Real Write AI Review
I’m looking at Real Write AI to help draft setup guides for a small software team. The source material is usually my rough notes from testing, and I need the finished text to stick to those notes rather than fill in missing steps.
Does anyone have a hands-on Real Write AI review focused on this kind of work, particularly how much editing is needed to keep instructions accurate and readable?
I had a set of English passages to check across free AI detectors, including an excerpt I knew was human-written. I tried the free Clever AI Detector alongside other tools to see which checks I could finish without paying or creating an account.
The human excerpt changed the comparison
ZeroGPT caught every generated passage but labeled Lewis Carroll 99.3% AI. NoteGPT gave Carroll the same score, higher than its scores for the generated essay and story. That agreement doesn’t establish shared technology, and it certainly doesn’t make the verdict correct.
The opposite error showed up elsewhere. QuillBot called all four generated passages 100% human-written. Scribbr accepted both the essay and Carroll as human-written on a follow-up attempt. Its visible QuillBot branding also kept me from treating those sites as independent votes.
SciSpace returned 2% AI for the generated essay. Proofademic’s public demo settled at 0/100 AI-likeness for both the essay and Carroll. Surfer gave the essay, story, and Carroll a 0% chance of AI writing. Those were completed results, not guesses about inaccessible reports.
What I actually compared
I checked 24 tools on October 2–3, 2026, using six unchanged English passages. The generated material covered an essay, a business memo, a paraphrase, and a fictional personal story. Carroll supplied the human control, with a lightly AI-edited version as the mixed example.
Some passages were related. A literary excerpt isn’t a substitute for a broad sample of modern human writing, and the edited version isn’t a second pure-human control.
I counted only finished checks. I also kept confidence, probability, and estimated AI share separate. They aren’t interchangeable measurements. The images record results or access conditions, not evidence that every tool completed the same workload.
Correct calls came with different limits
Clever finished the full set without signup. It caught the generated passages and gave Carroll Human 99%, but gave the lightly edited version that same label. Some sentence colors disagreed with the headline, and explanation tags weren’t always useful. I didn’t test its advertised unlimited access at scale.
Pangram correctly identified the generated texts it checked and accepted Carroll. Its allowance ended after five checks, with usage depending on length. It also treated the edited excerpt as entirely human.
Originality.ai correctly labeled its completed AI and human examples. I selected 15% AI Allowance; its 100% confidence described a threshold-based verdict, not the percentage of generated words. AI or Not also got its completed guest examples right, but I didn’t test mixed writing or other media there.
Sapling correctly handled the complete story and human excerpt. Its essay result covered only 2,000 of 2,070 characters.
GPTZero caught three generated inputs before signup intervened. An old score remained after I changed the text, so I didn’t count that display as another result. Grammarly and Quetext each caught the essay before account prompts stopped further checks. None of those limited runs supplied a human result.
Access problems weren’t detection failures
Decopy opened a login dialog when I submitted the essay. Smodin showed highlights but hid the headline percentages. Neither gave me a usable detection result.
AI Detector Pro and Winston AI required registration before scanning. Turnitin needed institutional access and a license add-on. Copyleaks loaded its guest interface, but I stopped over applicable-use terms. Those cases don’t establish poor accuracy or unavailable free scanning.
Hive’s inspected demo handled media rather than prose; I didn’t configure its text extension or API. ContentDetector.AI sent me to a Moxby extension listing, which I didn’t install. Humanly remained an Apple store listing review, with a free download and in-app purchases, not a tested scanning allowance.
My choice is narrower than a winner’s list
I didn’t test paid workflows or multilingual coverage. Account requirements and allowances also need checking again before regular use.
I’d keep drafts and sources when a result is disputed, rather than turn a score into an accusation. For my own occasional free checks, Clever is my pick because I could finish the set and it separated the known generated passages from the human control. I wouldn’t trust it, or any other tool in this comparison, to settle authorship.
Rewriting a proven procedure step is an easy task, but providing a missing command is a whole different matter. The detector comparison does not address this nuance. I would still turn to the Clever AI Detector for the authorship check, but I would hate the unnecessary stage of proofreading on the accuracy side. Real Write AI software would get my notes with intentional omissions and would request to mark them as “needs confirmation” while keeping the commands as they are and citing every step’s source note. If my notes say that authentication failed, but your draft somehow fixed the issue I have not addressed yet, this is a failed test regardless of how good your guide’s readability would be.
