I run a small company with under 50 employees and our current performance review process is a mix of spreadsheets, emails, and notes that’s gotten really messy and time-consuming. I’m looking for recommendations on simple, affordable performance review software that’s actually built for small businesses, not giant enterprise tools. What features should I prioritize, and which platforms have you had good or bad experiences with for managing reviews, goals, and feedback?
Been there with the spreadsheet + email chaos. For <50 people you want something simple that does not need a full time admin.
Here are options that tend to work well for small shops:
- Lattice
Good if you want structure and growth focus.
- Features: reviews, goals/OKRs, 1:1 agendas, feedback, engagement.
- Pros: clean UI, easy for managers, strong review templates.
- Cons: cost adds up for very small teams, some setup time.
Best if you plan to grow beyond 50 and want one system for reviews, goals, feedback.
- PerformYard
More focused on reviews and less fluff.
- Features: review cycles, 360s, goals, simple reporting.
- Pros: flexible workflows, works well for small orgs, less overwhelming than some tools.
- Cons: UI feels a bit “HR tool” but it works.
Good if you want serious review structure without too much culture stuff.
- BambooHR Performance (if you need basic HR too)
If you do not have HRIS yet, this kills two birds.
- Features: employee records, PTO, plus goals, reviews, simple feedback.
- Pros: one system, decent performance module for small teams.
- Cons: performance features are lighter than Lattice/Leapsome.
Good if you want HR plus reviews in one tool and do not need deep analytics.
- 15Five
Good for ongoing check ins plus reviews.
- Features: weekly check-ins, 1:1s, reviews, engagement.
- Pros: supports continuous feedback, helps managers run better meetings.
- Cons: can feel like “one more thing to fill out” if you do not keep it simple.
Works well if your culture supports frequent touchpoints, not only annual reviews.
- HiBob Performance or Leapsome
More complete people platforms.
- Features: reviews, goals, feedback, engagement, learning.
- Pros: strong flexibility, good for detailed review cycles and analytics.
- Cons: might feel heavy for <50 unless you have a people ops owner.
What I would do with under 50 people:
- Decide how often you want reviews
- Simple option: 2 cycles per year, plus light mid cycle check ins.
- Keep rating scales and questions short. Aim for 6 to 10 key questions.
- Define one standard process
Example:
- Self review
- Manager review
- Optional peer feedback
- One meeting to align, document 3 priorities for next 6 months.
- Shortlist tools based on that process
If you want:
- Minimal system, review-focused: PerformYard.
- Reviews plus weekly manager habits: 15Five.
- Reviews plus broader HR: BambooHR with performance.
- Strong growth / career focus: Lattice or Leapsome.
- Run 1 pilot cycle with 5 to 10 people
- Time how long it takes per manager.
- Check if people understand the questions.
- Adjust templates after that pilot.
Ballpark pricing you will see for these tools is often in the 5 to 12 USD per user per month range for performance modules for a team your size, so budget something in that area.
Big tip from my own screwups
- Spend more time on good questions and a simple process than on fancy features.
- Keep templates short so people do them on time.
- Make sure every review ends with written goals and one follow up date in the system.
If you post what you want most, like reviews only vs reviews + goals + HR, folks here can narrow this to 1 or 2 strong fits.
+1 to a lot of what @caminantenocturno said, but I’d actually start even simpler for <50 people before jumping into the “people platforms.”
If your main pain is “spreadsheet + email chaos” and not “we need deep analytics and OKRs,” I’d look at:
- Trakstar Perform (formerly Reviewsnap)
Very review-centric, not a whole culture OS.
- Strengths: Dead simple cycles, reminders, basic goals, 360s.
- Weakness: UI feels older, less shiny than Lattice / 15Five.
Good if you just want reviews to run on rails and stop chasing people.
- Small Improvements
Feels lighter and less “enterprise HR.”
- Strengths: Reviews, 1:1s, objectives, praise. Easy to grok, good for tech & creative teams.
- Weakness: Not a full HRIS, reporting is fine but not fancy.
Nice middle ground between “Google Forms” and “HR mothership.”
- Culture Amp (performance only)
Slightly disagree with the “might be overkill” angle people often have for <50. If you can afford it, it’s actually very friendly for smaller teams.
- Strengths: Great question banks and templates, very clear flows, good 360s.
- Weakness: Pricing can sting at small headcount, more stuff than you may need.
Best if you want high quality review content and are ok paying for it.
