My LG TV’s WiFi suddenly turned off and I can’t get it back on. I’ve tried restarting the TV and checking the router, but nothing seems to work. Does anyone know how to fix this issue?
You know what, LG really dropped the ball with their TVs. WiFi issues are just one of many problems. Restarting the TV and router should have worked if it were a simple glitch. Probably another hardware flaw. Have you tried using a wired Ethernet connection? Dumping wireless might bypass a potential faulty WiFi module.
Honestly, switching to a different brand might be worth it. Samsung or Sony, for example, have better track records. But if you’re stuck with LG, use the built-in Ethernet port or get a WiFi extender. Or, if it’s still under warranty, just push for a replacement. Spending more on LG makes zero sense when their products are this unreliable.
The one pro? If it works under Ethernet, you dodge further WiFi headaches. Cons? You’re dealing with LG’s notorious customer service. Frustration city.
Sounds frustrating! But before we give LG any more heat, let’s troubleshoot a bit more. Similar issues can occur with other brands too – sometimes it’s not just the manufacturer but maybe something in your setup.
First, try turning off the Quick Start feature on your LG TV. Sometimes, it causes goofy WiFi problems. You can find this in the Settings menu under General. Turning off Quick Start and then restarting the TV might just do the trick.
If that doesn’t help, you might wanna check for any firmware updates. Head to the Settings → All Settings → General → About This TV → Check for Updates. Outdated software can often be the culprit in connectivity issues.
If those don’t work, reset the network settings on the TV. Go to Settings → All Settings → Network → Wi-Fi Connection → Advanced Wi-Fi Settings → Reset Wi-Fi. This will remove all previously saved networks and you can then reconnect to your WiFi.
And you know what, sometimes it’s not even the TV but interference from other devices or household electronics. Get rid of any potential signal interference and see if that helps.
If after all this it’s still not working, and per techchizkid’s suggestion, trying an Ethernet connection can be a practical temporary workaround but keeping in mind scepticism about brands… sometimes switching isn’t the best immediate solution unless you’re 110% done with LG. For those critical moments, a universal WiFi adapter might save the day. Essentially, it allows your TV to connect wirelessly through a wired port using the adapter’s bridge function.
And don’t worry too much yet about LG’s customer service; they’re known to have mixed reviews but if your TV is under warranty, they might just help for the replacement end of things.
You’ve tried restarting your LG TV and router but the WiFi is still off? Bummer. Been there, done that. First off, let’s eliminate some common culprits without diving straight into hardware replacements.
Quick Start+ Feature:
- Go to the Settings menu under General and turn off Quick Start+. Sometimes, this little setting causes more trouble than it’s worth. Restart the TV after turning it off.
Firmware Updates:
- Ensure your TV’s software is up-to-date. Navigate to Settings → All Settings → General → About This TV → Check for Updates.
Believe it or not, outdated firmware can mess with network connections. If you find an update, install it and restart your TV.
Interference Check:
- Interference from other devices might be another reason for your WiFi woes. Cordless phones, microwaves, or even neighboring WiFi networks can cause problems. Ensure none of these are causing the trouble by testing your connection with such devices turned off.
Network Settings Reset:
- A bit more drastic but often effective, try resetting your network settings. Go to Settings → All Settings → Network → Wi-Fi Connection → Advanced Wi-Fi Settings → Reset Wi-Fi. Reconnect to your WiFi network afterward. If there’s any glitch in saved network profiles, this should iron it out.
Now, in case these software tweaks don’t do the job, let’s explore some alternative routes:
Router Settings & Placement:
- Sometimes, the problem isn’t the TV but your WiFi settings. Ensure your router’s firmware is up-to-date and the TV is set at a proper range from the router. Additionally, try changing the WiFi channel on the router. Channels 1, 6, or 11 are often less crowded. If possible, position the router closer to the TV and away from any big electronic devices or metal objects.
Ethernet Connection:
- As mentioned, try connecting your TV via Ethernet cable. This isn’t a permanent fix but a good way to check if the issue is solely with the WiFi module. If your TV works fine on wired Internet, then the WiFi module might be at fault.
External WiFi Adapter:
- No one’s really mentioned this, but if you’re not getting anywhere with troubleshooting, an external WiFi adapter can be an alternative. They often bypass the internal WiFi module. A universal WiFi adapter can connect via USB or Ethernet to your TV, turning a wired signal into a wireless one.
Testing with Another Network:
- Connect your TV to a different WiFi network, like a mobile hotspot. This helps identify if the problem is your home network or the TV itself.
Factory Reset on TV:
- If nothing else works, consider a factory reset. This one’s a bit more drastic and will wipe out all your personal settings, but sometimes, it’s necessary:
- Settings → All Settings → General → Reset to Initial Settings
LG Customer Support:
- While LG’s customer service has mixed reviews, don’t disregard them entirely. If your TV is under warranty, reach out. Be prepared for some back-and-forth but sometimes they provide a fix or replacement. Before this though, confirm and document all the steps you’ve taken. This makes your case stronger.
Exploring Other Brands:
- From your description and the vibes in this thread, considering another brand might not be overreacting. Samsung, Sony, or even some TCLs have better track records. Sure, it’s an investment but so is your time and sanity dealing with prolonged issues.
Experimenting with steps and recommendations from my peers might bring some unexpected result. I’ve specifically avoided repeating every troubleshooting step mentioned but some overlap seems inevitable given the nature of the problem. If troubleshooting gets you nowhere, considering a hardware bypass with Ethernet or a WiFi adapter might salvage the situation before a brand switch.
In the DIY spirit, solving it yourself is satisfying but don’t let it stop you from tapping into warranties or support services if needed. Best of luck!
Good list. Try a true power drain reset. It often fixes LG WiFi off.
Unplug the TV. Hold the TV’s power button for 30 seconds. Wait 60 seconds. Plug back in. Power on. After boot, wait 2 minutes. Turn WiFi on and reconnect. Dont skip the 60 second wait.
This is not a normal restart. It clears residual charge and reinitializes the WiFi board. Techs use it as a first step. No settings wiped. No router tweaks. If it works, great. If not, continue with the heavier steps you tried.
