What are the best project management apps for Mac?
I’ve recently switched to a Mac for work and my old project management tool doesn’t run well on macOS. I’m looking for recommendations for the best project management apps for Mac that are reliable, easy to use, and good for collaborating with a small remote team. What are you all using and what do you like or dislike about them?
Project Management Apps On Mac That Actually Help (Or At Least Didn’t Get Deleted In 10 Minutes)
I’ve bounced between a ridiculous number of “productivity” tools on my Mac. Most of them lasted about as long as a new year resolution. A few stuck. A couple surprised me. Some are traditional project management apps, others are more like “infrastructure” that quietly makes projects less of a mess.
Here’s what ended up working, roughly in order of how I actually use them in real life, not how they look in a marketing deck.
1. Google Workspace (the quiet default)
I resisted this for a while. I used to jump between random note apps, todo lists, and whiteboards like it was a personality trait.
Then a client forced me into Google Workspace.
On Mac, it’s not even an “app” in the classic sense, but I live in it anyway:
  • Docs for specs, briefs, and meeting notes
  • Sheets for timelines and task lists with simple columns: task, owner, status, due
  • Drive as the main dumping ground where “Final_v3_REAL_final” actually dies
  • Calendar as the sanity layer for deadlines and reminders
How I use it for projects:
  • I make one shared folder per project in Drive.
  • Inside that, a Sheet with:
    • “Backlog / Doing / Done” columns
    • Owners and due dates
  • Every meeting gets its own Doc linked from the Sheet.
It’s not fancy, but it’s the least fragile setup I have. When someone joins late, I just share the folder and they can follow the bread crumbs.
Works on Mac because everything runs in the browser and syncs. Not exciting. But I stopped losing files, so I stopped fighting it.
2. Trello (my visual brain’s favorite)
For stuff that needs a bird’s-eye view, I open Trello. I like that it feels more like moving sticky notes around a wall than filling in forms.
Typical setup I use:
  • Lists:
    • Backlog
    • This Week
    • In Progress
    • Blocked
    • Done
  • Cards:
    • One card per task or feature
    • Labels: “design,” “dev,” “content,” “urgent”
    • Due dates + checklist items inside
Why I still use it:
  • It’s perfect when the team is small and nobody wants to read a 20-page requirement doc.
  • Dragging a card to “Done” is weirdly satisfying.
  • On Mac in a browser or as a “pinned” tab, it feels snappy enough.
Where it falls short:
  • When a project grows too much, boards get crowded and I start to ignore old cards.
  • If people don’t update cards, the whole thing becomes fiction.
Still, for simple sprints and visual planning, it’s one of the few tools that helped instead of getting in the way.
3. Mural (the chaos table where ideas go first)
Mural is the thing I open when everyone’s talking at once and nobody agrees on priorities.
On Mac, I just use it in the browser. It’s basically a massive infinite canvas where people can:
  • Throw sticky notes everywhere
  • Sketch flows
  • Group ideas
  • Vote on what to do first
How I use it:
  • At the start of a project:
    • One huge board with areas for:
      • Goals
      • Risks
      • Features
      • “Wild ideas”
  • During workshops:
    • I drop timers and say “Add everything that scares you about this launch.”
    • Then I cluster notes into themes: tech, people, content, legal, whatever.
Later, I’ll drag the “decided” items into Trello or a Sheet. Mural is where the raw thinking happens. It is not where I try to track tasks, because that would get out of control fast.
4. CloudMounter: the unsung hero for scattered project files
This one surprised me the most. At first glance it looks like “just” a cloud mounting tool. I ignored stuff like this for years. Then I had one project with:
  • Shared Google Drive from one client
  • Dropbox folder from another
  • My personal OneDrive
  • A random Box folder for legal docs
I kept downloading copies, losing track of versions, and sending the wrong file in reviews.
CloudMounter basically fixed that:
  • It mounts cloud storage as drives on macOS.