- The ultra-light route: Notion + a cheap automation tool
If budget is tight or you’re tool-averse, one contrarian take:
- Put your review templates in Notion
- One page per employee, archive per cycle
- Use something like Zapier/Make + email/Slack to remind people and collect self-reviews via a simple form
This is not as pretty as Lattice, but it is a huge step up from random spreadsheets and costs almost nothing.
A few opinions that go slightly against the grain:
- Don’t start by buying “engagement + goals + feedback + HR + reviews.” You’ll use 30% of the features and confuse people. For a first year, get reviews & simple goals working, then layer in extras.
- Avoid tools that require weekly check ins unless your culture already has that habit. Otherwise it just becomes another form people resent.
- For <50, admin effort matters more than feature depth. One clear dashboard showing “who started / submitted / is late” saves you more time than a sophisticated 9-box grid you’ll never open.
If I were in your shoes and wanted something boring and reliable:
- Need only reviews + light goals: Trakstar Perform or Small Improvements
- Want very polished templates and 360s: Culture Amp (if budget ok)
- Want almost-free but less automated: Notion + forms + reminders
Whatever you pick, keep your first cycle tiny: 5–7 questions max, one overall rating if you really need it, and a mandatory “3 priorities for the next 6 months” field. Fancy features won’t fix a bloated form.
Short version: before picking a tool, fix your “system.” For <50 people, the software should fit the process, not the other way around.
I slightly disagree with @waldgeist and @caminantenocturno on one thing: even “light” tools can feel heavy if you import your messy process into them. You can absolutely drown 40 people in Lattice or Culture Amp if your forms and cycles are overdesigned.
Here’s a different angle.
1. Decide your real minimum feature set
Given your size, I’d prioritize:
- Automated reminders so you stop chasing people
- One simple workflow: self review → manager review → sign off
- A central history per person so you can ditch spreadsheets
- Lightweight goals (3 to 5 per person max), not full OKRs
- Basic exports to CSV/PDF for your records
Skip for now:
- Deep OKR platforms
- Complicated 9‑box and calibration features
- Heavy engagement survey suites
2. About the “product title” you mentioned
You referenced Need performance review software for a small company I run a small company with under 50 employees... as a kind of product / solution concept, so I’ll treat it like the idea of a very small‑company focused performance tool.
Pros for a tool positioned like that:
- Typically simpler setup than Lattice / Culture Amp
- Pricing more aligned with <50 headcount
- Less clutter: usually just reviews, light goals and maybe 1:1 notes
- Easier to roll out without a full‑time HR or People Ops person
- Often weaker reporting and analytics
- Fewer integrations with other systems
- Might lack nice extras like calibration, talent mapping, or robust 360 libraries
- If you grow past ~100 people fast, you may outgrow it
If you can find an actual product that matches that description, it should sit in the same competitive space as:
- Trakstar Perform / Small Improvements style tools that @caminantenocturno mentioned
- PerformYard / 15Five’s performance module that @waldgeist called out
3. Where I’d zig instead of zag
- I would not start with weekly check‑ins unless managers are already good at regular 1:1s. Otherwise it becomes homework and people game the system.
- I would give up on 360s for the first cycle unless your culture is very feedback‑mature. 360s are admin‑heavy and can revive your email chaos if people get confused.
- I’d keep ratings brutally simple: maybe a 3‑point scale (Below / Meets / Exceeds) plus 1 text box per core area.
4. Concrete setup that works for most <50 teams
- Two review cycles per year
- Template structure per employee:
- 3 short questions for self review
- 3 for manager
- 1 “future” question: “What are the 3 priorities until the next review?”
- Every review must end with 3 documented priorities in the system
- Tool handles: scheduling, reminders, locking forms after sign‑off, keeping history
If the tool you pick (whatever its name) cannot make that specific flow easy, look elsewhere even if the marketing looks perfect.
5. How to choose in 1 week
- Shortlist 3 tools: for example one like the “small‑company performance review” concept, one more feature‑rich like Lattice / 15Five, and one barebones like Trakstar Perform.
- Run test cycles with 2 managers and 3 employees. Literally time how long it takes them.
- Ask them 2 questions:
- “What confused you?”
- “What would make you dread doing this twice a year?”
Pick the tool where people are least confused and least dreading the next round, even if it is not the fanciest.
You are not shopping for features. You are buying back your time and your team’s willingness to actually complete reviews on schedule.
