NetSpot WiFi Scanner vs Ekahau for small office setup?
I’m setting up WiFi in a small office and I’m torn between using NetSpot WiFi Scanner and Ekahau for site surveys, troubleshooting dead zones, and planning access point placement. I’d really appreciate real‑world feedback on which tool offers better value, ease of use, and accuracy for a non‑enterprise user so I don’t overspend or choose the wrong software.
I bounced between Ekahau and NetSpot for a while for Wi‑Fi surveys, so here is how it played out for me.
Ekahau felt like bringing an entire data center toolkit to fix an office AP. Tons of knobs, lots of reports, licensing tied to hardware, and a price tag that only made sense when I was doing work for larger clients with existing budgets. It did the job, but every time I opened it I had to mentally prep for it.
NetSpot was the one I ended up keeping on my own laptop.
What I liked in day to day use:
  1. Pricing and scope
I did not need an annual line item approved to use it. For small offices, coworking spaces, clinics, retail, and my own home setup, NetSpot covered the basics without me arguing with accounting. If you are not servicing stadiums, airports, or multi‑building campuses, the cheaper tool usually wins.
Site: https://www.netspotapp.com/
  1. Setup and learning curve
With Ekahau, the first week was me reading docs and watching tutorials. Once you get used to it, it is strong, but it expects you to live in it.
With NetSpot, I installed it, loaded a floor plan, walked the site with a laptop, and had usable heatmaps in under an hour. No special hardware, no odd licensing dongles, no “where is that setting buried” moment.
  1. Features that mattered for me
Here is what I ended up using most in NetSpot:
• Heatmaps for RSSI, noise, SNR
• Quick visualization of dead zones and overlap
• Channel usage overview to spot dumb auto‑channel behavior
• Simple reports I could hand to non‑technical managers
What I did not miss from Ekahau for small jobs:
• Heavy predictive modeling with super detailed wall types
• Advanced multi‑floor interference planning
• Huge compliance‑style reports
If you are designing a multi‑AP deployment for a warehouse with scanners, forklifts, and roaming requirements across floors, Ekahau earns its cost. For a normal SMB office, that level of depth felt like overkill.
  1. Who I think NetSpot fits
From my own use, NetSpot made sense in these cases:
• One to twenty AP environments
• MSPs doing periodic Wi‑Fi checkups
• IT staff in small or medium offices
• Power users fixing their home Wi‑Fi without wasting a weekend on training
If you handle large, critical Wi‑Fi infrastructure, you will likely still want Ekahau in your toolbox. If your work looks more like “make sure this office floor has good Wi‑Fi” rather than “optimize roaming across thousands of clients”, NetSpot is easier to live with.
Video reference
If you want to see it in action before touching anything, this video helped someone I work with get comfortable:
I would not call any of these tools perfect, but if I had to pick one for most day jobs and home setups, I reach for NetSpot first.
I land a bit differently than @mikeappsreviewer on a few points, so here is another angle.
Short version. For a normal small office, NetSpot App is usually the better fit. Ekahau makes sense if you need formal design work or you manage more than one site and need strong documentation.
Here is how I split it in practice.
  1. Budget and licensing
    Ekahau:
  • High upfront cost plus support.
  • Tied to their sidekick hardware for best results.
  • Makes sense if you bill WiFi work to clients or have a dedicated network budget.
NetSpot App:
  • One time cost that finance does not argue about much.
  • Runs on your laptop, no special hardware needed for small jobs.
  1. Learning curve and workflow
    If you only touch WiFi tools a few times a year, Ekahau feels heavy. You lose speed between projects, then you re learn the workflow.
    NetSpot App is closer to “open, walk, get heatmap, fix AP placement.” Good when you are juggling other IT tasks.
  2. What you actually need for a small office
    If your office is something like:
  • One floor
  • Under 20 APs
  • Standard drywall, some glass
  • Typical laptops and phones, maybe a VoIP system
NetSpot App covers:
  • Post install survey to see RSSI, SNR, noise.
  • Find dead zones and spots with too much overlap.
  • Validate 5 GHz coverage and see if 2.4 GHz is too crowded.
  • Simple “before and after” screenshots for management.
Where I disagree slightly with @mikeappsreviewer is on predictive design.
I have had small offices where:
  • There was dense concrete or metal racks.
  • Few APs, but coverage needed to be tight for WiFi calling or handheld scanners.
In those cases, Ekahau’s wall modeling and predictive design saved me a second site visit. I placed APs on the plan, tweaked wall types, then did a light survey after install. That avoided extra ceiling work.