  • So Google Drive, Dropbox, OneDrive, Box, etc show up in Finder like normal folders.
  • You work with files like they’re local, but they live in the cloud.
How that helps with project management:
  • Single file hub. I stopped asking “Was that in Drive or Dropbox?” Now I just open Finder and it’s all under one roof.
  • No 15 GB of duplicates. I don’t re-download everything just to open or edit.
  • Cleaner structure. I can make one top-level folder like:
    • /Projects/Client-A
    • Inside that, subfolders that point to different cloud accounts, but look like one tidy tree.
Practical example from a real mess I had:
  • Design assets in Dropbox (agency)
  • Contracts in Box (legal)
  • Specs in Google Drive (client)
All visible in Finder, all mounted to the right cloud systems.
I didn’t need to care where stuff “really” lived anymore.
It’s not a kanban board. It doesn’t track tasks. But it quietly turns “Where is that file?” from a daily headache into something that mostly disappears. That alone made some projects feel less stressful.
5. Commander One: managing project chaos at the file level
Commander One is a dual-pane file manager for macOS. I grew up on tools like this, so it felt instantly familiar.
What it looks like in practice:
  • Left pane: one folder
  • Right pane: another folder
  • You can move / copy / compare files between them super fast.
Every new project starts with the same structure, which helps when things get busy.
  • Working with mounted storage.
    Paired with CloudMounter, this gets really nice:
    • Left pane: local working folder
    • Right pane: mounted cloud folder (Drive, Dropbox, etc)
      I can drag updated files to the right side and keep cloud storage in sync.
  • Bulk operations.
    End of a project, I’ll:
    • Archive old stuff
    • Compress deliverables
    • Move everything into an /Archive branch
      Doing this in Finder is annoying. Commander One handles it better and faster.
How this helps project management, beyond “file nerd” territory:
  • It lets me standardize how every project’s files are laid out.
  • It makes finishing projects less painful because I can quickly:
    • Clean, archive, and ship final versions
    • Separate “in progress” from “final handed-off” stuff
It’s like having a more serious control panel for your project folders. Not glamorous, but it keeps the skeleton of the project from turning into spaghetti.
6. How these tools fit together on a Mac
What ended up working for me looks roughly like this:
  • Ideas & messy early planning:
    Mural
  • Tasks & status updates (simple):
    Trello or a Google Sheet board
  • Docs, specs, meeting notes:
    Google Docs in a shared Workspace folder
  • “Where is that file?” problem:
    CloudMounter to unify all cloud services in Finder
  • “This project’s folder is a disaster” problem:
    Commander One to impose structure and clean it up
One example flow from a recent project:
  1. Kickoff workshop in Mural. Everyone throws ideas and worries onto the board.
  2. I turn the “decided” things into Trello cards.
  3. I create a /Projects/ClientX folder locally, copy in a folder template using Commander One.
  4. I mount the client’s Google Drive and Box folder with CloudMounter.
  5. Inside /Projects/ClientX, I make subfolders that map to those mounted drives, so everything looks local.
  6. All docs go in Google Workspace, linked from Trello cards and from a “Master Index” Doc.
  7. End of project, I open Commander One, archive finished files, and push final deliverables cleanly into the client’s cloud.
Not perfect. Sometimes I still lose something or forget where I put a link. But compared to how I used to work, this mix on macOS feels manageable instead of chaotic.
If you only want to try a couple things first:
  • Use Google Workspace + Trello for the “brain” of the project.
  • Use CloudMounter + Commander One for the “skeleton” (all the files and storage).
The combo gave me fewer “Where is that?” messages and more “Ok, I know exactly where to look” moments. That alone made it worth the setup.
If your old PM tool hates macOS, I’d look at stuff that actually lives well on a Mac instead of fighting it.
