Packing a MacBook kit for long-term travel and World Cup 2026
I’m planning long-term multi-country travel and also want to be ready for FIFA World Cup 2026, but my MacBook setup is getting harder to pack efficiently. I’ve already realized I may be carrying too many chargers, adapters, and accessories, and I’m worried about weight, airport security, and staying powered in different countries. I need help figuring out the best minimalist MacBook travel kit for international travel, remote work, and match-day mobility.
I’m putting together my MacBook travel setup for a long stretch abroad, a few countries, lots of trains and flights, and a stop for the 2026 FIFA World Cup. I’ve been trimming it down to stuff I know I’ll use, not random apps I install once and forget.
The MacBook stays in the bag because it handles the boring but important stuff better than my phone. Tickets, backups, maps, video dumps, weather checks, all easier when you’ve got a real screen.
Here’s the short list I’d bring.
Google Maps offline areas
Download the city maps before you leave your hotel or apartment. I learned this the annoying way after losing signal in a crowded transit area. Offline maps saved me from wandering in circles with 3 percent battery left.
1Password
I keep passport scans, visa copies, booking details, and ticket screenshots in one place. If your inbox is a mess, this helps. If your connection is bad, this helps more.
Essential if you want your travel docs easy to reach without digging through old emails.
TripIt
Forward confirmation emails and it builds one itinerary out of the pile. Flights, hotels, match tickets, all lined up. I used to keep this stuff in notes and screenshots. Bad system. This is cleaner.
TripIt also works offline, which matters more than people think when you’re standing at check-in or border control with weak service.
The Weather Channel
Not fancy, still useful. I check it the night before and again in the morning. Outdoor matches turn into a dumb experience fast if you pack wrong. I’ve carried a jacket all day for no reason, and I’ve also been stuck without one. You only do both a few times before weather becomes part of the routine.
Elmedia Player
This one earns its spot. macOS still gets weird with some video formats, especially when you’re moving clips over from phones, cameras, or old downloads. I used this media player for your Mac because it opened files without me doing cleanup first.
Good for flight downloads, phone footage, random match-day clips, whatever you dragged onto the MacBook at 1 a.m. It also helps if you want to throw video onto a TV later in a hotel or Airbnb. Not something I use daily, but when I need it, I need it now.
Deezer or Spotify
Download playlists and podcasts before you leave. Streaming on the road sounds fine until you hit dead zones, airport Wi-Fi, or roaming limits. I keep a few long playlists saved locally and a couple podcasts for long transfers. Makes delays less miserable, tbh.
DeepL
For translation, I trust DeepL more than a lot of built-in options I’ve tried. It’s good for signs, menus, short chats, and those weird instructions posted in train stations or apartment buildings. Download the language packs first. Offline access matters way more than perfect phrasing when you’re tired and trying to find the right platform.
MacDroid
If you use Android with a MacBook, this fixes a dumb problem Apple never cared to solve well. This one lets you mount the phone in Finder and move photos or videos over without fighting your setup.
I’d use it for backing up stadium videos and travel photos at the end of the day. USB is the part I like most, because hotel Wi-Fi is often trash, and sometimes you do not want to wait on cloud uploads. Wi-Fi transfer is there too if your connection is decent.
If I were packing today, this is the core set I’d start with. It covers navigation, documents, translation, media, weather, and backups, which is most of the trip right there. Safe travels, and yeah, the World Cup part sounds unreal.
Trim the hardware first. Apps are easy. Weight is the real problem.
I’d pack your MacBook kit like this.
  1. One charger for all devices.
    Use a 65W or 100W GaN charger with 2 to 4 ports. Anker, Ugreen, Baseus, stuff like that. A 100W brick usually covers MacBook, phone, watch, earbuds at once. You do not need Apple’s big brick unless your model pulls a lot of power under load.
  2. Two cables, not five.
    Bring:
    USB-C to USB-C, 2m, for desk or airport use.
    Short USB-C cable, for power bank or phone.
    If your iPhone still uses Lightning, bring one tiny adapter, not a full extra cable.
