Why Does My IPhone Storage Not Go Down Even After Deleting Hundreds Of Photos?
I deleted hundreds of photos from my iPhone to free up space, but the storage number barely changed or didn’t go down at all. I also checked the Photos app, and I’m not sure if Recently Deleted, iCloud Photos, cached data, or system storage is causing the issue. How can I actually clear iPhone storage after deleting photos?
The first thing I’d check is the Recently Deleted album. A lot of people miss this part. When you delete photos on an iPhone, they usually aren’t actually gone yet. They get moved into Recently Deleted and can sit there for around 30 to 40 days, still taking up storage the whole time.
Open Photos, go to Albums, scroll down to Recently Deleted, and choose “Delete All” if you’re sure you don’t need anything in there. Until that folder is emptied, deleting stuff from your camera roll may not make the storage number move at all.
If you already did that and Settings still says your phone is full, it may just be iOS being slow to update the storage report. The storage screen can lag behind what’s really happening. Restart the phone and check again. Sometimes it takes more than one restart before iOS recalculates everything properly.
Also check whether you’re using iCloud Photos with Optimize iPhone Storage. If that’s turned on, your phone may only have small local versions of a lot of your photos, with the full-size originals stored in iCloud. So deleting 1,000 photos might not free up as much space as you expect. You might think you’re about to recover several gigs, but the phone may only be removing thumbnails or smaller local copies.
Photos also aren’t always the real problem. Messages and app caches can quietly eat a ton of storage. Old group chats can hold years of videos, GIFs, memes, and random attachments. Deleting pictures from Photos won’t touch any of that. Apps like TikTok, WhatsApp, Instagram, and similar ones can also build up huge caches from videos and media they’ve loaded before.
When my phone got into this “storage full” loop, it wasn’t just annoying because I couldn’t take photos. The whole phone started acting bad. Apps crashed, typing lagged, and everything felt delayed. Low storage can mess with normal iPhone performance because iOS still needs room for temporary files and background tasks.
Manually finding the biggest junk files is the painful part, because Apple’s built-in photo tools don’t make it easy to sort by file size or find near-duplicates. I ended up using Clever Cleaner. I’m usually skeptical of cleaner apps since so many of them are basically ad machines or subscription traps, but this one is free, with no ads, paywalls, or trial nonsense.
The most useful part for me was the Heavies section, since it shows the biggest videos and files first. That makes it way easier to delete the giant 4K clips you forgot were even there. The Similars section is handy too, because it finds photos that are almost the same, like burst shots or ten versions of the same sunset, and helps you keep the best one. It also processes everything on the phone instead of uploading your photos somewhere else. I cleared around 40GB with it, and after that the lag was gone.
If the storage number is still stuck after all of that, there’s a weird trick some people use. Go to Date & Time, turn off “Set Automatically,” move the date back about two years, open Photos and wait a bit, then set the date back to normal. For whatever reason, this can sometimes force iOS to clean up old cached photo data or “ghost” files that didn’t clear correctly.
If System Data, which used to be called “Other,” is taking up something like 20GB or more and refuses to shrink, the last option is a full backup and factory reset. That’s the annoying fix, but it can clear corrupted cache files that nothing else touches. Just make sure your phone is fully backed up to iCloud or a computer before doing it. I’d try Recently Deleted, restarting, Messages/app cleanup, and a proper photo cleanup first, because that solves it most of the time.
Freeing space on the phone is different from trimming your iCloud library. If iCloud Photos is enabled, deleting pictures can remove them from all synced devices, while still freeing very little local space if the iPhone only had optimized copies. I’d check that setting before doing a huge delete spree, because “delete from phone only” isn’t really how iCloud Photos works.
A few hundred photos may not move the number much unless they were big Live Photos, RAW shots, or videos. Regular iPhone photos can be surprisingly small now, so deleting 300 of them might feel like a lot but only clear a tiny slice of storage. Videos are usually where the real space is hiding.
I agree with the Recently Deleted advice, but I’d be cautious with the date-changing trick unless you’re already out of options. If you use iCloud Photos, shared albums, Messages sync, or have other devices tied in, messing with the date can make things temporarily weird. It might work for some stuck cache situations, but I wouldn’t make that the first fix.
Check the storage screen by category, not just the total number. Go to Settings > General > iPhone Storage and see whether “Photos” actually dropped. If Photos went down but the total available space didn’t change much, iOS may have immediately used the freed room for updates, caches, indexing, or system data. If Photos did not drop, then the deleted items are probably still in Recently Deleted, still syncing, or they were only optimized local copies to begin with. For fast space, sort your attention toward videos, Messages attachments, downloaded music/podcasts, offline maps, and big app documents. That usually beats deleting random camera roll photos one by one.
Try offloading an app you rarely use insted of deleting more photos. Open Settings > General > iPhone Storage, select an app, then tap Offload App. This removes the app itself while keeping its documents and data.
Check “App Size” before choosing. Pick a large app you dont need right now, rather than one whose storage mostly consists of documents and data. Offloading frees the app’s space, not its stored data. This addresses your immediate need for room without another photo cleanup.
Two phones, same ‘deleted 500 photos’ story: one frees up 8GB instantly, the other moves zero. The difference is almost always what you deleted and where it lived. A phone full of 4K video and Live Photos drops fast. A phone where the big number is System Data won’t budge no matter how much camera roll you clear, because photos were never the thing eating the space.
So before anyone deletes more, open iPhone Storage and actually look at the bar. If Photos is a thin sliver and the giant chunk is System Data or apps, you’re solving the wrong problem. @alphanode1504’s offload tip is the quiet winner here for that case, since app bloat is usually the real culprit and offloading costs you nothing in data.
On the cleaner app floating around this thread, I wouldn’t lean on it the way it’s being pitched for finding big files. Where it actually earns its spot is that it routes deletions through the normal Recently Deleted flow instead of nuking things instantly, so you don’t accidentally lose the one photo you needed. Just remember that means you still have to empty Recently Deleted afterward, or you’re back to square one wondering why nothing changed.