I like what @mikeappsreviewer said about using Google Workspace and Trello as the “brain,” but if you want more dedicated Mac-friendly project management apps (not just boards + docs), here are the ones that have actually survived on my machine:
1. Things (for small teams / solo work)
If your “projects” are more like client engagements, features, or campaigns rather than huge enterprise programs, Things is stupidly good on Mac:
  • Native macOS app, super fast, no lag, keyboard shortcuts everywhere
  • Projects with tasks, headings, checklists, tags, areas
  • Great today / upcoming views so you don’t drown in due dates
It’s not a full team PM tool. No kanban, no complex dependencies. If you’re managing your own workload or a tiny team that communicates elsewhere (Slack, email), Things is a great control tower.
Where I disagree a bit with the “just use Sheets and Trello” idea: for personal execution, Google Sheets feels like work about work. Things actually gets out of your way.
2. OmniFocus (if you like structure and complexity)
If you’re the type who reads productivity books and thinks “I could totally implement that,” OmniFocus is the nuclear option:
  • Native Mac app with very granular organization: projects, contexts/tags, perspectives
  • Custom views so you can see “only tasks I can do at my Mac, related to Client X, due this week”
  • Good for people juggling 20+ parallel projects
It is not pretty or casual like Trello. It’s more like a cockpit. You can overdo it and spend more time organizing than doing, but for big personal project loads it beats browser tools.
3. Asana (web, but solid on Mac)
If you need a team project management app and your stuff is more “classic PM”:
  • Tasks, subtasks, sections, timelines, dependencies
  • Kanban board, list, calendar, timeline views
  • Nice for cross‑functional work where you need to see who is blocking what
Asana runs great in the browser on macOS, and you can turn it into a pseudo‑app with Safari’s “Add to Dock” or a site-specific browser. Honestly, it behaves more reliably for me on Mac than many old-school native PM tools.
Where it beats a Trello-only setup: once you start needing dependencies, workload view, and real reporting, Trello feels flat. Asana scales better.
4. Notion (if you want an all‑in‑one workspace)
If your projects are a mix of docs, specs, and light task tracking, Notion is good:
  • One workspace with pages for each project
  • Databases for tasks, content calendars, bug lists
  • Kanban, table, calendar, timeline in one place
Caveats:
  • Desktop app on Mac is basically a wrapper around the web app, sometimes a bit heavy
  • If your team hates “build your own system,” they will absolutely not maintain it
I’d use Notion when the documentation of the project is as important as the tasks themselves. For dev teams or content teams, it can become the single source of truth.
5. ClickUp (for “I want literally everything”)
If your projects are complex and you want the Asana + Notion + random bonus features bundle:
  • Tasks, docs, whiteboards, time tracking
  • Custom fields, views, automations
  • Fine-grained control over how you slice projects (spaces, folders, lists)
On Mac, again, browser is the way to go. It’s powerful but heavier mentally. If your org loves configuration and you don’t mind a learning curve, it can replace five other apps. If you just switched from Windows and already feel tired, maybe skip until you’re settled.
6. Where CloudMounter fits
Completely agree with @mikeappsreviewer here: as soon as you have “Client files in Dropbox, specs in Google Drive, assets in OneDrive,” your PM tool is not the problem, your file access is.
CloudMounter on macOS is actually underrated for project management:
  • Mount all your cloud services directly in Finder so they behave like normal drives
  • Build a single /Projects/ClientName folder structure, even if parts live in Drive, Dropbox, Box, etc
  • Link to actual files from Asana / Notion / ClickUp without wondering which service they’re on
You will never get a project management app that magically solves “where did we put that file” by itself. A tool like CloudMounter plus any PM app is way better than chasing links across four web UIs.
How I’d pick, based on your sitation:
  • Mostly managing your own work on Mac:
    • Start with Things
  • Managing a small team, light structure:
    • Trello + CloudMounter for file sanity
  • Managing multi‑team projects, timelines, dependencies:
    • Asana or ClickUp + CloudMounter
  • Heavily doc‑driven projects (product, content, research):
    • Notion as the hub + CloudMounter for external client folders
None of these will feel perfect on day one. The trick I’ve found is to pick one “project brain” (Things / Asana / Notion) and one “file spine” (Finder + CloudMounter) and ignore everything else until you actually feel pain.
