I recently started using Gamma App to create presentations and documents, but I’m struggling to figure out the best way to organize my content, customize templates, and export my work for sharing. The interface looks powerful, yet I keep missing features people mention in tutorials, and some options seem hidden or inconsistent. Can someone explain practical tips, workflows, or must‑know settings for getting the most out of Gamma App, especially for professional client presentations and team collaboration?
I had the same “Gamma looks nice but wtf do I do now” moment, so here is what helped me get over the hump.
- Organizing content
• Start from an outline, not a template
- Create a new doc or deck
- Add sections first: “Intro”, “Problem”, “Solution”, “Data”, “Next steps” etc
- Use bullets in one page to brain dump content
- Then split that into multiple pages with “Split page” or copy paste
• Use pages as slides or chapters
- One core idea per page
- If you need sub-points, use “Stacks” or “Layouts” instead of cramming text
• Use headings consistently
- H1 for page title
- H2 for key points
- This keeps navigation clear and helps when you regenerate layouts
- Customizing templates
• Start with any template, then “save your own style”
- Change fonts, colors, spacing once
- Save it as a Theme
- Reuse that Theme for new docs so everything looks consistent
• Lock in a layout pattern
- Decide on 2 or 3 layouts you repeat:
Example:- Title + big visual
- Two columns text + image
- List with icons
- Reuse those rather than changing layout on every page
- This makes the deck feel intentional and faster to build
• Use AI in small steps
- Let Gamma generate a rough deck from your outline
- Then edit each page manually
- Avoid regenerating whole decks over and over or you lose structure
- Exporting and sharing
• For clients or folks who like files
- Use Export > PDF for static decks
- Use Export > PowerPoint if you want to tweak in PPT later
• For async viewing
- Use the share link
- Turn off “Allow remix” if you do not want others to edit
- Turn on “Require email” if you need to know who opened it
• Quick checks before export
- View in “Present” mode
- Check font sizes on a laptop screen, not only your big monitor
- Make sure no text hugs the edges, PDFs sometimes clip that
- Simple workflow that worked for me
• Step 1: Write a plain text outline in Gamma or elsewhere
• Step 2: Paste into a new Gamma doc, use AI to turn it into pages
• Step 3: Apply your Theme, fix layouts on 3 key pages first
• Step 4: Duplicate those layouts for the rest
• Step 5: Run a quick pass for alignment, font size, and spacing
• Step 6: Export PDF, plus keep a share link for live edits
If you share what type of content you build, you will get more tailored layout patterns. For example sales decks vs internal docs need different structure.
Two quick things I do a bit differently from @andarilhonoturno that might help:
- Start in Gamma with raw text, not a formal outline
Instead of a clean outline first, I literally dump a mess of text onto 1–2 pages: notes, quotes, screenshots, links. Then I:
- Use “Convert selection to new page” on chunks of text
- Let AI rewrite just that page for clarity or brevity
- Drag pages around in the left sidebar until the flow feels right
So it’s “brain dump → chunk → reorder” instead of “outline → fill in.” This works especially well if you’re not sure yet what your final structure should be.
- Treat themes as systems, not just “pretty styles”
I’m slightly against obsessing over layouts early. Instead:
- Define tokens in your Theme:
- 1 main color (actions / highlights)
- 1 neutral color (backgrounds)
- 1 accent (sparingly)
- Lock in typography hierarchy:
- Title: big, bold, short
- Subtitle: medium, descriptive
- Body: small, high contrast
Once this is set, you can be pretty sloppy while building. Even if layouts are inconsistent, the deck still feels coherent because the system is consistent.
- For organizing content: think “story beats,” not sections
Instead of “Intro / Problem / Solution,” I like to write explicit beats:
- “Why this matters now”
- “What breaks if we ignore it”
- “What a good future looks like”
- “What we’re actually proposing”
- “What it costs / what we gain”
Each page must answer one of those beats. If a page doesn’t move the story forward, I delete or merge it. It hurts a little but makes export-worthy decks.
- Use AI for refining, not deciding
I disagree slightly with leaning on AI to draft whole decks. Gamma’s AI is decent, but it tends to:
- Over explain
- Insert generic buzzwords
- Flatten your own voice
What I do instead:
- Write ugly, honest text myself
- Ask AI to: “tighten this to 3 bullets” or “make this sound like a technical risk section”
- Never use “regenerate page” unless the page is completely unsalvageable
This keeps your personality while still using the tool for polish.
- Export & sharing tricks that aren’t obvious
For live sessions:
- Present from Gamma itself, but keep the left sidebar open in another tab to jump around if Q&A goes in a different order.
For reviewers who love to break things:
- Share link with comments allowed but remix off.
- Ask them to comment on specific blocks instead of emailing walls of feedback. Blocks + comments is way more surgical.
For handouts:
- Before exporting PDF, duplicate the deck.
- In the duplicate, add “speaker notes” or small text blocks under each main point with extra detail.
- Export that version as the “reading” PDF, keep the original as the “presenting” version.
- A simple mental checklist before you hit export
Run through these super fast:
- One main idea per page?
- Are any sentences longer than 2 lines? Shorten.
- Is there at least one visual break every 2–3 pages? (image, diagram, callout, quote)
- Are important numbers big enough that you can read them from across a small room?
If you answer “no” on any of those, fix before exporting. It takes 5 min and saves you from the “text soup” deck problem.
If you share what you’re mostly using Gamma for (sales, internal updates, teaching, docs, etc.), people here can probably suggest specific page patterns and themes that fit that use case instead of random generic suggestions.