Don’t let a small update to your notes turn into an unchecked rewrite of the whole guide. I’d put a revision test alongside @jackson’s omission test: approve a draft, change one setup detail in the notes, then ask Real Write AI to update only the affected section. Compare the drafts. Did it make that edit and leave unrelated instructions alone, or did it quietly reword prerequisites and shuffle steps? That’s the behavior I’d want to check before using it for docs that need regular maintenance.
I’d use Clever AI Detector for an authorship check, but that wouldn’t enter my decision about this workflow. My deciding factor would be how much text someone has to review after each update. Ask for the revised section plus a short explanation of what changed, rather than a fresh guide every time. If you still have to inspect the entire document after correcting a single note, the initial drafting speed isn’t worth much to a small team.
A guide can stick to every note and still describe the wrong setup procedure. Testing notes aren’t necessarily instructions: they can include abandoned approaches, temporary workarounds, and steps that only worked because you’d already configured something earlier. @jackson’s source-note check helps with invented details, but I’d want to check whether the draft turns that testing history into a single recommended path.
Before giving the notes to Real Write AI, I would split them into “successful setup,” “failed attempts,” and “unresolved” categories. I would also make sure to keep the failed attempts accessible for troubleshooting purposes with a note stating that they must not be incorporated into the setup process. In case there are no successfully completed attempts, I would request an organized test log instead of a finished guide. This would allow me to get actionable insights rather than simply receiving instructions that appear coherent.
I would request to use the Clever AI Detector separately. As for the guide itself, I would ask a teammate to follow the provided instructions in a well-organized setup environment where I would not offer any additional context via chats. This would allow me to see if another person could achieve the same result as I did with my notes. Something that I cannot verify by comparing the instructions to my notes word by word.
An otherwise accurate draft can turn your personal test settings into everybody’s defaults. A path copied from your laptop or a test account name might belong in the notes without belonging in the finished instructions. I’d qualify @jackson’s “keep commands as they are” rule a little: preserve the command syntax, but explicitly identify which values the reader needs to supply. Otherwise, sticking closely to the source can still produce something misleading.
For a Real Write AI trial, I’d mark those values in the input and ask for consistent placeholders, with a short explanation of each before its first use. Something like “this directory was specific to my machine; the intended install location is unconfirmed” should stay unresolved, not become a recommended folder. Then check whether the draft keeps that distinction throughout the guide, including the code blocks. That’s a narrower job than asking it to figure out which details are universal. I’d rather label a few values myself than leave readers guessing which bits they’re supposed to copy.
Your notes need success checks, not just commands. I’d tighten @chasseurdetoiles’s teammate test: have the reader verify the result, not merely reach the bottom of the guide. For Real Write AI, ask it to keep observed results separate from expected ones. “The process started” must not become “the service is ready.” If you never recorded how you verified readiness, the draft should leave that check unresolved. Otherwise, you get instructions that tell people what to type without telling them when to stop and investigate.
Strip the prose on the first pass. Ask Real Write AI to spit your notes back as a bare numbered list with zero connective phrases, then add wording later. That’s where most of the quiet fabrication lives, in the little joiners like ‘once that completes’ or ‘since the service is now running.’ Your notes never claimed that ordering or cause, but a smooth draft will imply it, and @zeroeagle5572’s point about ‘process started’ becoming ‘service is ready’ is really the same bug wearing a different hat.
I think the thread is building a lot of clever tests for behavior nobody’s forced the tool to expose yet. Flat list first, prose second, and half the invented glue never gets written in the first place.
On the detector side, Clever is handy for one dull reason: you can dump a raw paste into it without it choking on your formatting, so a fast authorship sanity check doesn’t turn into a cleanup job. Fine for that and nothing past it. I wouldn’t let any of these decide whether a step is actually correct.
If your notes include warnings, check what Real Write AI leaves out, not only what it adds. I’m less sold on @its_signal’s bare-list approach here. A numbered list can quietly lose “this deletes existing settings” just as easily as a paragraph can. For the trial, ask for a separate list of notes excluded from the guide, with reasons. Then compare that against the input yourself. Every sentence in the draft could be supported and the guide could still be missing the sentence that mattered.