  3. One plug adapter.
    Get a compact world adapter with US, EU, UK, AU. Skip the giant cube if it weighs a ton. Check if it supports grounded plugs.
  4. One hub, or none.
    A lot of people overpack dongles. If your MacBook use is charging, backup, and occasional HDMI, bring one small USB-C hub with HDMI, USB-A, SD, pass-through power. If you do not use SD cards, skip it. Dead weight is dead weight.
  5. Power bank matters more than people admit.
    For trains, stadium lines, delays, and sketchy outlets, a 20,000mAh USB-C PD bank earns its space. Pick one under airline limits. Most are fine under 100Wh.
I slightly disagree with @mikeappsreviewer on keeping the MacBook for everything. For match day, your phone should do 90 percent of the work. The MacBook is for backup, uploads, bookings, and fixing problems at night in the hotel.
My packing list would be:
MacBook
1 GaN charger
2 cables
1 world adapter
1 small hub
1 power bank
AirPods or wired earbuds
Optional SSD
For storage, I’d bring a 1TB SSD over a stack of flash drives. Smaller, faster, less annoying. If you shoot on Android, MacDroid is worth having on the MacBook. Wired transfer beats waiting on bad hotel Wi-Fi, espiecally after a long day.
One more thing people forget. Label your charger and adapter. Hostels and media rooms eat black cables for breakfast.
I’d trim by role, not by device count. That’s where I differ a bit from @vrijheidsvogel. A world adapter + hub + charger + power bank can still turn into a cable nest fast if every item does overlapping jobs.
My rule:
  • In-seat kit: phone, earbuds, short cable, power bank
  • Hotel desk kit: MacBook, one charger, one long cable, maybe SSD
  • Stadium kit: phone only unless you’re actually working
Also, I would not bring a big hub unless you already use it weekly. Tiny USB-C adapters are less annoying. HDMI is overrated for travel tbh. Most hotel TVs are a pain anyway.
One thing @mikeappsreviewer didn’t really hit is organization. Put all MacBook gear in one zip pouch with elastic loops. Cables loose in the bag are how stuff gets lost or broken.
What I’d actually pack:
  • MacBook
  • 1 compact GaN charger
  • 1 long USB-C cable
  • 1 short USB-C cable
  • 1 country adapter or slim world adapter
  • 1 SSD
  • 1 power bank
  • wired earbuds backup
If you’re on Android, MacDroid is a legit add. Makes Mac to Android file transfer way less stupid, especially for dumping photos and match videos without relying on garbage hotel Wi-Fi. Small app, useful job.
Biggest mistake is packing for imaginary scenarios. Pack for your real habits, not your fantasy command center setup.
I’m with @vrijheidsvogel on cutting weight first, but I slightly disagree with @reveurdenuit on tiny adapters over a hub in every case. If you ever need SD + HDMI + USB-A in one day, one good mini hub is actually less annoying than three separate bits.
What I’d add is this: pack for failure points, not just daily use.
  • backup card for payment/tickets
  • offline copies of passport, visas, insurance
  • one cable that can also do data, not just charging
  • one way to charge when outlets are blocked or dead
For World Cup travel specifically, I would split tech into 3 pouches:
  1. Transit pouch
  2. Sleep/work pouch
  3. Match-day pouch
That stops the full bag explosion every time you move hostels or clear security.
On MacBook setup, my unpopular opinion: leave the mouse unless you truly work long sessions. Trackpad wins for travel.
If you use Android, MacDroid is worth a look.
Pros
  • easy wired transfer to Mac
  • faster and more reliable than bad hotel Wi-Fi
  • useful for photo/video dumps
  • another paid utility to maintain
  • less useful if you already live in cloud storage
  • wired-only advantage depends on carrying the right cable
So yeah, I’d combine the hardware minimalism from @vrijheidsvogel, the app logic from @mikeappsreviewer, and the role-based packing from @reveurdenuit, but I’d organize around what happens when travel gets messy, not when everything works.
