What are the best Anydesk alternatives for Mac?
I’m searching for a reliable alternative to Anydesk for my Mac. I need it for remote access and troubleshooting tasks as my current Anydesk setup has started glitching frequently. Any recommendations or help would be appreciated!
Oh, I completely get where you’re coming from. At one point, I felt like I had exhausted every option trying to find the right tool. For example, I gave AnyDesk a spin—worked decently enough—but it kept flagging me with those pesky “commercial use” warnings, which totally wrecked the flow. Then I turned to RustDesk. It’s a solid choice for sure, but if you’re not hosting it yourself, setting it up can feel like more of a headache than it’s worth.
Eventually, I came across HelpWire, and honestly, it’s been a game-changer for me. It’s compatible with both Windows and Linux, which is a big deal if you’re juggling different operating systems. Plus, it doesn’t throw in those unwanted session timeouts that some platforms do, which is such a relief. The setup process? Smooth as can be—practically plug-and-play. Best part? No annoying ads bombarding you or any unnecessary “helpful suggestions” cluttering the experience. If you’re still hunting for the perfect solution, this one might seriously be worth considering.
I hear ya—AnyDesk glitches can be the most frustrating thing. If you’re exploring alternatives for Mac remote access, I’d recommend checking out a few solid options that might suit your needs better. Let’s break it down:
  1. TeamViewer: Yeah, yeah, it’s the big guy everyone knows. But if you’re okay with a slightly bloated platform (and let’s be real, some nagging upgrade prompts), it’s rock-solid for troubleshooting across multiple devices. Plus, it’s pretty intuitive even for non-techy clients you’re helping out. However, lately a lot of users have been complaining about false “commercial use” detections for personal use, which can lead to annoying session limits and restrictions.
  2. SplashTop: Honestly underrated. Super smooth for personal and corporate use alike. They’ve got great performance, secure access, and you can even tweak between different devices like desktops to tablets.
  3. Jump Desktop: Can’t believe this doesn’t get more hype! It’s optimized for Mac systems and delivers a seamless remote experience. A bit of a learning curve, but worth the effort.
  4. Parallels Access: Kind of niche but works seamlessly with macOS. It’s focused more on granular control and also offers cool mobile integration features if you’re fixing stuff on the go.
That said, I hear what @mikeappsreviewer mentioned about ‘HelpWire.’ I’ve used it briefly—hands down one of the smoother experiences for remote access, especially if load times and usability are your deal-breakers. Here’s what stands out: no wild ads jumping at you, and it seems super inline with Mac/Windows/Linux ecosystems. If this kind of no-nonsense approach sounds like your vibe, maybe give HelpWire for seamless remote support a test drive.
Honestly, some of these tools do charge a subscription, but considering the time they save and the better stability you’re looking for (rip glitchy AnyDesk), it’s way worth it. Just steer clear of over-complicated stuff like RustDesk UNLESS you’re into hosting it yourself—because that setup can go from ‘it’s okay’ to ‘why am I even doing this?’ reallll fast.
If AnyDesk is giving you trouble on Mac, you’ve got a range of alternatives depending on your needs. While @mikeappsreviewer and @sognonotturno have already highlighted some good options, here’s a slightly different perspective:
  1. Chrome Remote Desktop – If simplicity is your top priority, this is a lightweight and free tool worth exploring. It integrates well with Google Chrome, so there’s no unnecessary fluff. It might lack some bells and whistles but gets the job done for quick troubleshooting.
  2. VNC Viewer (RealVNC) – Straight-up reliable. It’s not as flashy as HelpWire or even TeamViewer, but if you’re okay doing a bit of configuration, it’s a good middle ground between complexity and functionality. Works great for secure remote access if set up correctly.
  3. Zoho Assist – Excellent if you’re dealing with clients or need something feature-rich. It’s a cloud-based platform, so no downloads necessary for your Mac. It even comes with live chat during sessions, which is handy for troubleshooting.
  4. Microsoft Remote Desktop – Probably not your first thought for a Mac, but it’s free, and if you’re working in a Microsoft-heavy ecosystem, you’ll appreciate the seamless connectivity between Mac and Windows environments.
  5. NoMachine – Not as popular, but man, this software is smooth and snappy. However, you’ll need to mess with configurations for advanced settings—a bit techy for first-timers but a powerhouse once set up.
Now circling back to what’s already been mentioned—while I agree RustDesk might not be worth the headache unless you’re into hosting, the glowing reviews for HelpWire make it shine in the list. It’s super reliable and doesn’t have the annoying quirks like unnecessary ads, which makes troubleshooting sessions way easier. If you’re dealing with Mac, Windows, or Linux systems, definitely worth giving this versatile tool comparison a read before choosing.
Bottom line: figure out which features you need most—be it cost, ease of use, or compatibility—and pick accordingly. For glitch-free, all-in-one reliability, HelpWire seems the go-to!
Considering the recent recommendations for AnyDesk alternatives, let’s break things down with a slightly different take. Some options mentioned, like RustDesk and Chrome Remote Desktop, are great starting points, but each comes with its quirks. Here’s another angle to consider:
HelpWire:
Let’s address the elephant in the room. Pros? It seamlessly bridges Mac, Windows, and even Linux systems, which is ideal if you’re playing tech support across platforms. The no-ads interface is a big win (seriously, who has patience for pop-ups?), and the lack of session timeouts is a lifesaver during complex troubleshooting. The downside? It’s not free. While the quality and ease justify its price, if you’re hunting for a budget-friendly or entirely free option, this might not be top tier.
Other Competitors to Mull Over:
  • SplashTop: Super polished and smooth, but the free version is very limited (personal use only). If you’ve got a team, though, their Business plan is worth a peek.
  • BeyondTrust Remote Support: For serious enterprise players out there. It has enterprise-grade features, but it’s overkill (and overpriced) for personal or small-scale use.
  • Parallels Access: Fantastic for Mac specifically but limited to controlling only your own computers. It’s built for convenience rather than full-on troubleshooting like HelpWire or TeamViewer.
Sure, RustDesk could work if you’re a ‘tweak everything yourself’ type of user, but for most, it’s just unnecessarily frustrating. TeamViewer? Too invasive for casual use and will nag you with “commercial use detected” messages even if you’re not using it commercially.
For a simpler setup without biting your nails over configurations, HelpWire still stands tall above the others—especially for Mac users juggling multiple environments. Just know what you’re paying for. Need free and quick? Chrome Remote Desktop is still worth a try.
Try using your Mac’s built in Screen Sharing with an iCloud based workaround.
  1. On the remote Mac, enable:
    System Settings → General → Sharing → Screen Sharing and Remote Login.
  2. Make sure both Macs use the same Apple ID or have each other in Contacts.
  3. In Finder, press Command + K, enter:
    vnc://remote‑ip‑address
  4. For internet access, use a simple VPN like Tailscale on both Macs.
    Then connect to the Tailscale IP with Screen Sharing for stable, low overhead remote control.