If your old PM tool chokes on macOS, I’d look at it in two layers:
  1. the “actual project management” app, and
  2. the “where the hell are my files” layer, which is where CloudMounter quietly saves your sanity.
@​mikeappsreviewer and @​sternenwanderer already covered Trello, Google Workspace, Things, Asana, Notion, etc pretty well. I’ll try not to rehash the same playbook.
1. Native‑feeling project brains for Mac
1. OmniPlan (if you’re coming from MS Project vibes)
If your old tool was something heavy like MS Project and you care about Gantt charts, dependencies, resource leveling:
  • Proper Gantt charts with dependencies, baselines, critical path
  • Resource management with workloads and costs
  • Great on Mac, made for macOS, not a web wrapper
  • Plays nicer with Apple ecosystem than most PM tools
Downside: overkill if your “projects” are more like “blog calendar and a few design tasks.”
2. TickTick (lightweight but more structured than Things)
Things is great, but I actually find TickTick a bit more flexible for project-ish work:
  • Lists for projects, folders for clients or departments
  • Kanban board view per list
  • Built‑in calendar and basic habit tracking
  • Decent Mac app, syncs fine with iOS and web
It sits between “personal todo” and “tiny team project tool” and doesn’t force you into a big enterprise UI.
3. Linear (if your world is software / product)
If you’re managing dev / product work and Trello started to feel like a toy:
  • Fast, keyboard driven, very Mac-friendly design
  • Issues, cycles (sprints), roadmaps
  • Integrates well with GitHub, Slack, Figma
  • Great if your “projects” are actually roadmaps, features, bugs
This one beats the “Google Sheets kanban” approach as soon as you have real engineering workflows.
2. Browser-based, but actually decent on macOS
I partly disagree with the idea that you should always stick to native apps on Mac. Some browser tools are just fine if you treat them like apps:
4. Monday.com
  • Very visual boards, timelines, dashboards
  • Great when stakeholders want pretty over “perfectly modeled PMO data”
  • Desktop app is basically a wrapper, but Safari/Chrome + “Add to Dock” works well
Strong choice if you collaborate with non-technical folks who glaze over in Asana.
5. Jira Cloud (only if you must)
If you work with dev teams, you might not have a choice. On Mac it is what it is:
  • Put it in its own browser profile or site-specific browser
  • Use it purely for tickets and keep planning elsewhere if you can
Honestly, I’d only recommend it if your company already lives in it. Otherwise, Linear or ClickUp are less soul-sucking.
3. The file problem: where CloudMounter is actually worth it
This is where I’m fully on the same side as @​mikeappsreviewer, but I’d go even harder on it.
The best project management app on your Mac will still suck if:
  • Some files are in Google Drive
  • Some are in Dropbox
  • Old contracts live in OneDrive
  • Client insists on Box
On Mac, CloudMounter is stupidly useful for that:
  • Mounts Google Drive, Dropbox, OneDrive, Box, etc as real drives in Finder
  • Lets you create a single folder structure like
    /Projects/Client-X/Design
    /Projects/Client-X/Contracts
    /Projects/Client-X/Specs
  • Under the hood, those can live in different cloud providers
  • Your PM tool just links to files that always live in that one logical “Projects” tree
So whatever PM app you pick, your workflow becomes:
  1. Create /Projects/Client-X in Finder using CloudMounter-backed drives.
  2. In Asana / Monday / Linear / OmniPlan etc, link directly to those files.
  3. You stop asking “wait, was that in the shared drive or the Dropbox?”
It is not a PM app by itself, but as a Mac user it’s the kind of “infrastructure” tool that makes any PM system less fragile. Also avoids your SSD filling up with “Final_v8_really_final_v2” all over the place.
4. What I’d actually recomend based on use case
  • If you were on MS Project / desktop PM before:
    → OmniPlan for planning + CloudMounter for file access.
