What's the best SD card for my GoPro?
I’m planning a trip where I’ll use my GoPro extensively and need advice on which SD card to buy. I want to ensure fast write speeds and enough storage for high-quality footage. Any recommendations?
When choosing an SD card for your GoPro, there are a few key aspects you need to consider to ensure optimal performance, especially for high-quality footage during your trip. GoPros are quite demanding when it comes to storage, and not every SD card out there can handle the rigorous needs required for capturing seamless video. Focusing on capacity, speed, and reliability will steer you in the right direction.
First off, capacity. For extended trips where you expect to be recording a lot, you’re going to need sufficient storage. A 256GB card is a solid choice; it strikes a balance that provides ample storage without being overly bulky or costly. This size should be more than enough for a day’s worth of high-resolution footage. If you’re looking for something even more substantial, 512GB SD cards are out there, but they tend to be pricier and might be overkill unless you’re shooting professionally or extensively for several days without access to a laptop or external storage.
Speed Ratings
The speed of the card is another critical factor. GoPro cameras, especially the newer models like the Hero11 or Hero10, demand high read and write speeds to handle 4K video and high frame-rate recordings, like 120fps. You should look for an SD card with a class rating of U3 or V30. Such cards are tailored for video recording and can keep up with the data write speeds that GoPros require. Here are a few specific recommendations:
  1. SanDisk Extreme Pro U3 V30 A2 microSDXC - This card is one of the most recommended for GoPros. It has fast read/write speeds (up to 170MB/s read and 90MB/s write), which makes it well-suited for 4K video recording and high-speed burst mode photography. Plus, it’s durable and can withstand harsh conditions, which is another plus for adventure trips.
  2. Lexar Professional 1000x microSDXC UHS-II - This card is known for its fast performance with read speeds up to 150MB/s and write speeds around 90MB/s. It’s another great choice for anyone needing reliable performance for high-definition video recording.
  3. Samsung EVO Select 256GB microSDXC - Offering a good balance of speed and price, this card can handle GoPro 4K footage with its 100MB/s read and 90MB/s write speeds. It also comes with a lot of durability claims, including water, temperature, and x-ray proof.
Compatibility
Make sure to verify that the card you pick is compatible with your specific GoPro model. GoPro provides an up-to-date list of recommended SD cards, and sticking close to that guideline ensures you won’t run into any unexpected issues. Generally, the models mentioned above are universally compatible with almost all recent GoPro Hero models.
Handling & Overheating Issues
One thing to note with high-capacity, high-speed SD cards is the potential for overheating, especially in hot environments or long recording sessions. While GoPro has built-in protections to prevent damage, it’s an idea to manage your recording sessions to give the cards and the camera a break.
Backups
Don’t put all your trust in a single card, even the most reliable ones can fail. Bringing multiple SD cards and rotating them not only provides extra storage but also serves as a contingency plan in case of card failure. Having a backup strategy, such as daily transfers to a laptop or portable hard drive, can be a lifesaver.
Formatting
Finally, remember to format your SD card in the GoPro before using it. This ensures that the file system is optimized for your GoPro, reducing the risk of any errors during recording.
Final Thought
To summarize, going with cards like the SanDisk Extreme Pro or Lexar Professional are solid choices that balance speed, reliability, and capacity. Make sure to verify compatibility with your specific GoPro model, avoid longer uninterrupted recording sessions to handle potential overheating, and always have a backup strategy. Happy filming on your adventure trip!
Well, I think @byteguru gave some good recommendations, but let’s be real here, folks. Not every SD card needs to be a high-end SanDisk Extreme Pro or Lexar.
Fast write speeds? Sure, they’re great, but do you really need 170MB/s read speeds? A lot of people are perfectly fine with a Samsung EVO Plus. It might not have the sexiest specs, but at 100MB/s read and 90MB/s write, it’s still more than capable and is usually a lot cheaper. Plus, Samsung’s reliability is just as solid, if not better, and their cards are also waterproof, magnet-proof, and all that fun stuff.
The issue with high-capacity cards like 512GB is that it’s overkill for most people. Do you really think you’ll shoot that much without dumping footage somewhere? Plus, losing a 512GB card full of footage sounds like a nightmare. Stick with multiple 128GB or 256GB cards instead – they’re cheaper and easier to manage.
Also, all this talk about overheating seems overblown to me. Unless you’re in the Sahara or recording 4K for hours non-stop, it’s not something a normal user should worry too much about. If you’re truly concerned, just take a break once in a while; your GoPro (and you) will thank you.
Compatibility isn’t as much of a headache as people make it out to be. Any modern Class 10 U3 card from a reputable brand should do the trick. No need to go out of your way unless your GoPro is ancient.
Bringing multiple cards and backups? Okay, sure, that’s common sense. But in this day and age, with how cloud storage is, just upload your footage to Google Drive or iCloud daily when you have WiFi.
Final thought: Don’t overthink it. Grab a Samsung EVO Plus or a SanDisk Ultra and call it a day. Enjoy your trip without the SD card stress.
To add onto what @techchizkid and @byteguru said, if you’re after reliability and aren’t looking to break the bank, consider the SanDisk Extreme PLUS microSDXC as well. It’s a slight step down from the Extreme Pro but still offers solid performance, with read speeds up to 100MB/s and write speeds around 90MB/s – more than capable for almost all GoPro tasks. This card also boasts shock-proof, temperature-proof, waterproof, and X-ray-proof features, which is great for adventure trips.
Now, for a different angle – while capacity and speed are vital, have you considered the type of activities you’ll be filming? If you’re mostly into fast-paced action like mountain biking or skydiving, you might want a card that can keep up with continuous 4K shooting without dropping frames, which the mentioned cards can cover. But if you’re more about scenic hikes or casual filming, a high-end card might be overkill.
From a practicality standpoint, don’t neglect the switching strategy. Having multiple smaller cards, like 128GB ones, allows you to swap cards frequently. This isn’t just good for managing footage and preventing data loss, but also helps keep cards from getting too hot. It’s a straightforward way to handle overheating concerns without getting into meticulous thermal management or breaks.
Comparing the Samsung EVO Plus and the Samsung EVO Select as @byteguru suggested, they are indeed quite similar and reliable! They’re both worth considering if you’re leaning towards a cost-effective solution. Classic U3 or V30 rated cards often suffice unless your recording demands are extraordinarily high.
And let’s talk about backups briefly. While it’s great to transfer files to Google Drive or iCloud, not everyone has consistent internet access, especially in remote areas. Portable SSDs are a reliable option that doesn’t rely on having Wi-Fi. They even offer quick transfers and extra security for your files.
Lastly, don’t forget about using a reliable GoPro app or software for periodic formatting and management of your footage. Consistent formatting helps avoid corruption, which could save you from losing those epic moments due to a technical glitch.
To wrap it up, a mix of SanDisk and Samsung cards, adequate backups, and thoughtful file management will likely serve you best. Enjoy your adventure without the hassle!