  1. When I would pick Ekahau for a “small” office
  • You must support latency sensitive apps like voice over WiFi with roaming.
  • There is a legal or compliance requirement to document design and validation.
  • The building has odd shapes, multiple suites, or thick structures where trial and error is expensive.
  • You manage many “small” offices for a client and want consistent design standards.
  1. Practical advice for your case
    If this is your own office or a single client site:
  • Start with NetSpot App.
  • Do a quick passive survey after you hang a few APs.
  • Look at RSSI and SNR. Aim for at least around -65 dBm and SNR above 20 dB in work areas.
  • Fix channels and transmit power, then rescan.
  • Only step up to Ekahau if you hit issues you cannot explain, or if you know you will repeat this work across many sites.
If you expect WiFi design to turn into a recurring service line for you, learning Ekahau early pays off. For one or two small offices, it tends to feel like bringing a full broadcast truck to record a Zoom call.
For a small office, I’d look at it this way:
@​mikeappsreviewer and @​codecrafter already covered the “feel” of both pretty well, so I’ll just poke at some edges they didn’t lean on as much and slightly disagree in a couple spots.
1. What actually bites you in a small office
The real problems I see in <20 AP offices are usually:
  • Terrible channel planning (everything on 1/6/11 in 2.4, 5 GHz on auto chaos)
  • APs cranked to full power so clients cling to the wrong AP
  • One or two dead pockets everyone complains about near conference rooms
  • No one wants to pay for a “proper” design, they just want “make WiFi not suck”
For that world, Netspot App is usually enough. It lets you:
  • Walk the floor with a laptop
  • See RSSI / SNR heatmaps
  • Spot the “too hot” overlap zones and the dead spots
  • Grab simple screenshots to justify “we need 1 more AP here” to management
You don’t need Ekahau-level RF nerd knobs to fix that class of issue.
2. Where I actually disagree with the Ekahau love
People often oversell predictive design for small offices. Yes, Ekahau’s wall modeling is nice, but in a typical SMB floor with drywall, glass, and maybe one elevator shaft:
  • A quick rough placement, then a Netspot App survey after install, is usually faster and cheaper than trying to model every wall type perfectly.
  • You often end up adjusting APs after real users show up anyway, because furniture, people and doors change the RF more than your pretty model.
I only reach for Ekahau in “small office” scenarios when:
  • There are multiple floors with weird shapes and you need roaming to be really clean for WiFi calling
  • You’re producing a formal design doc for a client who will ask “why here?” for every AP
  • You know you’ll replicate that design pattern across a bunch of near-identical sites
Otherwise, the prediction work can feel like doing CAD to hang a single picture frame.
3. Hardware & workflow reality
One thing not stressed enough: the friction of the tool matters.
  • Ekahau + Sidekick is fantastic technically, but it’s bulky, needs charging, license management, firmware, etc.
  • Netspot App lives on your existing laptop, no dongles, no “where did I put that thing.” That means you’re actually more likely to run quick surveys after changes, which is way more valuable over time than a single perfect design day.
I’d argue that for someone who wears many IT hats, the tool you actually use monthly beats the “perfect” tool that sits in a case.
4. How I’d decide for your specific situation
If your office is:
  • Single floor (or simple 2‑floor)
  • Typical drywall
  • Mix of laptops / phones / a few VoIP handsets
  • No formal SLA or compliance pressure
Then:
  1. Get Netspot App.
  2. Rough in APs where you logically expect coverage (open areas, near conference rooms, avoid right on top of each other).
  3. Do a passive survey: check for
    • RSSI around -65 dBm or better where people work
    • SNR above ~20 dB
    • No crazy co‑channel overlap on the same channels
  4. Adjust channels and transmit power, maybe move or add one AP, resurvey quickly.
If you tell me instead:
  • “We’ve got a lot of WiFi calling and barcode scanners that roam between floors”
  • or “Legal is asking for design & validation reports they can file away”
  • or “This is the first of 15 similar branch offices we’re rolling out”
Then yeah, bite the bullet, learn Ekahau, and lean into its documentation and predictive work. In that scenario, the overhead starts to pay back.
5. Very blunt summary
  • For one small office and basic “fix the dead zones, stop the random drops”:
    Go with Netspot App and spend the saved money on one more well placed AP.
  • For a small office that behaves like a mini campus (voice over WiFi, strict roaming, repeatable design, or compliance docs):
    Then Ekahau makes sense, but that’s the exception, not the rule.
Netspot App plus a bit of common sense RF hygiene solves 90% of small office pain without turning you into a full‑time WiFi engineer.