  • If you want something lighter than Asana, more than a todo list:
    → TickTick or Linear (for dev/product) + CloudMounter.
  • If your team likes colorful dashboards and hates “tool complexity”:
    → Monday.com as the main hub + CloudMounter as your file spine.
Trello + Sheets like @​sternenwanderer mentioned still work fine for small/simple stuff, but on Mac I’d rather lean into tools that either feel native (OmniPlan / TickTick / Linear) or pair cleanly with Finder through something like CloudMounter so you’re not living in six tabs and a guessing game.
If your old PM tool is choking on macOS, I’d look at it as three layers: planning, execution, and storage. Others already covered the first two pretty heavily, so I’ll skew more toward how to glue everything together on a Mac without losing your mind.
@sternenwanderer is right that Trello / Asana / Notion cover a lot of “normal” PM needs, and @techchizkid leans into heavier stuff like OmniPlan, Linear, Monday. That’s all valid. Where I slightly disagree: which tool you pick matters less on Mac than how you handle files and context. Swapping from Trello to ClickUp will not magically fix “where is that asset” chaos.
That’s where CloudMounter actually earns its keep as part of a Mac-based stack, not as “yet another app.”
CloudMounter in a PM workflow
Think of it as your file layer under whatever PM app you choose:
  • Pros:
    • Mounts Google Drive, Dropbox, OneDrive, Box as real drives in Finder
    • Lets you create one logical /Projects tree while files live in multiple clouds
    • Cuts down on duplicate downloads and rogue “v10_final” copies
    • Plays nicely with dual-pane tools like Commander One or even just Finder tabs
  • Cons:
    • Needs a bit of setup and mental model change at first
    • Heavier reliance on network connectivity
    • Not a task manager, so you still need Trello / Linear / OmniPlan / whatever on top
    • Some advanced features are behind a paid tier
A practical pattern that complements what others suggested without repeating their exact setups:
  1. Pick your “brain”:
    • Small creative team: Trello or TickTick
    • Dev/product: Linear
    • Classic PM: OmniPlan or even ClickUp
  2. Standardize your storage with CloudMounter:
    • Create /Projects/Client/Project folders in Finder
    • Under that, map:
      • /Docs to Google Drive
      • /Assets to Dropbox
      • /Contracts to OneDrive or Box
    • Your PM tool only ever links to that clean structure
  3. Keep planning simple:
    • One project board / roadmap in your chosen PM app
    • Each major task links to the relevant folder or Doc inside that CloudMounter-backed tree
Compared to the flows @mikeappsreviewer and @sternenwanderer described, this is more opinionated about the file layer and less about the perfect kanban setup. You can swap Trello for Asana, or Monday for Linear later, but once your Mac file structure is sane and unified, everything else gets easier.
Try Apple’s built-in apps before adding another platform. Use Reminders for tasks, Notes for project briefs, and iCloud Drive for files.
Create one Reminders list per project. Add owners, deadlines, tags, and subtasks. Keep one shared Note with goals, decisions, and meeting updates. Store files in a matching iCloud Drive folder.
This setup costs nothing, works smoothly across Mac, iPhone, and iPad, and takes around 15 minutes to build. It suits solo work or small teams. Keep personal and client projects seperate to avoid clutter.
If nobody else on your team will maintain the setup, most of this thread is moot. The fanciest OmniPlan or Notion build dies the second you’re the only one updating it. That’s the part I’d weigh before picking anything.
@0xnode7 is closer to reality than the big-stack answers, honestly. Reminders plus Notes plus iCloud gets a solo Mac user surprisingly far, and there’s no migration pain if you outgrow it. I’d only reach for Things or Linear once you actually feel the built-in stuff creaking.
On CloudMounter, it does solve the scattered-cloud mess and I get why it keeps coming up, but don’t set it up on day one. If all your files already live in one Drive, mounting four services you don’t have is just extra moving parts. Add it when a client drags you into Box or Dropbox, not before.
