will it go direct deposit if I turn this in today?”
Some places can push it through same cycle if you turn it in a few days before payroll is processed. Others lock it a week or more ahead of time. So if payday is very soon, be ready that first one might be a paper check no matter what.
Instead of stressing about getting a checkbook:- Go to the bank and ask for a “direct deposit verification” or “account verification letter”
- Or download it from their site if they offer it
These usually include your name, routing, account, and account type. Employers like those because if something goes wrong, they can blame the bank instead of you.
Triple check the digits like a psycho
When you fill the form out:- Read the routing number out loud from your phone
- Write it
- Then compare every digit one by one
Same for account number. One wrong digit usually means the bank rejects it and your employer has to “reissue” your pay in the next cycle. That’s the scenario you’re trying to avoid.
Small but important: name match
If your bank account is under a different name format than your job (maiden name, middle initial, etc.), ask the bank whether that matters for ACH credits. Most of the time it does not, but if there’s anything weird like a nickname on the bank account, fix that first.
If you do those:
- Get ACH routing from the app or bank, not Google
- Make sure the account type matches where the numbers came from
- Use a bank letter or voided check if HR insists
- Ask HR about timing for the first deposit
You’re basically eliminating all the usual ways people mess this up.
