I’m struggling to connect my Brother printer to my WiFi network. I tried following the manual, but it’s not working and now it’s becoming frustrating. Can someone guide me through the steps I need to take to get it connected? Any help is appreciated!
Oh man, connecting a Brother printer to WiFi can be a real pain! Don’t worry, let’s walk through it step by step. Hopefully, I can help ya avoid some of the common pitfalls.
Prepare Your Printer and Network: Before you do anything, make sure your WiFi network is up and running and you know your WiFi SSID (network name) and password. Have your printer close to the router for easier initial connection.
Use Printer Control Panel: If your Brother printer has a control panel, use it to navigate to the wireless settings. You usually find it under Menu > Network > WLAN. If you don’t see exactly that, look for something similar like ‘WiFi setup wizard’ or ‘Network wizard.’
Manual Setup: Select ‘Setup Wizard’ or ‘Manual’ and the printer should start searching for available networks. When your network shows up, select it and enter your password. Be careful with the password - it’s case-sensitive and you gotta enter exactly right.
Using WPS (WiFi Protected Setup): If your router supports WPS, this might be even easier. Enable WPS on your router (should be a button on the side or back). Then, on the printer, in the WLAN setup, choose ‘WPS.’ Press the WPS button on your router when prompted. This should connect the printer to your network without needing a password.
Install Printer Driver on Computer: Go to Brother’s official website and download the latest driver for your printer that matches your operating system. Run the installer and follow the instructions. When prompted, choose the wireless network connection option.
Troubleshooting:
- Signal Strength: If your WiFi signal is weak, the printer may struggle to maintain a connection. Try moving the printer closer to the router.
- Firewall/Antivirus: Sometimes, firewalls or antivirus software can mess with the connection. Temporarily disable them to see if the setup completes.
- Restart Everything: Sometimes the simplest fix is to just restart your router, computer, and printer.
Use the App: Brother iPrint&Scan is a handy app if you’re still having trouble. It can sometimes do the heavy lifting and connect the devices.
Double-check each step to make sure nothing’s missed, and you should be all set. If all else fails, it may be time to contact Brother support directly. Sometimes, it’s just a faulty setting or hardware that needs a professional touch.
codecrafter has already laid out a solid foundation, but let’s delve a bit deeper into some alternative solutions you might find useful if the initial approach isn’t cutting it.
WPS Alternative is a Misunderstanding
While the WPS method is generally advised, it’s not always as straightforward as pressing buttons. Not all routers light up immediately or sustain the connection signal well. Some older routers might also have WPS disabled for security reasons. To manually enable:
- Login to your router settings (usually through 192.168.0.1 or 192.168.1.1).
- Navigate to the WPS settings and toggle it on.
- Only then should you attempt reconnecting your Brother printer as codecrafter suggested.
Double-Check Your Network Band
Ensure you’re connecting to the 2.4GHz band! Many Brother printers don’t support the 5GHz band. Verify your router’s settings to see if it broadcasts both networks separately; you might have to temporarily turn off the 5GHz band during setup.
Reserved IP Address in Router
Assigning a static IP for your printer on your network can help prevent it from losing connection over time. Here’s how:
- Access your router settings.
- Find the device list within your network settings.
- Locate your Brother printer and select the option to reserve its IP address.
- Use the same IP to configure network settings manually on the printer’s control panel if required.
Firmware Update
Firmware can be a hidden culprit. Make sure your printer’s firmware is up-to-date:
- Visit Brother’s official support page.
- Enter your printer model and look for the Firmware Update Tool.
- Download and follow the provided installation instructions. Bugs related to connectivity are often fixed in firmware updates.
Using a USB Cable First – Hybrid Method
Connecting via USB initially and then switching to WiFi can smooth out some hiccups:
- Connect your printer to your laptop/desktop using a USB cable.
- Run the installation driver downloaded from Brother’s website.
- Choose the option to switch to wireless network during the driver setup.
- Follow the on-screen instructions; the printer might connect more reliably to your WiFi then.
QR Code & Mobile Setup
Did you know some Brother printers support QR code WiFi setup via mobile apps?
- Download Brother’s iPrint&Scan app.
- Within the app, select the option to configure your printer.
- Scan the QR code displayed on the printer’s control panel using your smartphone.
- Follow the app’s guidance to complete the WiFi setup.
Access Point Mode
Use your printer’s Access Point mode to connect directly to it and configure WiFi settings:
- Enable Access Point Mode from the printer’s control panel (usually found under WLAN menu).
- Using your laptop or smartphone, connect to the WiFi that the printer itself broadcasts.
- Open a browser and enter ‘http://brother/…’ to access printer settings.
- Manually enter your home network WiFi credentials here.
Ensure Proper Network Channels
Overcrowded WiFi channels can disrupt a connection:
- Change your router’s WiFi channel to a less crowded one (like 6 or 11) by logging into your router settings.
- Many routers have auto-channel options; disable it and manually pick a quieter channel.
Correct Printer Settings
Sometimes default settings might be causing an issue, so resetting network settings on the printer could help:
- Go to Menu > Network > Network Reset.
- Confirm and let the printer restart.
External Factors
Other factors, often unnoticed, can play havoc:
- Interference: Cordless phones, microwave ovens, and other devices can interfere with WiFi signals.
- Environment: Thick walls, metal objects can weaken signals. Moving the router or printer slightly might help.
Configuration On Computer/OS Specifics
Last but not least, if none of these steps resolve your issue, the settings on your computer might be wrong:
- Ensure the correct network settings in your OS are dedicated for printer connections.
- Windows: Control Panel > Devices and Printers > Add a printer, ensure you followed the wireless setup prompts accurately.
- macOS: System Preferences > Printers & Scanners > Add printer, select the networked printer option properly.
Direct Support
If you’re hitting brick walls, reach out to Brother support with detailed notes of steps you’ve taken up until now. Sometimes, an overlooked minor tweak by professional guidance makes all the difference.
With these tweaks and a careful check, you should be able to get your Brother printer up and running on your WiFi. Tech can be infuriatingly frustrating! Just gotta nudge those settings from another angle.
Sounds like a nightmare.
Honestly, no amount of these step-by-step guides can always guarantee everything works smoothly, and it’s often hit-or-miss. Sometimes it’s not even your fault but some obscure setting. I’m skeptical about the effectiveness of some methods mentioned, especially WPS - not all routers support it, and it’s unsafe.
Instead:
Check Compatibility: Ensure your router uses a compatible encryption type (like WPA2). Older routers might cause hiccups.
Router Settings Overhaul: Access your router settings and check for any ‘MAC filtering’ policies. Some routers block new devices unless explicitly allowed.
Alternative Printers: I hate to say it, but if this keeps up, consider a different brand. HP or Epson might provide a more user-friendly experience. At least you won’t spend an eternity banging your head against the wall.
Professional Help: If the frustration is real, professional help or contacting a local technician could save you hours. Sometimes it’s best to leave it to the pros.
Technology’s supposed to make our lives easier, but with issues like this, it’s easy to question that. Good luck… you’re probably gonna need it. ![]()
You got vague advice. It warned about WPS, encryption, and MAC filtering. It suggested switching brands or hiring help. No clear path.
Simpler path, use Brother Mobile Connect on iOS or Android. Steps:
- On printer, Network Reset.
- Open app, Add device, Set up Wi Fi.
- When asked, join the printer’s setup network.
- Enter your 2.4 GHz SSID and password, WPA2 AES.
- Wait for success, print Network Config to verify IP.
If the router merges bands, split SSIDs. Avoid spaces or odd symbols in SSID. Reboot router and printer to finalize. Fix any IP adress issues.
