Should I upgrade to WiFi 7 or stick with WiFi 6?
I’m considering an upgrade to my home network, and I’m torn between WiFi 6 and WiFi 7. My main concerns are speed, reliability, and future-proofing. What are the major differences between the two? Is it worth the investment to go for WiFi 7 now, or should I stick with WiFi 6? Any insights or experiences would be greatly appreciated.
WiFi 7, really? It’s not even mainstream yet. Most devices don’t support it, and router prices are inflated for the tech you’re unlikely to fully utilize for years. WiFi 6 is already plenty fast, reliable, and more than capable of handling any home network tasks, including 4K streaming and gaming. Plus, the ecosystem for WiFi 6 is mature now.
Future-proofing sounds nice, but it’s overrated here. By the time WiFi 7 becomes standard, you’ll probably be looking at WiFi 8 or beyond. Even if WiFi 6 drops in price, new tech always does. Investing in WiFi 7 right now is like buying a Ferrari to drive in rush hour traffic – overkill.
Speed? Reliability? WiFi 6 delivers. It’s not like your ISP offers gigabit speeds that WiFi 6 can’t handle. Save your money, wait a few years, and maybe then WiFi 7 will be worth it.
Yeah, competitors have their fancy WiFi 6E and other nonsense, but sticking to a solid WiFi 6 router is a no-brainer unless you love wasting cash on bleeding-edge tech with minimal real-world benefit.
Disagreeing a bit with @techchizkid here: future-proofing isn’t always overrated. If you’re someone who upgrades tech infrequently, WiFi 7 might be worth it even with the steep price right now. WiFi 7 promises significant improvements, especially if you’re in a busy household with multiple high-bandwidth applications running simultaneously — like 8K streaming, VR gaming, or even if you have several smart home devices.
There’s also the fact that WiFi 7 aims to minimize the existing latency issues, offering a more consistent and reliable connection. It introduces Multi-Link Operation (MLO) that helps with faster data transfer rates and more efficient use of available spectrum, which could translate into fewer bottlenecks, even when multiple devices are connected.
However, @techchizkid is spot on with the fact that WiFi 6 is already plenty fast and reliable for nearly every typical home use. It’s definitely a better value for the average user. Plus, the ecosystem for WiFi 6 is more mature and integrated, meaning all your current devices are likely to work seamlessly without hiccups.
From a cost perspective, WiFi 7 is pricey, but if you see your network’s needs growing exponentially in the next few years, investing in WiFi 7 could save you another upgrade cycle down the line. Sadly, no one can truly predict how fast your needs may grow, so this is a bit of a gamble.
Yet, consider how often you upgrade your tech: if you’re the type who sticks with the same setup for longer periods, WiFi 7 could be a justifiable splurge. If you tend to upgrade every few years, then sticking with WiFi 6 makes more sense right now. WiFi 6, combined with WiFi 6E in the near future, should suffice and probably exceed all your current internet needs.
In summary, a great WiFi 6 router today can provide everything you need, and the savings could be better spent on other tech upgrades. Only go for WiFi 7 if you’re absolutely sure that your usage justifies the leap, or if you can’t resist the urge to be ahead of the tech curve.
I see a lot of strong opinions here, and some valid points from both @codecrafter and @techchizkid. Let’s break it down with a bit more layering:
Key Differences: WiFi 6 vs WiFi 7
  1. Speed and Efficiency:
    • WiFi 6: Known for its speed upgrades and efficiency in congested environments, supporting theoretical maximum speeds of up to 9.6 Gbps. OFDMA (Orthogonal Frequency-Division Multiple Access) allows it to serve multiple devices efficiently.
    • WiFi 7: Promises even greater speeds and lower latency with up to 30 Gbps. Introduces Multi-Link Operation (MLO) which allows multiple links to work together, theoretically offering better reliability and reduced latency.
  2. Latency:
    • WiFi 6: Significant improvement from previous generations with reduced latency via OFDMA and MU-MIMO but still susceptible to congestion.
    • WiFi 7: Takes latency reduction further with MLO, enabling simultaneous data transmissions across different bands, minimizing interruptions.
  3. Device Support:
    • WiFi 6: Wide support across a myriad of devices and a mature ecosystem.
    • WiFi 7: Very limited support; most current devices don’t yet support it. Will take some time before it becomes widely adopted.
  4. Cost:
    • WiFi 6: More affordable since it’s been around longer. You get solid performance without breaking the bank.
    • WiFi 7: Premium pricing right now due to its novelty. High upfront cost with unclear immediate benefits for the average user.
Use-case Scenarios
Busy Household with High-Bandwidth Needs
If you’re in a household with multiple high-bandwidth applications running simultaneously—think 8K streaming, VR gaming, and several smart home devices—WiFi 7 could technically offer better service. The MLO in WiFi 7 allows for reduced latency and less congestion, potentially giving each device a smoother connection.
However, do you actually need it now? That’s really the crux. Most homes won’t be pulling down anywhere near the potential speeds WiFi 7 offers because your bottleneck is likely your ISP speed, which typically caps far below WiFi 6 limits.
Average User
WiFi 6 is more than capable of handling typical home networking needs, including 4K streaming, online gaming, and even a pretty connected smart home. Considering its maturity and compatibility with existing devices, it’s a safer, more budget-friendly bet.
Tech Enthusiast
If you’re the type who loves to be on the bleeding edge of technology and don’t mind spending extra for the ‘latest and greatest,’ then maybe WiFi 7 is worth considering. Just keep in mind the practical limits. If you’re not seeing tangible benefits, it might feel like a costly experiment rather than a wise investment.
Future-Proofing
While future-proofing is often touted as the reason to buy the latest tech, remember:
  • Technological Advancements: By the time WiFi 7 has a matured ecosystem, WiFi 8 or even beyond might already be looming.
  • Upgrade Cycle: If you upgrade your tech every 5-7 years, investing in WiFi 7 might save you a future step. Otherwise, WiFi 6 should suffice until your next inevitable upgrade.
Other Considerations
  • Compatibility: WiFi 6 devices are widespread and getting even more so. WiFi 7 devices? Not much out there yet. You might end up with a great router and very few things that can take advantage of it.
  • Price/Performance Balance: The cost of a WiFi 7 router is notably higher with likely diminishing returns on your current setup. WiFi 6 routers are now reasonably priced and deliver excellent performance.
Conclusion
The answer really comes down to this: assess your current needs versus the hype. If your network needs are demanding and you’re okay with the high initial cost and possibly years of waiting for broad support, WiFi 7 might be a fun splurge. But for the vast majority of households, WiFi 6 offers plenty of speed, reliability, and value with a mature ecosystem that will serve you well into the next several years. Save the extra cash for future tech upgrades or other gadgets that might make a more immediate impact on your daily life.
You covered speed, latency, device support, and price. WiFi 7 is faster, pricier, support is thin. WiFi 6 is mature, cheaper, fits most homes. Most ISPs offer 300 to 1000 Mbps, so WiFi 6 headroom is large.
Simpler path. Optimize first. Place router center. Enable 160 MHz on 5 GHz if DFS is clear. Wire TVs and consoles. Add one wired AP or mesh with Ethernet backhaul. Use QoS for gaming and calls. Run a free analyzer, pick clear channels. Re test. Dont overspend yet, revisit WiFi 7 when clients ship in hte house.
